With Purifi releasing their own SMPS at any time, that won't affect our business.
It will be great to see the Purifi SMPS soon.
Thanks
Thanks
As far as the paranoid me concerns,a Purifi SMPS will probably have all the western certifications and will conform with all the safety and EMC standards.Bruno and Purifi give us plenty of warning before a new product becomes available to purchase!
@mocenigo gave us the ‘heads up’ on the forthcoming 1ET9040 and even provided a picture, at the start of this thread 2 years ago and we still can’t buy it.
So I’m fairly certain that there will be business for MicroAudio producing SMPS with perhaps improved performance to Hypex for a little time yet . .
Though I’m not sure what advantages the Purifi SMPS might confer. Improved efficiency? Unlikely to improve amplifier performance since the 1ET9040 design is robust to power rail noise according to Bruno.
Now we can!
The SMPS should undergo certification any time now (they said the same one year ago). And the first one will probably be a lower power one (750W, so for 1ET400A and 1E7040SA), so for the largest module one will have to shop elsewhere.
Question - [probably not relevant for !ET400, as it has adequate PS with Hypex ones] but for 1ET7040 where Hypex PS are not adequate - is it possible to refurb/swap just the power supply without re-doing the whole amp [input buffers etc]
BTW I am one of the people waiting for 1ET9040 module based amps ;-) to be delivered.
Purifi is seen by their shareholders as a tech company. Meaning that they have to innovate. Per my understanding, this power supply is indeed innovative, reason why it's development takes so much time. Not due to the development itself but more to the challenge to get the various worldwide certification bodies analyzing and validating the new concept.
'Innovative'. 'New concept' and 'certification bodies'. I can see where this is going...
That sounds like a price increase. Do manufacturers usually brag about this and charge more?It's prime time for modern SMPSs to start using active rectification.
Ok, color me silly. What are you focused on?That sounds like a price increase. Do manufacturers usually brag about this and charge more?
Power supply. I asked about the power supply topology.Ok, color me silly. What are you focused on?
The power supply or the op-amp?
A linear power supply has sag unless expensive transformers and capacitors are used. A SMPS has near zero sag, is more efficient, used small inexpensive capacitors and transformer and overall is smaller.How would it be better than linear power supplies?
And if what I read SMPS has a bit of noise... which can be corrected at some expense.Power supply. I asked about the power supply topology.
