You need to remember that Revel isn't only about neutral response, it's about what is preferred in blind listening sessions. It's possible that listeners thought the M145 sounded too thin without the extra bass bump, and preferred the extra bottom (even at the expense of some accuracy in the measurements).
And as others have pointed out, it's easy enough to EQ out, or pair them with a sub, calibrate and you're done.
One of the things we've done here at TSR is do blind and sighted comparisons between speakers that all measure very well - Perlisten, JBL, Revel. What's interesting is how much more spacious the Revels sound than, say, Perlisten. The Perlisten models are hyper-focused, hyper-detailed. But play a track like this:
...and when the full string section comes in at about 1:40, it literally sounds about 3" wide on the Perlistens. It's room filling on the Revels (for reference, we are usually comparing the Perlisten S7t with the Revel F328Be). We've had tons of people compare these two excellent speakers side by side and all of them hear the same thing, and often agonize over which they prefer. With Revel you give up some hyper-detail for the sense of spaciousness, with Perlisten you get hyper-detail but lose a sense of acoustic "size."
KEF is another brand that has that pinpoint focus, and similarly, instruments sound more "narrow" while Revel models sound wide open.
Which is better? Depends on personal preference and the specific recording. Interesting that the JBL models kinda split the difference, depending on the particular waveguide in use.
Point being that the Spinoramas are great for narrowing down the list of speakers to audition, but based on 9 years of us doing blind, sighted and double blind tests of top measuring models, it's still really helpful to give all these speakers a listen - preferably side by side and level matched.
Another quick recording to audition:
When the solo piano comes in at 1:36, note how "wide" the piano sounds on your own system. Again, with the Perlisten S7t that piano sounds 3" wide, floating right in the middle of the room. With the F328Be, you get a more believable piano sound, but you lose a tiny bit of the hyperdetail on the percussion.
Fascinating stuff.
