NEW O-NOORUS D4 (TPA3255 PFFB / HDMI ARC / ES9023P)
Hello, @Alexander Lin
I want to convert my D4 to direct power amp without volume control i.e [bypass potentiometer].
Please can you ask your engineers and guide me how it can be done.
Thanks.
My review of the amplifier O-noorus D4 PFFB
Received a parcel from @meta1984
Within 30 minutes, using simple tools, I fixed the problem with the noise in the speakers. The problem was in the incorrect assembly of the cooling system, the capacitor legs were close to the radiator plate, I shortened them with nippers and everything worked.
Then I made several changes:
1. Replaced the operational amplifiers. Instead of opa1642a, I installed NE5532, this reduced the noise level and increased the SINAD to 90.3 dB
2. Changed 4 capacitors around the operational amplifiers, instead of 200pF, I installed 100pF, this made the frequency response almost straight.
Sine Wave 1kHz SINAD 90.3dB at load 4ohm 9W
Maximum power 63.5W at load 8ohm and THD 1%
RMAA measurement reportView attachment 432626
I recorded the sound of the amplifier via Bluetooth, a flash card, a coaxial port, I will publish a video review on YouTube a little later.
Why you replaces 200pf capacitor with 100pf.
Please explain
Hi sabih :)
The answer is in his text -> '...Changed 4 capacitors around the operational amplifiers, instead of 200pF, I installed 100pF, this made the frequency response almost straight...'
But no before/after curves were presented to demonstrate this: neither with a 4 Ohm load, nor with an 8 Ohm load :confused:
Have a nice day ;)
