New Headphone Measurement Database by The Headphone Show
No? And why would we care if another uninformed group did the same thing?
My sense is that music producers HAVE TO use these words and think in this way. They want to engineer subjective impressions in their audience, and the objective manipulations are just means to an end.
And the science absolutely cares about subjective impressions. Where do you think Harman research came from? It was controlled subjective experimentation.
I feel Harman has focused on preference rather than what words people would use to describe a subjective impression. And so there really isn't a body of scientific literature for subjective reviews to contradict.
I am no authoritative person in this, but I can still easily translate most if not all of them into measurement features.
1. crazy is an intensifier, like "very", "significantly", "considerably", which are all used in science. It is just an informal version of those.
2. two FR ranges both being boosted
3. one FR range slightly boosted above the rest
4. this FR range is masked by another boosted FR range
5. need context for pummel, but again likely associated with boosted FR range that is heavily implicated in repeating rhythmic patterns
6. a certain instrument's frequencies are masked by boosted FR range elsewhere
7. too much bass, too little mids/treble
8. too much upper treble
9. FR boosted in the mids and treble, leading to sharpened transients, combined with bass boost
10. not one FR range is boosted to mask others
11. no sharp change in FR boosting or cutting
12. conflicting tuning goals, e.g., warm mids and bass + overly boosted upper treble
13. slight boost to the mids and treble
14. slight boost to a combination of FR ranges
15. peaks or valleys in the treble
16. smaller peaks or valleys in the treble
17. slightly excessive bass
18. boosted treble
19. boosted treble
20. no FR range sounds boosted or cut
21. unpleasant FR deviations from a certain target
22. the frequencies of a certain instrument cut or masked by boosted frequencies elsewhere
23. these pertain to spatial effects, and we know for a fact that even Harman hasn't researched into this, so there are no scientific things to say at all.
24. too much bass
25. ??? you sure this is related to sound?
To what specific quantifiable degree, using what specific metrics, in what direction, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
To what specific quantifiable degree, using what specific metrics, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
Define “masked”, as well as the definition in totality as far as what specific quantifiable degree, using what specific metrics, in what direction, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
Define “rhythmic patterns” objectively, and the definition in totality as to what specific quantifiable degree, using what specific metrics, in what direction, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
Define “masked”, as well as the definition in totality as far as what specific quantifiable degree, what instrument, where else would the boost be, using what specific metrics, in what direction, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
Define “sharpened transients”, along with the definition in totality what specific quantifiable degree, using what specific metrics, in what direction, compared to what standard?
Define “masked”, and to what specific quantifiable degree, using what specific metrics, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
To what specific quantifiable degree, using what specific metrics, compared to what standard, to what specific FR ranges? What would the compliant and non-compliant descriptor be in relation to that standard?
To what specific quantifiable degree, where in the treble, using what specific metrics, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
To what specific quantifiable degree are they smaller, where in the treble, using what specific metrics, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
To what specific quantifiable degree, where in the bass, using what specific metrics, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
18. boosted treble
19. boosted treble
Define “unpleasant”, then in totality to what specific quantifiable degree, where in the treble, using what specific metrics, compared to what standard, what certain target? What would the compliant and non-compliant descriptor be in relation to that standard?
Defined “masked”, to what specific quantifiable degree, where in response, using what specific metrics, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
If all of these terms had are easily correlated to objective measurements as you claimed they were, define spatial effects, then what specific quantifiable degree, using what specific metrics, compared to what standard? What would the compliant and non-compliant descriptor be in relation to that standard?
24. too much bass
I’m not sure any of them are related to sound, which is why I’d imagine they’re subjective terms and not objective science.
This isn’t purposefully obtuse, it’s demonstrating the difficulty in establishing a secondary language based in non-scientific metrics and personal impression without a floor, target or ceiling and applying them to scientific objective evaluation, or even a subjective one based in correlative reality.
We have some loose attempts at assigning subjective terms and instrument representation to areas of the frequency response, but there is no formal consensus or standard for most terms used or how they’re quantified and most “technicalities” have little to no basis in anything measurable or substantiated as legitimate:
It’s enormously difficult to find a sweet spot for communicating a device evaluation in a way that’s engaging and universally understood to a large consumer audience, more difficult to do this in ways that satisfy objectivists and subjectivists. To his credit, I don’t know of anyone in audio review that does this better than Andrew Park - The objective presented with explanation, the subjective presented with qualification. Mark Ryan also does a very good job trying to bridge measurements into subjective interpretation layered with consumer education.
The associations are truly arbitrary. Yet we can reconstruct what the graph looks like from many subjective descriptions.
There is no way you can do that. Go ahead and draw the graph, and provide back up for this statement in Listener's review:
"Older Audeze models were known for a thick, weighty bass that stayed firm into the lower mids, giving instruments a sense of physicality and chesty impact that few open-backs could replicate. "
Chesty impact, a phrase that makes no sense for a headphone, could be attributed to anything in bass. Sense of physicality is just nonsense audio poetry. Bass that stayed firm into lower midrange? Firm means what?
How about this:
"Audeze is known for favoring of a more relaxed top end compared to other planar manufacturers... except in the air where they're often quite forward, for me."
So it is simultaneously relaxed and angry at the same time?
The proper way to describe tonality difference is just that: too much bass; too bright, etc. These have a prayer of having some correlation with measurements.
To wit, here is a summary of terms used in Harman controlled testing:
The Subjective and Objective Evaluation of Room Correction Products
Sean E. Olive, John Jackson, Allan Devantier, David Hunt and Sean M. Hess
Harman International, Northridge, CA, 91329, USA
"Comments strongly associated with lower preference ratings are colored (r = - .9), harsh (r = - .86), and thin (r= - .75). Comments strongly associated with higher preference ratings are include full (r = .79) and neutral(r = 1). Comments weakly correlated with preference are bright (r = - .32), dull (r = - .2), and boomy (r = .36)."
In another paper, this summary was produced:
A Multiple Regression Model For PredictingLoudspeaker Preference Using ObjectiveMeasurements: Part I-Listening Test Results
Sean E. Olive, AES Fellow
Heck, you don't even need to read the above research to know the proper way to describe impression of sound that a) has real meaning and b) reader can understand them.
What they write is pure subjectivist nonsense without any firm connection to anything verifiable or usable.
Your feeling has no place in such a discussion. Harman training tools allow humans to describe colorations so well that they correlate quite nicely with measured results.
From AES Presentation:
Listeners are trained for discrimination of tonality errors in different audible bands:
Using this, human subjects were able to describe with high accuracy impressions that very closely matched measurements:
This is the power of knowing what you are talking about when it comes to describing fidelity of a speaker/headphone/IEM.
We have science. You just have to learn to use it.
The logical conclusion of "this means that each person's unique HpTF is influencing both in the same way" is that, for IEMs at least, measurements on a standard GRAS fixture tell most of the story. The "fear" that these measurements does not apply and aren't valid to you (generic you), and therefore must be viewed with a heavy dose of skepticism, is vastly overblown.
So does that mean if I use my wife's Airpods, which she has EQed using Personalized Spatial Audio for her own head and ear geometry, I would get that same/similar quality of spatial audio effects as her? If not, does that conflict with the conclusion that each person's unique HpTF has very little influence on preference?
Spatial hearing is a separate issue. Cup your ears or deform your pinnae will significantly degrade your hearing location accuracy. They are highly sensitive to very narrow band features in the frequency response curve (results from the frequency response alterations by your outer ear).
None of the target curves, as they are all highly smoothed, will be able to give predictable spatial sensations across a wide population of listeners.
The actual peer review process in science actually does not care about your past credentials. Instead, new research is evaluated solely on its own merits. The peer review process is double-blind, after all. And so I think critiquing the preference bounds or whatever DF+tilt target that HP.com have been doing in terms of the conceptual and empirical support for them is totally valid and should be encouraged. But repeatedly calling into question their credentials is not helpful, nor is it the standard practice in actual science.
And you can't equate subjective reviews with spreading flat earth theory. Flat earth theory contradicts established science. Subjective reviews don't, they are in a domain that science doesn't even care about, but the layperson does. The layperson wants to know "how the headphones sound like, subjectively" and doesn't have the skills to translate measurements into subjective expectations. And so the reviewer helps them do it. And the way HP.com does it is still relatively well-grounded in the measurement: I can easily identify which features in the graph correspond to which subjective descriptors they are using. Listener has also already illustrated it earlier.
Subjective sighted reviews are very problematic, the science taught us this. Unless the listening tests are done according to proper procedures, they are of very limited value.
These are for objectively describing where colorations are, not about describing the subjective impressions about what impact those colorations have on music.
The important thing is, the layperson has no way to interpret what "boosted 3k, cut 200hz" means, or what a headphone with those features will sound like.
We have seen what he said in 2025, which I repeat here:View attachment 568135
He did his own research with Dan Clark on these variations and came to such conclusions. I think the 2021 comments should be superseded by these 2025 comments.
And yet this year, just a couple of months ago, in his presentation entitled "How Much Headphone Personalization Do Listeners Need?", Sean said this:
The original question posed by Sean that I posted concerning differences between actual frequency response at the DRP of people and those measured by ear simulators still stands 5 years on - 'Does it matter?', and if so 'How much does it matter?' We still don't have definitive evidence that it significantly does to deviate from using "a well-researched population target [read: Harman target] and provide a simple adjustment range" in the form of a "simple bass and treble filter", as Sean clearly still thinks. This is the fundamental problem with what hp.com are doing; they are assuming these ear canal / outer-ear anatomical differences do significantly matter to warrant changing this approach without presenting sufficient evidence for this.
What also still stands is the point Sean made in the tweet I posted about hearing differences due to auditory nerve and/or hair cell function (which can of course be impaired via age or noise-induced hearing loss). The (rough) causal chain when listening to headphones is:
1. Headphone transducer converts electrical audio signal via mechanical vibration into sound waves.
2. These sound waves propagate via the pinna and ear canal (which impart their acoustic transfer function on them) and impact on the eardrum.
3. The ear, a biological transducer (inverse in initial and final energy form to the headphone), converts the resultant mechanical vibration of the eardrum, via intermediate mechanical movement within the inner ear to fluid pressure waves, then to electrochromical impulses in the cochlea via vibrations of the stereocilia (hair cells).
4. The auditory nerve then carries these electrical signals to the brain, where they are interpreted as sound.
5. The tonality of these sounds are judged by the brain to be 'neutral' / 'preferred' or otherwise, to varying degree, influenced by innumerable cognitive factors (in sighted listening one of which, subconscious bias, severely confounds true sound preference), in addition to just the signals from the auditory nerve.
Absent scientifically controlled, level-matched, double-blind listening tests, to claim DRP measurements at step 2 necessarily inform about preference judgements at step 5 is a gross (methodo)logical fallacy.
As an example, it could be the case that some or even many people who have ear geometries that amplify frequencies say around 3 kHz significantly more than the population average also have biological differences in steps 3 and 4 that reduce mechanical or auditory signals representing those frequencies; or that the auditory electrochemical pathways in their brain have over their childhood (where neuroplasticity is greatest) and adult life adapted to reduce the signals representing these frequencies and so the person's perception of their loudness to a level approximating the population median. We have no idea.
And it's because of this black box in the auditory causal chain, between the eardrum and actual perceptual sound judgements, that the only way to determine the true influence of any variable such as ear geometry or acoustic impedance and whether it really matters in sound preference judgements is to measure preference itself in blind listening tests and analyze any significant correlations that appear, if they do at all. Layers upon layers of assumption, conjecture, inference and untested hypothesis will never, ever get anywhere without this.
18. boosted treble
19. boosted treble
24. too much bass
In the context of their reviews, we know what the target is. It is the tilted version of their own HRTFs or the population average HRTF.
As to how much is "too much", I don't think there can be objective standards. Most gradable adjectives have vague thresholds, in daily life or in science, even then ones your diagrams display. It has to be up to the discretion of the users of the language.
Clearly and accurately communicating of subjective qualities is hard, but useful in the context of reviews for the layperson to read. The issue of vague thresholds is not an argument to completely avoid these terms.
Could be true, but still incomparable with spreading flat earth theory. of limited value =/= false/refuted.
I think the chest has an acoustic resonance between 100-200 hz, and a boost there could be where the chesty impression comes from. Sense of physicality makes intuitive sense to me as whether an acoustic instrument sound as if it is physically played rather than synthesized. Say for example if the sustain of a drum hit is unrealistically loud compared to the attack due to excessive bass in the tuning, this will then "lack physicality".
Back to palm reading?
You too have a future in audio fiction writing....
Nope. They were the words they used as trained listeners and they correlated with listening preference:
No one said those things. Actually, HP.com folks keep saying their made up impressions are due to stuff you write. The peak from measurements to justify some random stuff they want to say about a headphone.
And so, chesty = boosted 100-200hz. Physicality = the colorations (if any) are not making acoustic instruments sound unrealistic. I have de-fictionalized these terms, no?
top end = entire treble range, air = upper treble; take this mm-500 example, you see that lower treble is relaxed yet upper treble is boosted.
Compare with Hifiman, where the entire treble range can be said to be somewhat elevated
No. You are so far into it, you don't know what is or is not fiction.
In case anyone is curious: using the human vs. Welti/KB500x/5128 pinnae delta @Listener made (Figure 1), these are the Harman 2018 targets that should exist for each rig including humans (Figure 2).
Figure 1. Human pinnae vs. ear simulators pinnae
Figure 2. Harman 2018 target on: 5128 pinnae (red), KB500x pinnae (green), Human pinnae (blue).
Anyone who uses a GRAS rig with KB500x pinnae should theoretically be using the green target.. at least according to this.
That is all extrapolated stuff with no listening tests to verify validity. Actual work on this front as I reported was peformed by Dr. Olive and Dan Clark in the study that came out last year. As I explained, they arrived at different targets based on how many headphones were averaged and what headphone was being measured. Results were not conclusive.
If you do look at it for one of the headphone instances you get this (AI extracted):
Basically the graphs highly correlate until you get to mid treble. As far as I am concerned, that is where taste comes in and folks should just decide how much brightness they want.
