"37 individual power supplies"
My whole system only has one power supply.
Tampa Electric Company now owned by Canadian Emera, though they may occasionally load-share with other utilities.
Mine too - the mains cable coming into my house
https://www.whathifi.com/news/nagra-hd-dac-x-aims-for-digital-perfection
As we approach the limits of audibility in $100 DACs, what does this offer besides snake oil?
Me hopes this post is in humor. Otherwise it is so sad.I joined this forum just to reply to you! Sadly, my friend, you are completely mistaken if you think you can measure audio gear on a test bench. You can, but it will get you nowhere near the truth of how components really sound. You are fooling yourself if you think a $100 DAC is as good as a $1k DAC or a $20k DAC.
I used to think like you, until I actually heard what a high end system is capable of. I can tell you that a $100 DAC that measures ‘off the charts’ on the bench cannot hold a candle to a properly engineered $10k DAC. Not even close.
Do yourself a favour and go out and listen to various components, and forget about S/N, distortion %, and other worthless stats. This hobby has nothing to do with those stats.
Or continue to live in ignorance, since it is supposed to be “bliss” after all!
OH, it can and it does. I have the system you are talking about (nearly $100,000). And I can tell without hesitation that I would be more than happy with said $100 DAC. I have heard hundreds of high-end systems and nothing about them would make your idea correct. You are letting your eyes judge the sound, not your ears.I used to think like you, until I actually heard what a high end system is capable of. I can tell you that a $100 DAC that measures ‘off the charts’ on the bench cannot hold a candle to a properly engineered $10k DAC. Not even close.
Hi. Welcome to the forum. In my 50+ years of using music recording and replay equipment I have had periods of believing that one can judge from measurements, then a couple of decades of sceptiscism where I was sure I could hear differences which didn't show up in measurements but after I retired 10 years ago and had more time I did much more in depth comparisons, starting with looking for a DAC that could decode higher than the 16/48 limit of my Goldmund Mimesis 20.I joined this forum just to reply to you! Sadly, my friend, you are completely mistaken if you think you can measure audio gear on a test bench. You can, but it will get you nowhere near the truth of how components really sound. You are fooling yourself if you think a $100 DAC is as good as a $1k DAC or a $20k DAC.
I've got to ask now and I think others that view this forum may well be want to pose the same question.OH, it can and it does. I have the system you are talking about (nearly $100,000). And I can tell without hesitation that I would be more than happy with said $100 DAC. I have heard hundreds of high-end systems and nothing about them would make your idea correct. You are letting your eyes judge the sound, not your ears.
What high-end systems can provide is massive dynamic range. In that regard, you want a well measuring DAC so that you know the low-level detail is not stomped upon as is the case with some boutique expensive DACs.
PMFJI.I've got to ask now and I think others that view this forum may well be want to pose the same question.
Given the measurements done by yourself showing that very modestly priced electronic equipment can perform equally as well as the high end audiophile equipment and that under ABX conditions nobody has managed to successfully distinguish amps, Dacs and cables (I think music severs may well fall into this category as well) How did you manage to blow £100.000.00 on a stereo system?
It's even more pertinent given the forums ethos is objectivity and this is your forum.
I've seen a few systems on ASR that cost incredible amounts of money, Which, given the opportunity, I believe I could match for performance at less than one tenth of the cost.
With regard to the dynamic range, the dynamic range on recordings is limited, you can't reproduce more than is on the medium.
Addressing the last bit first, so? Live music can have SPLs near 120 dB. You can't get that with inadequate amplification and speakers.I've got to ask now and I think others that view this forum may well be want to pose the same question.
Thanks for the comprehensive answer.Addressing the last bit first, so? Live music can have SPLs near 120 dB. You can't get that with inadequate amplification and speakers.
For the rest, it is a long story. I will touch on a few points:
1. Having an expensive system immediately short-cuts the claims of subjectivists that your system is not expensive enough to "hear" (really imagine) what they are hearing. Too often our objectivists champions have a $300 stereo and so are beat up using this argument. I like to not be subject to that.
2. I can't run ABX or proper multi-way AB tests on speakers. Harman can and has. As such, I purchased the best speaker from them that has passed such blind tests, the Revel Salon 2. These cost $23,000. Their lower cost speakers get very close to its performance but still can't match it.
3. Amplifiers are Mark Levinson No 53. These are $25,000 each. I have listened to Revel Salon 2s with less powerful amplifiers and they just don't quite get there with lower powered amplifiers in large spaces. The 53s are efficient which means they extract juice from the wall socket well. Can't say the same for many other classic high-end amplifiers. I also love their looks. They make me happy looking at them.
4. The DAC is a Mark Levinson No36S which cost thousands of dollars back in 1999. Today, I would not hesitate to replace it with a $300 DAC balanced DAC.
5. My company (Madrona Digital) is a dealer for Harman so the prices above is not remotely what I paid. Indeed this gear is purchased at accomodation pricing which is even lower than dealer cost. Still, we are talking tens of thousands of dollars so the system still cost me a lot.
6. I became an audiophile when I was 10 years old or something in 1970s. My first system was an all-in-one Aiwa cassette and AM/FM system. It was horrible in performance. From then on, I had a dream of having the best system I can. That day arrived when I could finally afford to get such a system and I went for it. It was a dream that took decades to come true. Quite a splurge. It is better fidelity than I deserve honestly. It is so good that I never come back from an audio show, after listening to hundreds of systems regardless of price, and wish I had one of those systems instead of mine.
In other words, this is a personal choice. Some of it is based absolutely on audio science. Others is about feeling of finally getting there and being happy forever.
There's a £20,000 prize for you waiting with Clark challenge.At this point, we are mostly talking about DACs. Nowadays audibly transparent and well measuring DACs are mostly straightforward current chipset implementations. It wasn't always the case and there are still potentially bad deals. I now have 6 or 7 CCAs. I extensively listened to the first one and could definitely tell its built-in DAC was inferior to the other ones I had. CCA optical is fine though and I use them as endpoints feeding other DACs.
Cables, interconnects, when they are sufficient (and sufficient has a very low bar I think), no differences.
Amps, I beg to differ somewhat in practice. I am sure "good" amps sound very much alike, but loudspeaker pairing is still an issue. The Focals I have are very picky and, in case of a poor match, are easily recognizable in a blind test, provided the content played hits on the problem ofc. I also ran a five amps shoutout on the KEF LS 50 for fun and there are not only significant differences but also measurable differences with a microphone and deltawave (some examples I posted previously).
At the risk of sounding a bit politically incorrect here, because it is a hobby and you can? The goal of a hobby doesn't necessarily have to be optimization for a single purpose although it can of course be.
If I was to build a multi-component system based on some kind of consensus here, I am would probably go for a transparent DAC with XLR, two Hypex monoblocks driving a pair of Revels F208. That would be well below $10000. Problem solved, for most cases. If you are into organ music and want that 16Hz feeling, you might want to add a big sub or two. If you have a large room, maybe upgrade the speakers... But it should be near optimal in terms of what has been measured here and elsewhere (Revels).
On can objectively decide to behave non-rationally in terms of ROI for hobbies. And there is also, as @Frank Dernie stated, the history aspect. We tend to accumulate things over the years and those tend to be obsoleted fairly quickly these days, especially on the digital side of things.
True, as soon as you get a decent system, you immediately realize the recording matters tremendously. You can't get more than there is, but you can often get much less.
Bottom line, one can agree 99% with you and still want to spend more because they enjoy the whole process.
I've yet to find any 16Hz content on any medium and not much that reaches 20Hz but yes, I agree, decent bass tends to cost.
That's very good. I had a much steeper roll off last time I measured, but I don't use subs. That peak at around 18Hz must be a bit of a shocker.16.5Hz here...
In the first tune on
Top - in-room with UMIK-1 with the signal to the speakers filtered by AcourateDRC, convolved in a miniDSP OpenDRC-DI
Middle - left CD channel
Bottom - right CD channel
(the CD levels are not calibrated, look a little high. What's important are the relative levels. The in-room levels noted should be realistic)
I try to match the in-room frequency response (peaks) to that contained on the medium being played. This as a cross-check for the test tone measurements.
Why peaks? That's what hits you in de side de haid harder than the little stuff you can let slide.
A little DRC helps.
The in-room is the sum of the left and right, so there isn't a perfect match. And I do still have a couple of problem areas. A dip at 48Hz - asymmetrical room and/or room node, and 215Hz dip - dipole interaction with the wall behind the speaker.
But it's close, and sounds fine.
