D
Deleted member 12642
Guest
I had a brain fart and realized the dsp is in the kh80 and the sub would be unaffected. Just used to doing it from the pc I didn't even think about it.
Review of the MA1/ Neumann KH 750DSP + KH310
Sound and Recording KH750 MA1
Also I find the highpass filter response interestingAh, there it is! But it is without the MA 1 actually. Just the KH750 + 310 + iPad-App. For linear phase FIR-filtering of the KH310 you don´t need the MA 1.
What i find interesting is the almost perfectly linear FR of the KH 750 solo up to 700Hz. I wonder for what cases this is useful.
That its not continuously dropping like the corresponding symmetric lowpassfilter (red curve).Why? Is it different than typical highpass filters?
What interests me more is why they chose/designed it this way.Ok. Maybe it is not really a highpass but a bell filter? I know nothing about filter design, though.
Got my ma-1 mic in, or is it the p48? it says both so who knows. The cost of this thing is insane for what you get. It comes in a thin cardboard box in some foam with no case, I would've expected some way of safely storing the mic for $250. The mic itself is very small, half the size of the emm6. It's build doesn't instill confidence but it's probably going to be a use it and put it away mic so whatever.
1. Setting output level is weird, it mutes the speakers and plays what I assume is an internal loopback measurement to determine output gain? I'm assuming it wants the monitor set to the lowest input sens. Mine were on stock settings so 100db, at the level the software picked this would likely have damaged the speakers, at this point I'm very aware of the relationship between my interfaces volume knob and how it relates to the speakers output so I didn't bother running it anywhere the softwares desired output. It's weird because later on it has you set the mic gain and speaker output together in real time and I find that's far more useful.
2. When identifying monitors I have them selected properly but in the actual measurement it shows the opposite speaker being measured? Left makes the left monitor logo blink, right makes the right one blink, not sure what's up here.
3. A little confused by the info given with the results. I expected a before and simulated after, and a target. What it gives you is simulated after and target, and you can adjust the magnitude of each corrected band in terms of deviation from the target? Am I getting that right? I don't feel super confident adjusting these settings without seeing the before correction measurements.
As far pro's this is probably the most "colorless" correction I've heard if that makes any sense. I've tried most of the software suites out there like sonarworks, IK arc, both of those never sounded quite right to me, something off about the mid and top end. I had dirac back in version 3 when there was a desktop app and I feel like that was the best that I had heard before this dsp. I've only run it once and I was happy with the results, sounds great. It was nice to be able to add a shelf in the top end. Tossed on father john misty pure comedy and it was just magic.
p48 means it has to be connected toi 48V phantom power. "Insane" cost... well, i paid 350 EUR for a Dirac stereo license only + 120 for a UMIK. Here you are getting a mic plus software for 250 EUR. I consider this "sane".
I don´t know what you were doing, but i think it´s supposed to work like this: You set input (mic) and output gain to some value (i use a middle position), then the software does a test to make sure measurement volume is always the same regardless what your gain settings are. Then you leave those settings alone. Next step is a short burst measurement around 85db that checks noise level. If that´s ok you don´t have to change anything else.
Red means "muted".
You can see the "before" result if of you uncheck "use automatic calibration". It takes a few seconds. Not very intuitive, i admit.
Good to that you had good results after all.
Desk reflection?Anyone have an idea what that ripple in the mid range is from? desk? ceiling?
This info should help anyone that wants to calculate their individual mic's calibration curve - take the golden mic curve and add the five filters encoded in the microphone code to it.
Overall, for someone that doesn't have a good understanding of how to set the delay and generate their own EQ, the software can get you about halfway there in much less time, so I see the appeal. I don't know why, but I was expecting a result better than my manual calibration, which didn't turn out to be the case. It's still much better than how my setup sounds uncorrected though.
Thank you, very interesting. I imported the curve in REW and set the EQ how you suggested based on the code on my mic. It looks plausible. But how do i create a cal-file from the "Predicted"-curve in REW?
Yeah, it did a better job in the 200-1000 Hz range too, but the bass response... :/FWIW in my case the automatic correction was way better than my manual attempts. But i surely don´t have a good enough understanding of what i tried before. I consider myself kind of an "enthusiast hobbyist" without special technical knowledge, but some trial and error experience i collected over a few years. The software was a bit better than me in integrating the sub and a lot better in smoothing the area above 200 Hz. But it is good to read another perspective from someone with obviously more technical knowledge.
That's basically the same way I would do it, yes. However I'm not sure if mic calibration curves are presented in this format, or inverted/upside-down. Basically the final resulting curve from A*Bing the golden mic curve and the hex mic curve is what needs to A*Bed with any measurement in order to correct it - it is the inverse of the mic's frequency response. If a mic calibration file represents the frequency response of the mic, and not the inverse, then you'll need to invert it as well.I think i figured it out (export filters impulse response as wav, import impulse response, all spl -> trace arithmetics -> A*B, export measurement as txt). I´ll try to use it later.
