Curvature
- Joined
- May 20, 2022
- Messages
- 2,479
- Likes
- 3,970
Like you said, these are not comparable.I am currently looking for it, as far as I remember, a German website did the comparison before, I need to look deep for that. In worst case, comparing Anselm Goertz's max SPL measurements for Neumann and ATC can tell the story, however I want to find the direct comparison.
Neumann KH 420 Messungen - FIDELITY online
Neumann KH 420 – Studiomonitor versus High End Einige Lautsprecherhersteller betätigen sich bereits seit geraumer Zeit durchaus erfolgreich parallel in den Marktsegmenten High End und Studiomonitore. Der hier vorgestellte Lautsprecher KH 420 von Neumann Berlin dürfte primär in die zweite...www.fidelity-online.de
Let this be a placeholder until I find the real comparison.
KH 420:
ATC SCM25:
I posted a fuller set of S&R measurements for the ATC SCM25 and the KH310: https://www.audiosciencereview.com/...leaked-pricing-info.72465/page-6#post-2669027
Here's a comparison using extraction of the max SPL plots. Even then, I don't think there's enough evidence because of the difference in use to be very firm in an opinion.
- KH310: Sealed, 25cm x 38cm x 29cm, 13kg, 25mm tweeter, 75mm midrange, 210mm woofer, crossover points 650Hz & 2kHz
- SCM25: Ported, 26cm x 43cm x 37cm, 25kg, 25mm tweeter, 75mm midrange, 164mm woofer, crossover points 380Hz & 3.5kHz
KH 310 A - Three Way Nearfield Monitor
High-resolution tri-amplified near-field monitor, optimized for midrange and a dry bass sound.
SCM25A Pro - ATC Loudspeakers
Overview 25mm neodymium soft dome tweeter. ATC hand built 3˝/75mm soft dome mid driver. ATC hand built 6.5˝/164mm carbon-paper cone bass driver. On-board grounded source 235W class A/B 3-way amplifier. Compact size with high output and low cut-off frequency. 19˝ rack mountable. 6 year warranty.
Edit: To be clear, in this post I'm talking about having a firm opinion of the midrange drivers in isolation, not the speakers. And honestly the speakers and the end result are much more important, and there Neumann is a clear winner.
