maty
Hence the surprise to notice so much difference. Live it must be much higher.
Unfortunately the review is Patreon only: https://www.alpha-audio.nl/review/triple-test-hypex-nilai-purifi-eigentakt-eval1-icepower-700as2/BTW this is the video maty was referring to:
What about the much more significant differences introduced by the recording process of each?If you are not able to appreciate the obvious differences, then you have a problem in your system
Agreed. No need to post three times in a row that way...Did you know that you can write 3 sentences or even more in one post ?
@maty himself wrote that the levels were not matched. No need to search further.What about the much more significant differences introduced by the recording process of each?
If you are not able to appreciate the obvious differences, then you have a problem in your system. Very few have optimized the O.S. for multimedia. BTW, in Windows I have been able, but not in Linux.
Soundimports seems to follow the 5 year/20.000 hours warrantyback to topic:
(away from the three stooges)
@Hypexsales:
on diyclassd.com you write "Warranty: 5 years / 20.000h"
(valid only for Nilai-related products ? / is there a "operating hour counter" in the Nilai-Modules ?)
1.)
why do you write in the datasheets / manuals then:
"DIYClassD.com warrants this device for a period of two years after the original date of purchase against defects due to faulty workmanship or materials arising from normal use of the device..."
e.g. here -> https://www.diyclassd.com/documenten/download/2457
2.)
is this a "manufacturer warranty" that is valid no matter where (at which reseller) I bought my Nilai-Kit or Nilai-Module?
So in case of warranty, do I have to contact my reseller first,
or can I (or must I) contact you (hypex) directly and to validate my warranty I just show you my original purchase receipt (from the reseller) ?
(Is it needed to have a S/N on my resellers purchase receipt ?)
Is it 20000 hours of operation? How do they know that? Does the module register them?
Who knows,it's the first time I see such a warranty for an amp.Is it 20000 hours of operation? How do they know that? Does the module register them?
Whether it will be cheaper than buying a kit is unclear.
Nilai500DIY: 350,-
PS500DIY: 250,-
Mono kit: 820,-
stereo kit: 1225,-
pre amp kit: 1225,-
all prices in Euro and ex VAT.
Edit
hmmm... I think you are right !plus21% Dutchshipping address VAT
Edit
