Trouble Maker
Do you understand what the other woofers are doing?
What do you mean? It says it has 1 high, 1 mid and 2 woofers. Am i missing something?Do you understand what the other woofers are doing?
The woofers on the sides are necessary for cardioid radiation and not ment to provide additional or lower bass response in the first place...What do you mean? It says it has 1 high, 1 mid and 2 woofers. Am i missing something?
Why is it "bad"? If it's good quality reproduction, many people will find it all the bass they need.Lots of Standmounts reach this low with single woofer... This is really bad.
So 2 driver dont bring more depth and just there for acoustics? Edifier s3000pro with 1 driver can go 38hz deep with small cabinet so i expected much bigger speaker like this ATLEAST to match and it cant even do that!The woofers on the sides are necessary for cardioid radiation and not ment to provide additional or lower bass response in the first place...
Cardioid bass radiation is mainly intended to combat the SBIR (Speaker-Boundary Interference Response) null caused by the wall behind the speaker. This is a common source of "bass suckout" so making loudspeakers that are less affected by it seems like a pretty good idea IMHO. For this to work the loudspeaker-wall distance should be appropriate (i.e. so the null is within the cardioid radiation range).So 2 driver dont bring more depth and just there for acoustics? Edifier s3000pro with 1 driver can go 38hz deep with small cabinet so i expected much bigger speaker like this ATLEAST to match and it cant even do that!
You still need subs with these so i have a hard time seeing how these can compete with something like Kef l60 that goes much deeper or any other small floorstand.
In the 3 below about 70hz they stop doing the cardioid shaping and transition to adding bass, I would expect something similar with these.The woofers on the sides are necessary for cardioid radiation and not ment to provide additional or lower bass response in the first place...
I wonder how just a pair of side-firing woofer can do cardioid.
Unless the 5-in midrange is actually a mid-woofer.
Just think about the side drivers being used to produce the same cancellation as the side vents in the 8c, it doesn't matter to acoustics what produced the sound, just that it shapes the sound correctly.Thats the thing that makes me wonder. They explicitly state "5 Inch midrange" and "two 6.5 Inch woofers". Other companys that were successfull with cardoid bass like ME Geithain or Dutch&Dutch solved the problem mechanically with damped and controlled openings in the back of the cabinet. Maybe there are controlled openings in the back of the Kii Sevens cabinet hidden somewhere?
Or it's just a shortcut done by a marketing guy.Wouldn't that imply that the 5" front driver is in fact a midwoofer instead of a midrange? In the Kii Three the front driver ist crossed over at 220hz.
EDIT: Would the following scenario be plausible? Lets say the front driver plays down to ~100hz and is high pass filtered. The sidewoofers are crossed over at lets say ~220hz. The sidewoofers play out of phase between 100hz and 220hz and thus make the speaker cardoid down to 100hz. Below 100hz only the sidewoofers play. The cardoid behavior would move up in frequency compared to the Kii Three. The front driver could more plausibly be characterized as a midrange as it is high pass filtered.
That's exactly how I would guess it works, hopefully we will find out.EDIT: Would the following scenario be plausible? Lets say the front driver plays down to ~100hz and is high pass filtered. The sidewoofers are crossed over at lets say ~220hz. The sidewoofers play out of phase between 100hz and 220hz and thus make the speaker cardoid down to 100hz. Below 100hz only the sidewoofers play. The cardoid behavior would move up in frequency compared to the Kii Three. The front driver could more plausibly be characterized as a midrange as it is high pass filtered.
It depends on your needs...In my case i would have to place the speakers on a lowboard....I simply have no free space for a KH 420. And a 8361 as a "compact speaker" on a lowboard is a no-go...So the Kii Seven comes at a very steep price but if it measures as good as the subjective experience indicates, i might put it on my list.Isn't the price a bit high if for a little more you can get much bigger speakers like KH420 or 8361?
The KH420 is butt ugly and way to old school (no dsp, is no roon endpoint, no tidal/spotify/qobuz connect, not wireless) for me. It’s just a simple active speaker with an analog input. Also not cardioid.Isn't the price a bit high if for a little more you can get much bigger speakers like KH420 or 8361?
