In the past i used an NAD M25 (former NAD Master dealer) until it was destroyed beyond cost-effective repair, since I bought the wrong standby board from an ebay seller, which was intended for USA / Canada. I donated the NAD to a local audio club. As a temp solution, I hooked up a bunch of 15 Watt Tripath amps to a linear PSU (and later several TPA3116 based amps), and that already sounded much better than the NAD. I compared our Atmos setup with these "improvised" amps, to the IPEM 64ch array In Ghent, so I know where I stand, with regards to Atmos panning and clarity, compared to extreme research projects, with much more speakers.
I also listened to my own 24/96 field recording of a local church concent, upmixed with DTS Neural:X and this recreates my experience - and that was already with the cheap improvised amps.
The amp-8 cleans up this improvised setup, by having all effect channels in one nice chassis. I also rearranged the equipment now on solidsteel racks, on wheels with locking mechanism, so I can easily access the 8x XLR and speaker cables. In the new home the good old solid steel racks do not visually fit with the living room, but perfect for the home cinema.
The amp-8 is here to stay. When applying the fan mod firmware, we never could spot the fan so that means the internal temp is in between 60 and 70 degrees all the time.
The next challenge is to buy identical XLR runs, since I used a mix of whatever spare XLR I had, a mix of mogami's, DIY and some cheap entry level for the height channels, just to confirm the cable routing and channel mapping works.
So next challenge is to find 8x short XLR. The Anthem AVM60 is directly on top of the amp-8. Yup that Anthem with the 1 kHz issue, which only distracts when played very loud, and the content is so silent that it competes with that 1 kHz issue. But it's rare enough I am postponing the search for a new surround processor.
