RexrothPigeon
- Joined
- Mar 21, 2025
- Messages
- 1,829
- Likes
- 3,774
agreed, especially since the dip costs moreGiven the choice, I'd rather not have the dip.
That looks pretty good other than usual bunching at 2-4khz and some diffraction problems.Yes, ATC loudspeakers measures well enough for you or anyone else not to hear any problems in a real-world setting.
This is how my ATC SCM20PSL Classics measure, and it will only be people who are exaggerating the small deviations they see in the measurements who will think they will hear any problems while listening to these speakers. I don’t care for deep-diving nerdy stuff, in a similar way as I don’t care about the highest sinad numbers above what can be heard in a real-world setting.
You see that dip around 5kHz? It's present in nearly all ATC measurements we have, including one of the midrange driver: http://www.troelsgravesen.dk/ATC-SM75-150.htm It's consistent with a resonance. If you are interested you can try isolate it with a bandpass filter.
who here is exaggerating the deviations? I am not seeing that--in fact, it seems like an exaggeration (thank you, thank you, I'll be here all week, try the veal, tip the waitstaff, etc)Just an extra note about people here who tend to exaggerate deviations seen in measurements.
I own 3 pairs of ATC speakers, SCM11, SCM20, and SCM40. I have measurements for them and know what causes their individual deviations.
For the 2-way SCM20, the disturbance is a little bit of edge diffraction in the region between 4 and 5 kHz, which I can assure you that you won’t hear when listening to the speakers.
For the 3-way SCM40, there is a bit of a mismatch in the crossover region because ATC prefers their excellent mid-dome driver to handle a wide frequency range, causing a bit of recessed energy in the on-axis response, but it is compensated in the directivity response.
You may be right about what caused the dip you have seen around 5 kHz in the measurement, but it mostly affects the vertical directivity, making the 3-way speakers somewhat sensitive to listening height. This isn't a problem if you set up the speakers so that the acoustic axis of the speakers matches the height of the listening height. The horizontal measurements you have seen have obviously been made at the level of the tweeter, which is the wrong height, as their acoustic axis is at the height of the mid-dome driver for all ATC 3-way speakers.
None of the above-described problems make or break these loudspeakers in real-world use, but you can, of course, let your confirmation bias take the wheel if you want to exaggerate things seen in the measurements.![]()
Its more likely diffraction from the baffle.You see that dip around 5kHz? It's present in nearly all ATC measurements we have, including one of the midrange driver: http://www.troelsgravesen.dk/ATC-SM75-150.htm It's consistent with a resonance. If you are interested you can try isolate it with a bandpass filter.
In room reflections increase sensitivity to resonances, as the reflections gives you more "looks".
Have you tested thesespeakers in mono in a reflective room, compared them to others blind, preferably with both a great and terrible speaker mixed in to remind us how good/bad sounds, and confirmed you in fact do not hear this?
Having these experiences myself really opened my eyes.
These days I simply start *with speakers that can be corrected, use the Spinorama to make adjustment and ABX the filters blind to see if I can hear the difference and if so I then test if I prefer them with or without correction.
I never stopped listening.
my position is that I'd rather not have the deviation, especially since it's more expensive.
Recording, mixing, and mastering engineers don’t rely on marketing, they rely on the result and the satisfaction of their paying customers.
Thank you for the clear explanation of your position, I appreciate it.I'm not really concerned about what my loudspeakers would sound like in mono in a lousy listening environment. I have optimized the speaker placement, listening distance, and use acoustic room treatment to reduce room-related problems, which would otherwise reduce the overall sound quality in more ways than one. The strongest early reflections are down at -19 dB or lower, and I'm pretty sure I will prefer this type of optimization no matter what loudspeakers I put in the room.
I will not start searching for minor deviations that don't occur in a real-world scenario, which is me sitting in the sweet spot in front of my speakers, with the speakers' acoustic axis leveled to the height of my ears. I have no idea what loudspeakers you heard in the listening test, but if I’m allowed to guess, it was probably some loudspeakers with quite large directivity problems for the purpose of making problems more obvious.
what’s that bold syllable about? are you doing some kind of crypto-homophobia?My observation is a general one based on being a member of this and similar forums many years. Things like over analyzing small deviations is quite natural for a place focused on measurements.![]()
what are you doing?
If you would like to engage further, would you be so kind as to try and see it from my perspective?
You do not have to agree with it, but try to see the world through my eyes for a second.
What if the reason older speakers sounded "lousy" in those listening environments was at least in part because of those resonances in the speakers I mentioned?
And the industry learned to work around those imperfections because they made it more difficult to hear what was in the mix.
So we were taught how to avoid them by heavily treating the room.
And as such, do see how at least part of what you hear in an untreated room that sounds lousy to you could be the very effects I describe?
And how if this would be the case this does not make your observations invalid to me at all but that I would see/interpret your observation differently then you do?
Again, you do not have to agree with any of this and I am not telling you to go out of your way to test anything.
I am just curious if you could at least see the point I am trying to make.
If not I will simply see it as my inability to explain it to you, I will not hold it against you.![]()
what are you doing?
If I put myself in your shoes, I would try to gain a better understanding of the real reason why an acoustically well-treated listening environment is important when mixing music. It doesn't have much, if anything, to do with the loudspeakers' directivity behavior, and instead has much more to do with being able to hear what actually goes into the recording when it comes to finer details, the amount and length of reverb, and the attack and release times of compression, etc.
The idea that the loudspeakers' directivity behavior would be the main reason for an acoustically well-treated studio room is no more than a post-fabricated thing, based on a misconception or something that just happened to suit someone's "explanation model".
Anyone with at least a little experience with mixing music will understand the importance of hearing and sorting out what actually goes into the audio production, which is very hard to be certain of when mixing in an acoustically lively environment.
No is a two letter word my friend.
Like I said, I won't hold it against you, but if you are not interested in trying to understand I will not spend time trying to be understood.
All the best!![]()
The sounds you record in studios are resonances.If I put myself in your shoes, I would try to gain a better understanding of the real reason why an acoustically well-treated listening environment is important when mixing music. It doesn't have much, if anything, to do with the loudspeakers' directivity behavior, and instead has much more to do with being able to hear what actually goes into the recording when it comes to finer details, the amount and length of reverb, and the attack and release times of compression, etc.
