@Jlaz I mix and master for a living and use the 310s on a daily basis, so I hope my opinion can help you out in some way. When I was shopping for monitors I carried a set of KH 120s around studios and listened/compared with some popular options - Focal Trio ST6s, Amphion Two 18s/One 18s and a pair of bass managed 310s. In a few weeks I'll also be running measurements on PMC 6-2s and ATC SCM25s which I'll post here (since I've grown tired of having this same discussion with no data to speak of).
First off, and most importantly... at this kind of price point I've found most consensual monitor options to be good. Whenever I obsessed over forum opinions (and trust me, I did) pre-purchase I'd always genuinely worry I was spending a fortune on a mediocre pair of speakers. There's usually an insightful reason for popularity in this context. But really, with +/- 3dB flat FR speakers, using speakers daily, you can train your brain to listen beyond its traits. As you know, if the work sucks, it's not the speaker
. That said, I started my work on Kali IN-5s and headphones, so I've come to really value a flat and faithful response. I can't attest to it being better, but I can say I've never had to even think twice about mix translation to other systems. Broad/subtle FR preferences are so easy to correct for that choosing speakers based on that criteria seems ridiculous.
Regarding the midrange domes, I think you might be getting confused by the fact that a lot of people love the ATC domes in comparative opinions on Neumann's domes. Should I start by mentioning that SCM25s (at least here in the EU) are 2.5x the price of KH310s? Not saying expensive = always better, but that topic always seems to come up with a hint of "how dare this similarily round black driver not perform as well??". I find the KH310 overall to be very good and that extends to the midrange driver. The first octave, from 600-1200hz appears to accelerate/decelerate (transient response) a hair slower than the rest of the spectrum, but I've only noticed it through stress testing. The ATC's are valued for their frequency and time-domain performance in the mids, so I'd imagine the dome performs well, since it covers such a wide band. I'm very eager to find out in person and to finally have decent measurements. I did wish the kh310s low and mid drivers were XOd lower in the analog version (i image they'd be if it were possible). That'd do a lot to hide the woofer distortion at high SPL, since it wouldn't modulate the lower midrange.
Here in ASR we really value the way speakers interact with the room through directivity (rightfully so), since it's crucial for most listener environments. However, it is simultaneously the bigger cause for the divide between opinions voiced here and by studio professionals. At most treated studios, every first reflection point is absorbed to a very high degree, making the first milliseconds of a signal radically different. Not to mention how much less masking there is with low broadband reverb times - I imagine I wouldn't particularily care about speaker transient response if the room rang out long enough for me not to notice the speaker's acceleration. Pro monitor manufacturers can get away with a lot less care for off-axis response since their target audience would ideally mostly listen on-axis. I do not think that is a good design decision, but it is mostly true.
@Curvature, regarding PMCs, I do believe the new 6 series are an entirely different beast. I'll confirm with measurements once I get around to it. Those Result6s seem, indeed, awful. But it doesn't make much sense to keep bringing up an entirely different model every time PMC is mentioned. KEF has it's flops, but we're not rejecting it for that.
