New Neumann KH 310 II and KH 350 Rumors: Leaked Pricing & Info
Did not know they used a third-party dome previously. Measurements here: https://hifi-selbstbau.de/index.php/component/content/article/dynaudio-d-76af?Itemid=112&catid=15
I would very much like to speak with someone from K&H who could describe the reasons why they joined Neumann & Sennheiser, particularly from the engineering side. There must have been serious discussions about what the acquisition would mean for the quality of speakers before everyone shook hands and agreed.
Yup - D76AF in the 300 and if memory serves the 410, ATC SM75-150 (not the S model that has a more powerful motor) in the 500C.
Hi,
I still have the Klein+Hummel O 300 with a O 800 subwoofer. Would the KH O310 II be a real upgrade in your opinion?
Or maybe an alternative recommandation..?
Thanks
The original KH310 was already a massive improvement compared to the O300.
From the Neumann release note/FAQ comparing the O300 to their KH310:
(I attached the full doc for you.)
Going from your O300 to the mkII KH310 will be an even greater upgrade.
I seriously doubt that was an engineering choice. ;) :D
The good thing is that (at least for now) this studio monitor R&D center and engineers have stayed the same, hope it will also stay like this in the future.
Room is around 16 x 18 ('merican ft) I think. Arendhal s1 subs or whatever their smallest sealed subs are called. Listening distance ~ 10 ft. Crossover & bass management by MiniDsp SHD. Overall very happy with the setup and plenty of output. Wonder if KH350 would be much of an improvement, there is some appeal to a simpler setup though.
i have 15x12 feet room and planning to upgrade my HS7 to the new Neumann KH310 ii, but only worry I have is the SPL capability/internal limiter kicking in from too much bass due to their sealed design. i produce and mix techno music
There are enough pretty good measurements of SPL capability/frequency in this thread to help you make a choice.
i know, its just that i am without much experience on how those translate in real life
My opinion is that until we see independent measurements, and if you really want Neumann to either :
- Go with the KH 350 if you have room for them. It's a relatively big speaker volume wise, with a BR construction, the bass output will be much superior to that of the KH 310 II, and for where it's priced compared to the 310 II, it's absolutely worth it.
- Go with the outgoing KH 310 A. The mids and treble sections are basically unchanged, and the despite what Neumann said, my guess is that the increase output was for the midbass and above where the KH 310 A wasn't severely limited to begin with. Subbass limitations remain fairly high. For the price difference you might just want to buy a sub or two and enjoy the additional SPL and extension.
- Go with KH120II/150 with sub. Cheaper, arguably better horizontal dispersion than either KH310.
welp i need to check with Neumann, but i'd be on the lower spectrum honestly. my room size is 4.7m length, 3.5m wide and 3m high, and i am listening at 1.6m distance room is treated and fairly good
It's really not very big for a speaker of its output capability. It's a sort of medium-sized stand mount, about 56% the external box volume of the 420 (52L vs 93L). That's not to say it's small, not by any stretch of the imagination, but it's not that big either.
Yes, that's a more accurate way to put it.
you might be completely right tbh. also the kh350 would have a better horizontal dispersion. and when already paying premium price, i might stretch a bit more and get the kh350. the size would not be a problem, and Neumann are assuring me that my room is definitely not small for that speaker, also my listening position would be around 1.8m
I was also thinking that. The 310 II is very expensive compared to the 350. Presumably because everything else besides the cabinet is the same. Unfortunately the 350 can only be used in vertical orientation so in many cases it is not suitable as a center speaker.
When looking at the max spl vs frequency graph one can also see that both the 310 II and 350 have more or less the same output between 100 and 200Hz. The port only helps below 50Hz. When bass managed that advantage is basically gone and the output just above the xo region is about 105 dB. So when you really need output for movies it is exactly in this region. The max spl asked for is almost 0 dbfs here (so 105 dB) and we still have less of a noise signal and more of a low crest factor bass signals. The KH 420 is allowing for 113 dB output in that region - much more despite the DARDT rating being a bit lower.
Bottom line: When bass managed the KH 350 will likely not offer more max output than the 310 II.
not only for movies, for techno music also - which i produce and mix. but wdym by bass managed - MA1 calibrated? why do you think so that the output will be the same? first of all it will benefit by the design itself being larger and bass reflex vs sealed.
bass managed meaning "crossed over to subs".
thanks. that's another topic though, i was trying to decide for better SPL handling for house/techno production without the integration of a sub
If so, maybe you should go for larger speakers if you don't want to use subwoofers, since being able to hear deep, clean, undistorted bass should be pretty important for the genre you are mixing. Maybe you should go for the KH420?
It's hard to properly handle house/techno production in the bass regions without subs (or full-range mains), tbh
yeah, but adding subs or mains or getting the kh420 is a bit impossible now due to budget and the room size/environment. i mean, i am now doing that on Yamaha HS7 so it should be a massive upgrade already. I by no means am professional neither live out of this, its just my passion
Compared to the earlier KH310.
thanks, no expert but gave this screenshots brief look just to confirm the overall control and everything. however, charts like this cant really help me with how it will sound and how loud i can push it. i can feel the hs7 distorting when pushed loud (not even very loud) - but i dont know when the kh310 limiter will kick in. i can assume it will handle more spl but not how much more.
