Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 7,675
- Likes
- 9,578
I still don't understand why pro subs are so expensive
Why should they need improvement ? DSP ? maybe but in itself it doesn'at change much the sound
It could benefit from a better woofer like in the KH120 II and KH150
AFAIR improvement in the bass response was the major step forward over the O300D (7 dB higher SPL). Since I use a sub with my O300D I see no need for an update.The KH310 bass response is pretty good yet considering its size and closes cabinet. Must studios using this speaker seem satisfied with it, so why change ?
You mean they should close down their R&D and settle on selling their older products, because if they release a new version, everyone is forced to upgrade and invest more money, because the older models become bad instantly? What kind of logic is that?Of course, components and acoustic/electronics design have always a magin of progression and improvement. But is it worth the cost of R&D and making for the firm and is the slighly better performance worth the change and the cost for users ?
The KH120 also was almost perfect and still is great, but the KH120 II is a bit better in some aspects and also has the new digital stuff. I expect the same for the 310 II, some small improvements due to DSP implemetation, but mainly an upgrade in the digital domain. I won't buy it anytime soon, because the KH120II are sufficient for me, though.
With the new subwoofers, older analog Neumann monitors even got more attractive, i think. Studios or other users can hold on to their systems longer or even upgrade multichannel systems with older analog monitors and still use the newest DSP-tech, if they want.
There are things possible with DSP which cannot be done analog:No. Why should it?
Generally, pros buy entire systems from one or two brands whose technicians will install et calibrate them in the studio. For pros, homogeneity, reliability and long term service from the brand are top concerns. All this has a price.View attachment 476049
- Much steeper cross overs limit the range where 2 speakers overlap. This allows drivers to be driven louder without damage. The off axis dips and peaks are more narrow and hence less audible.
- Use delays to time align the drivers for a coherent wave front.
- Calculate the accumulated average power sent to each driver, to protection the voice coil of overheating.
To be fair, delays (variable! ) exists in even cheap analog garbagio like this.There are things possible with DSP which cannot be done analog:
