MoreWatts
Information on these new Revel speakers has leaked to the internet, so we might as well start a thread here. Revel is set to make official announcements in the USA on March 1. The 'Revel Owners Thread' at AVSForum has an active dealer that posts alotta info (and offers alotta help). The info here is from that thread, plus from WHAT HI*FI. I've seen discussion on these speakers show up on 2 threads here now, but these are important speakers, so we might as well consolidate. Why are these 'important'? Because the Performa3 F208 is prominent in Toole's book!
A few points gleaned from AVSForum:
I will add more info as it becomes available. @amirm, as a Revel dealer, please correct any info as needed.
Copy-pasta info from WHAT HI*FI:
R15 (£1699 / €2000 / $2000 a pair) = M145 as Performa4, in pairs only.
Compact bookshelf speaker
5.25in/130mm MCC (Micro Ceramic Composite) mid/bass
1in/25mm DCC (Deep Ceramic Composite) dome aluminium tweeter
Advanced Acoustic Lens waveguide
x2 rear-mounted bass-reflex ports
Magnetic grille
Black Walnut finish
R25 (£2599 / €3000 / $3000 a pair) = M146 as Performa4, in pairs only.
Bookshelf speaker
6.5in/165mm MCC (Micro Ceramic Composite) mid/bass driver
1in/25mm DCC dome aluminium tweeter
Magnetic grille
Black Walnut finish
R35 (£3998 / €5000 / $5000 a pair) = F345 as Performa4, singles available.
Floorstander
x3 5.25in/130mm MCC (Micro Ceramic Composite) woofers
x1 5.25in/130mm DCC midrange driver
Magnetic grille
Black Walnut finish
R45 (£5998 / €7000 / $7000 a pair) = F346 as Performa4, singles available.
Floorstander
x3 6.5in/165mm MCC (Micro Ceramic Composite) woofers
x1 6.5in/165mm DCC mid/bass driver
Magnetic grille
Black Walnut finish
R35C (£1699 / €2000 / $1500 each) = C245 as Performa4
Centre-channel speaker
x2 5.25in/130mm MCC (Micro Ceramic Composite) mid/bass drivers
Magnetic grille
Black Walnut finish
R25B subwoofer (£2599 / €3000 / $3000) = B140 as Performa4
10in/250mm coated fibre-composite woofer
750W total RMS power
Rear-mounted bass-reflex port
Black Walnut finish
- Revel has not updated their website, and the only current Revels are the PerformaBe stand-alone and in-wall speakers.
- Revel was always a ~USA-exclusive brand. That is the reason they've always been 'difficult' to acquire elsewhere. They now plan to expand, at least to Europe.
- Since Arcam is an established brand in Europe, they will sell the 'Revel Performa4' lineup as 'Arcam Radia.' No word on what they will do with the Revel PerformaBe line-up, at this point.
- There is only 1 center-channel available, and it is a 2-way. The AVSForum dealer was told by Revel that the C208 and even the C426Be never sold well. Probably because both are large speakers. At this point, if you want a Revel 3-way center, ya gotta spring for the big-boy C426Be.
- No more 8-inch woofers, which is sad news to a F208 owner. The big floor-stander now has 3 x 6.5 inch woofers. If you do the math, this is about equal to 2 x 8 inchers, with ~400 sq. in. of woof.
- At this time, only a 10-inch subwoofer is shown. Most of us here, however, pursue other subwoofer solutions (I use HSU, for example).
- "They are being produced now and should be for sale in the US in April 2026. They come in black and walnut finishes, both look matte, not gloss, but I'm not sure about that yet.... Are there grills for them? I don't know." The info below from WHAT HI*FI says they will have magnetic grills, and the only finish listed is 'Black-Walnut.'
- Dealers do not have Spinoramas yet, but these should be available soon.
- "According to Jim Garrett, the Revel business model is new generations need to beat the old in blind listening tests, so Performa4 should outperform Performa3. The new waveguide is impressive.... Concerta2 came after Performa3, so it actually had a better waveguide."
- Based on the above quote, the C245 center channel should be better than the C205, but probably not better than the C208....
- The dealer at AVSForum will probably hold-off on info updates until the official March 1 announcements from Revel.
- [EDIT: for info on the Anechoic EQ feature, see post #86.]
Magnetic grille
Black Walnut finish
Bookshelf speaker
Magnetic grille
Black Walnut finish
Floorstander
Magnetic grille
Black Walnut finish
Floorstander
Magnetic grille
Black Walnut finish
Magnetic grille
Black Walnut finish
Black Walnut finish
