New Neumann KH 310 II and KH 350 Rumors: Leaked Pricing & Info
especially when you listen in near field
I agree with the rest, but not this.
There's some idea out there that nearfield listening cancels the room and speaker issues off axis. Not only is that not true (for example, bass problems will persist regardless), desk reflections introduce new problems.
Have you contacted GIK for a free consultation?
They also have room kits which might give you some ideas.
Edit to add: they have an extensive knowledge base including a guide on how to use Room EQ Wizard to measure rooms.
GIK are on my to do list @Matt_Holland Flew back from hols last night. Will take some photos, once plaster's dry.
Wifes still deliberating on flooring atm ie lvt planks or stick down.raw, early stages but the fundimentals are there. On my to do list. Im trying to understand a few basics and potential ideas beforehand. Thanks.
I don't think this is a good approach for two reasons:
  1. GIK's advice follows old acoustics norms which call for excessive treatment.
  2. GIK will push their products. That's what the consultation is for.
Anyone who sees a steady-state room measurement for the first time is sure to have an immediate negative, overreaction. Plus, GIK is mixing advice with heavy-handed marketing. What kind of balanced, well-meaning article would ever include a section called, "Your Room Is Lying to You"?
I would counsel not planning a room around available products and services but to read books and the various threads here before planning purchases. Although I realize almost no one will do this because the consumer itch to acquire and get right into things is just too strong.
As this thread is about Neumann monitors, I think it can be a good idea to see what their view on room acoustics is for a home studio.
"As we’ve seen in the previous episode, the acoustic requirements for recording and mixing are very different. Most instruments sound best when recorded in a live room with some ambience – “acoustic support”, as the legendary engineer Bruce Swedien calls it. However, for mixing, we want a room which adds no sound of its own, a room that is essentially dead, so we can judge the recorded signals without any coloration."
Yes Im warey if GIKs "free" consultation.
Time is where I struggle, oh and mental capacity to cope with the maths and physics.
But mentally i was set on the 310s i see discounts already starting to feed through due to immenent new version release.
Ah... One day
Ah... One day
Buying the older KH310s is totally worth it. The degree of improvement with the next version will be, I would guess, mostly refinement than not, other than the MA1 DSP integration, although you can accomplish the same thing by getting a KH750.
I always liked the way this setup looked: https://www.audiosciencereview.com/...view-powered-monitor.17723/page-7#post-575431
Edit: Typo.
Lol and im concerned about speaker suitability for my room
My understanding is the space I have simply doesnt lend to a sub. Im really primed between the Trio6ST6 and KH310s, latter Im hoping sound better.
The ATCs are still in the back of my mind, but the range lends to the sub and back to £££s so ive got to be sensible i guess.
Might a a slightly hot take, but as long as you only care for a single seating position, DSP will likely be enough for bass if you have enough headroom or are willing to tolerate a dip (which are less audible that bumps).
If the room is meant for mixing, it's a good idea to have some control over the decay times so you can hear things like the amount of reverb and compression times, without too much interference from the listening environment. That's the main advantage of acoustic room treatment.
Try to find some psychoacoustically-backed research to back that up. I haven't been able to. Certainly nothing conclusive.
EQ works even for multiple positions as long as you are willing to compromise a little with a single sub.
I don't need to look for any research to know that.
I mix music myself, and I know it's way easier to hear what actually goes into the music mix when mixing in a less reverberant listening environment, especially when it comes to finer details such as the amount and length of reverb and the attack and release times of compression.
Do you find it equally as easy to hear what's actually going on in the music mix if you mix in an acoustically lively room?
Nice attitude.
Mixed music for 20 years. The only consistent issues have been to do with mixing bass below 500Hz. Everything else worked itself out with skill.
I put the below prompt into Chat GPT and got a lot of reasonable advice. At least a good starting point and I'm sure further prompts woulc aid either in giving more general advice, or suggesting specific treatment and hardware layouts for this particular room.
Referencing Sound Reproduction by Floyd Toole and other notable papers on room acoustics for mixing studios, recommend a set of key guidelines for room acoustic treatment for a 4.7x3.14x2.1m home mixing studio, including what the optimal reveration time should be.
That's a cynical stance, but fair enough in the case of me recommeding just one supplier.
Why not? That seems like a perfectly reasonable route to go down. I mean, most people don't have the time/will to become an acoustics expert
For many, that would just lead to more confusion and indecision. Personally, I would get 2 or 3 free consultations from companies like GIK, and choose a solution, maybe getting AI to help with the choice.
Everything was pretty well covered in this thread: https://www.audiosciencereview.com/...-are-so-many-on-reddit-in-love-with-it.72936/
My advice for the average person is to buy good speakers, have a way to make measurements and EQ, and then not to buy treatment unless there is space for low-frequency pressure-based resonators meant specifically for treating the SBIR region from roughly 100-400Hz. Any other treatment requires knowledge. For those unwilling, uninterested or unable to spend the time learning, the advice is not to spend money on treatment at all.
Nice attitude.
It wasn’t meant to sound like an “attitude” thing, it’s just way easier to hear what’s really going into the sound mix if the own listening environment stays out of the equation.
Question to ask yourself is if that idea is supported by the science or not.
Ok. But you don’t advocate for a bare room with just a chair and speakers, right?
In your opinion what is the baseline for a useable room in terms of fit out? Carpets, furniture, window dressings (if applicable), etc.
For critical listening to mixes, I’d rather have an over treated room than a bare room with excessive reverb and slap echoes.
