Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 7,479
- Likes
- 9,252
They sound pretty good
OK I stand corrected.I bought them new...
If only PJ if only!Back then everything was cheaper ...
We were the first with them in the U.K. and they were £9k a pair back then, for what you got it seemed pretty reasonable no Kii control back then of course. What are they now ( depending upon paint option) £16 k in standard grey?Wow, I guess I must go listen to these because I don't believe in hype. I bought my Kii Threes for around 7500-8000$ depending on exchange rate back in 2017 and thought that was already borderline too expensive then.
I also found the bottom end and upper bass lacking and added two subs (4x 10 inch drivers) to aid in the 20-200 hz range in my small room after experiencing the magic of BXT over the course of many hours in a largish demoroom.
I can't imagine feeling a mini-kii at the same + cost would ever feel like good value to me.
Well, just goes to show that we weight different things differently.
Yeah, the retail was around 10k, but even then it was a tough sell in the conservative audiophile community. Small, plastic and, worst of all, active wasn't an attractive proposition in the community 7 years ago. So I got a nice discount with the Kii Control included as one of the first buyers in my country.OK I stand corrected.
In Europe they were 10.000 euro with stands when introduced in 2015. Now they’re priced at 15.000 euro without stands.
What subs did you use?
I got the Kii Control included, but had to wait 6 months or so for it to arrive. In my opinion that Control is absolutely necessary and should be included as standard. We as consumers are morons to accept otherwise.We were the first with them in the U.K. and they were £9k a pair back then, for what you got it seemed pretty reasonable no Kii control back then of course. What are they now ( depending upon paint option) £16 k in standard grey?
Over here there are I believe only a few domestic kii retailers , Ultimate stream have their’s on Ebay one of the Scot’s have their kii/BXTs in the discounted section, the Cornish retailers don’t list them any more, probably more retailers I just don’t know about as the U.K. distributor doesn’t list retailers on their site.
Because the uni-Q used in the LS60 has a pure mid driver which must crossed high (in the LS60 it is crossed at 390 Hz) and above that frequency a cardioid wouldn't make any real sense or advantage as there is already a rising natural beaming there.I also am puzzled if the Kef LS60 can be made “cardioid” like the Kii Seven. They both have woofers on the side and mid/high on the front. Although the Kii’s front woofer digs down deeper.
Is the Kef “apparent point source” comparable? Why doesn’t Kef make the LS60 cardioid?
It does make a difference to the sides - Keep in mind that the orange is 10+dB down from the on-axis beam. That's a huge amount reduced in radiation. Besides that - the 200-500hz transition region is where EQ doesn't really work as it isn't minimum phase. The less off-axis you have there, the better. And boy do the Kiis do that.While cardioide has real merit, it's important to not go completely overboard with the claimed importance.
While it helps to reduce spl of far off-axis, or increase the focus of the beam, however one look at it, it's not like everything disappears. Kii themselves claim something like a 4,8 dB effect on the Three iirc.
I don't want to downplay the cardioide effect either, just establish a balanced perspective on what it does - and how it translates to reality.It does make a difference to the sides - Keep in mind that the orange is 10+dB down from the on-axis beam. That's a huge amount reduced in radiation. Besides that - the 200-500hz transition region is where EQ doesn't really work as it isn't minimum phase. The less off-axis you have there, the better. And boy do the Kiis do that.
Yes but it says pairThey usually price per single speaker.
There may be a mistake or something but the price is about half of what it supposed to be.
View attachment 345300View attachment 345301
That's why it's a bargain if anyone's quick enoughMust be typo in the US they are $7990 pair.
Kii SEVEN Compact DSP-Controlled Monitor - Fine Touch Dark Gray, Stereo Pair
Compact DSP-controlled 3-way active monitor pair with cardioid point-source technology, minimum phase or minimum latency modes, and XLR, TRS, AES/EBU, WiFi, Bluetooth, and Dante connectivityvintageking.com
