The research is very sketchy on this topic (psychoacoustics in general has limited information below 250-500Hz apart from specialized LF studies, almost all of which are recent). There is certainly a theoretical benefit, but it's not a benefit that has ever been established in controlled listening tests. Although also theoretical but on firmer ground is that sealed subs/speakers react more predictably to room gain:
https://www.audiosciencereview.com/forum/index.php?threads/analytical-analysis-room-gain.23211/
From the tests I've seen no sub or speaker ever exceeds the theoretical (I'm definitively overusing this word) 1-1.5 cycle LF GD limits. And as I typed the prior sentence I realize we are in the rare position of actually having that data from Neumann. So time to play with graphs.
I included the LF theoretical limits, limits from the Genelec GD paper, and a well-known paper on phase distortion audibility with GD limits from Jensen and Moller.
Been thinking about your replies this morning
@Curvature. Thanks again for persevering in this thirst for knowledge because your persistence on exploring the topic has been very beneficial to my research. I mean this genuinely. Sadly, the published science that touches on the audibility of small time-domain differences is not quite *there* yet when it comes to controlling extraneous variables and choosing methodologies.
My current thoughts on measuring time-domain performance is that I had been overly fixating on group delay (by mirroring pro audio conversation points) and somewhat undervaluing resonances (so, driver deceleration, rather than acceleration) and harmonic distortion. I still do think, after testing it, that GD is perceptible in the way sharp percussive elements are perceived and hope to dedicate a bit of time to posting some audio excerpts and graphs here this weekend. Should all this be in another thread? And I don't mean my measurements. We have completely taken over the Neumann thread with parallel discussions
Regarding GD. I have not yet researched the audibility of GD when it comes to phase linearized speakers, yet I would like to leave you with an example: The transient information on a typical snare drum hit is organized as follows. Within the first 5ms, most of the broadband content responsible for the physical sensation on impact (the transient peak) has already happened. The fundamental freq can take a bit longer, with a very low-tuned 120hz snare taking around 8ms. That means that around a snare's fundamental frequency range (say 120hz-300hz) a 3-5ms GD can mean that the transient's lower frequencies only reach maximum amplitude when the rest of the spectrum has already decayed. That's not better or worse, but I can vouch for the sound feeling different as a physical sensation.
These are my GD measurements of a Kali IN-5 (ported) and a KH310 (sealed) in the same room and position. There is around 10ms GD difference at 30-50hz, close to the Kali's port tuning. The negative GD peak is due to this being an in-room measurement, ignore it. This GD difference is very small and I don't realistically think most listeners should even care about this. But it's audible if you're listening for differences. However, compared to the difference in low end resonance (meaning how long the speaker resonates after the source stimulus has stopped) these GD times are irrelevant. Can't do it all in this reply, but I hope to post some examples soon.
Off-topic, I've also been thinking about this comment, regarding this measurement of a burst signal of the KH310 decay:
I don't know enough about signal processing to opine if it's a consequence of the Tukey window or if it's due to the reverberance in the hemianechoic chamber (anechoic with a solid floor) used by Anselm Goertz.
I found this decay measurement of an unrelated anechoic chamber at the University of Split. Definitely nonzero. So the answer seems to be a suggestive maybe.
This is another crucial question. Because there's no consolidated science on this topic, the whole audio industry has oriented their measurements to indirectly ignore the low end. Anechoic chamber, as a generic term, can be a simplification since, like Neumann's and certainly Split's (my studio has the same T20 as their chamber in the lower octave) are not by any means anechoic in the low end of the spectrum. It it much more expensive infrastructure-wise to build anything close to a true anechoic chamber.
PS: Yes, the blurriness in the spectrogram you posted is mostly due to window settings. I don't even think that particular graph is the worst offender, my original statement of complaining about its blurriness is probably misguided. But that just goes to show how disregarded time-domain performance is in the low end.
These hurdles, which are very particular to low end audio measurements, along with older studies stating on THD audibility in the bass region, among other factors, led us to a situation where effectively most measurements are disregarded below 100hz. So there's no data nor interest in the data. The Klippel NFS was a breath of fresh air in this regard, but even within the data we get here is ASR, notice how often relative THD graphs are cropped in a way that entirely disregards sub bass distortion.
Speaker resonance, in the low end, is yet another aspect of performance that is relatively disregarded for similar reasons. I personally work on a room with a quite damped low end because I find that the extra time-domain precision is beneficial to my work. The room has a T20 RT60 time of 100ms at 100Hz and 500ms at 50Hz. So the room has a longer decay time than the speakers, which appears to suggest that speaker resonances would be irrelevant in comparison. The difference is, however, audible and measurable since the room and speakers' resonant behavior is compounded.
These are peak-normalized spectrogram comparisons of both speakers' time-domain performance in the same room and position. I've included FR measurements for reference. It's not a night and day difference, of course. The Kali's port alignment is well designed and very far from being a boombox one-note bass reflex. But the difference in stored energy in the first 250ms is very noticeable. It can make a difference between clearly perceiving a bass part between two kick drum hits (keep in mind that an 1/8 note at 120bpm takes 250ms). Pair this with a gentle difference in the attack of the kick drum due to GD differences and you start to feel like the system behaves quite differently at low frequencies.
I'll add the disclaimer YET again. If you're in an average room, the decay times are so long that most of this is inaudible. I do not think, however, that a data point should be dropped just because it is only relevant in a very high performing room. I've also pondered on this designation - "high performing room" - since that is not most listeners' environment and came to the conclusion that the term is appropriate since the in-room response most accurately reproduced the input signal. I would really love it if Amir and Erin would start consistently presenting more time-domain data in measurements - spectrograms going down to 20hz, waterfall plots that aren't clipped to 20ms or 100hz, group delay, step response would suffice. They have started to do so, but all the older measurements have nothing.
