Hi-fi listening.For DJ / slip-cueing (i.e. rugged) or Hifi listening?
It's probably picking up crunge your previous stylus pushed out of the wayJust bumping this thread. I have the red version and it sounds great. The only thing I have noticed is that the stylus picks up grime pretty quickly. I am wondering if it's just eating up the vinyl more than other cartridges/styluses that I have owned.
I started playing a record this morning and maybe it was due to the gunk, but the needle just slid completely across my record. Ugh. I may just go back to my Pro S. Those are pretty basic but they work well and the sound isn't bad at all.It's probably picking up crunge your previous stylus pushed out of the way
I've recently acquired a low-hours OM30 stylus to go with my 'Super OM' body which originally had an OM10 stylus. I used to regard the OM10 as a bit 'scrappy and bright,' but not this one so much (it's more like an AT [VM] 95E standard, a tiny bit closed in up top). The OM30 seems neutral and basically honest as my V15 III surprisingly is - I used to find the VN35E stylus a little hard toned, but it's surprisingly close to 'digital' in tonal balance - but the Super OM30 is ever so slightly 'sweeter' if anything without losing hf, but not as 'nice/bland' as my old ADC ZLM in comparison, or bass-heavy as my Ortofon M20FL-Super is in this deck. I only got this stylus as a cheap attempt to try to lift the vinyl a little bit without a major upgrade which I couldn't afford anyway.
Maybe the styli in the new models are effectively the same as the 2M range, but the OM versions recommended 1.5g tracking for most of them I recall
OM Series
OM 3E, 5E, 10, 20, 30 and 40 technical data Technical data OM 3E OM 5E OM 10 OM 20 OM 30 OM 40 Output voltage at 1000 Hz, 5cm/sec. 4 mV 4 mV 4 mV 4 mV 3.5 mV 3.5 mV Channel balance at 1 kHz/dB 2,0 2,0 2,0 1,5 1,0 1,0 Channel separation at 1 kHz/dB 22 22 22 25 25 27 Frequency response...ortofon.com
Yep, the new Concorde Music range have 1.8g tracking force and a lower compliance and tracking ability it appears, not that the 2Ms are bad in this at all. I wonder if the original OM styli won't be quietly phased out once stocks are depleted.
I have the silver 'OM Pro' and its rather sibilant at the recommended 4g playing weight (used in a not low mass tonearm as well). The OMs are far better up top really, I'd suggest.I started playing a record this morning and maybe it was due to the gunk, but the needle just slid completely across my record. Ugh. I may just go back to my Pro S. Those are pretty basic but they work well and the sound isn't bad at all.
That's a DJ cartridge, isn't it? I would imagine 4g tracking force is only required for scratching/backcueing.I have the silver 'OM Pro' and its rather sibilant at the recommended 4g playing weight (used in a not low mass tonearm as well). The OMs are far better up top really, I'd suggest.
The AT 607 stylus cleaning fluid/brush works so well and safely I think, on most styli and I've used this for many decades now (certainly since the 80s and maybe before). Linn used to supply some 3M green rough-sided sheets, which could be cut into strips and used back to front either side to remove some of the dirt from the stylus. The AT fluid does seem able to soften any stuck-on gunk which said green strips couldn't get and neither a dry brush on its own.
It doesn't track anything much below that. 4g is quite safe for a .7 thou conical tip.That's a DJ cartridge, isn't it? I would imagine 4g tracking force is only required for scratching/backcueing.
Unfortunately, a look at the specs shows that these systems, at 18g, are once again too heavy for many vintage Technics HiFi decks, im my case a SL-Q3.
Bump again. I have just got the music bronze and too have noticed that it seems to pick up a lot of crap, so interested as to whether this is quirk of the Concorde Music as opposed to a potential fault.Just bumping this thread. I have the red version and it sounds great. The only thing I have noticed is that the stylus picks up grime pretty quickly. I am wondering if it's just eating up the vinyl more than other cartridges/styluses that I have owned.
You can try inspecting it with a USB microscope. If it is really damaged you would hear noise/distortion as well. The Ortofon fine-line stylus is differently shaped vs. the microline, and would not be surprised if it picks up a bit of dust.Bump again. I have just got the music bronze and too have noticed that it seems to pick up a lot of crap, so interested as to whether this is quirk of the Concorde Music as opposed to a potential fault.
Someone else suggested to me that it could be indicative of a damaged stylus and the gunk is actually the record being shaved and not fluff/gunk which has me worried. Having said that I think it sounds great and I would think any such damage would be audible?
The other cart I have for my GR2 is the VM540ML and I also have a P3 Anniversay with ND5 so that is my compariosn
They were light because they were designed for low effective mass tonearms. These Concords had high compliance 30-35 /10 HzThe early Concordes released for HiFi were ironically, too light. But they did have limited overhang adjustment with a hex nut and could be slid in and out of the bayonet mount a few mm.
