I had some time waiting for materials for another project so decided to work in the wood shop for a day. I had a bunch of 3x12x36" cork insulation panels (like these) from a barn salvage so I set up the table saw with a dado blade and went to work. Subjectively they've opened up the soundstage a little bit and tightened the bass but fear not I've a MMM REW plot to accompany this new exploration.
They are based on Arqen's plans and I used them in a 5 panel array in a profiled modulation set up. The length of the assembly is 83", height of 28" and maximum depth of 7.5". They are faced with 3/16" book board leaving the sidewalls of the wells exposed for absorption and it is mounted on the top rear wall.
My speakers are also flying up high on the front wall. Big 172 liter 3 way active XO monsters in a 16x20x11 foot room:
And here are some plots from REW (variable smoothing) before and after with new EQ and room curve applied:
I'm feeling pretty good about how things turned out!
