I couldn't hear any difference between the two in terms of imaging. I think people tend to hear what they think they should hear in that department. I'm pretty sure the results of a blind test between a wide-dispersion speaker and a narrower-dispersion unit would be very different from those of a sighted test. The HT may have a tad higher midbass level than big BMR tower, but it's subtle.
thank you
I know you are going for super wide dispersion to mimic orchestras.
but with such wide dispersion , don’t you lose the ‘ impact’ other less wide dispersion drivers give?
from what I understand sometimes a bit more focused directivity of SPL leads to better impact.
for example , how do the wide dispersion BMR towers handle a modern drum solo or rock music compared to let’s say a horn loaded speaker or speaker with wave guides.
A lot of ‘ negatives’ from some omnidirectional speakers are that they are too laid back sounding and too smooth because of the 360 dispersion.
Also when I go to see orchestras playing I always prefer to get a seat somewhere in the middle and distance wise somewhere again in the middle to closer to the front because I love strings.
if you sit too far behind in a concert hall the strings will tend to sound indistinct.
up too close and you will of course lose all the rest of the wall of sound from the rest of the orchestra.
i personally prefer a bit closer than center distance from the orchestra.
I think the topic of dispersion is more interesting and impactful to recreating a live instrument sound in speakers than has been researched.
if you think of it, every instrument has its own dispersion characteristics.
a trumpet will have more narrow directivity , a piano a wider dispersion
why rock probably sounds better on narrower dispersion speakers because , rock music for the most part uses amplifiers and cabinets for its sound directivity. A guitar cab for example is completely narrow dispersion compared to an acoustic instrument.
drums on the other hand are super wide dispersion. Maybe that’s why rock music sounds a bit off on wide dispersion speakers.
thank you as this is educational as well!
