New Gustard R30 Flagship DAC/Streamer
That was with headphone listening too. I'd strongly suspect that once loudspeakers and a room were involved no-one could reliably tell the difference.
Archimago shows the difference in preference: It does shuffle the order. I agree that if you want to try to discern a difference in electronics, headphones are the way to go.
Installed the R30 yesterday, changed nothing else in the system, only the dac (D70s)
People who say ´all dacs sound the same´ are delusional.
To be honest, I didn't expect much of a change in sound (first experience with R2R so I was just curious) but if you don´t hear tonally differences and a different soundstage between these dacs you A have a hearing problem and need a new hobby or B your other equipment sucks.
Never would have believed it but my beloved Topping is in his box after 4 years.
Both dacs sound balanced but the R30 has more body/weight. The D70s is slightly more nimble but definitely thinner sounding.
Pinot Noir vs Malbec
In my system it is a great match.
Dacs can sound different if one is adding audible distortion.
Which I presume from your post the R30 is.
I liked your post and don’t care who knows it!
Do R2R DAC's always sound different like CHIP DAC's (ESS AKM ROHM)?
But it’s so much easier to get followers on a YouTube channel or a forum if everybody believes „HiFi“ is available to everybody for peanuts.
It’s especially nice for the retailers that prefer to sell and ship small sized low weight units that they are basically just drop shipping from china .
Marry that with small speakers with 5“ woofers. That fit even in the tiniest living room :)
Just replaced my McIntosh D1100 with the R30 and it sounds great... always had weird audio session pops and stream start delays using the D1100 but the R30 is flawless. Basically zero latency, immediate stream starting and no unwarranted artifacts. With the D1100 it would make a popping sound when initiating a new audio session over USB with an explicit setting to mute the first seconds of the stream output to remove the pop. like why not just fix the issue instead of cutting the first seconds of a song out? Never understood the limitation but it caused all kinds of issues trying to use it for watching YouTube videos since you would miss the first bit of whatever the person was saying. For what the R30 is and does I think the price is entirely reasonable. Sound quality seems better than the D1100 as well though I do miss the classic blue McIntosh meters ;)
It is a bit like owning an expensive mechanical watch. You do not buy it because it is supposed to measure time better (it doesn't). But because you know it has some ingenious internal complexity.
Would be fine if the manufacture (or reviewers, or re-sellers) didn't claim superior sound.
You dont find expensive mech watch makers claiming they are more accurate than crystal timed watches.
I got the Gustard R30 5 days ago.
I also own Topping dx9, Gustard R26 IFI Zen dac v2 and Eversolo DMP A6 Master Edition. The Gustard R30 is a step up from the Gustard R26 which already sounded better than all the others. Sound Stage is much bigger and much more deeper, everything is much more separated, everything is more dynamic, and the resolution went up a notch.
I never believed in DACS sounding much different from one another but there is a clear difference between the Topping DX9 and the Eversolo DMP A6 Master Edition (10/10 in a blind test) where the Gustard R26 and the topping are very hard to tell apart in a blind test (except for the soundstage width which is more enveloping with the R26), the Gustard R30 is easily discernable
No ‘soundstage’ information here,
‘Amplitude and time OR amplitude and frequency completely determine a signal’.
It’s really easy to imagine that you hear differences, having said that if one unit is adding audible distortion..
Sounds logic.
But, according to measurements, the Gustard R26 has a bit more distortion than the Gustard R30 and yet, the R30 sounds "bigger" so maybe other characters are in play like frequency? DSP? I'm not sure, I just know that one sounds different from the other, imaging more focused and "bigger" soundstage
Sounds logic.
It is extremely unlikely that any of your DACs actually sound different. You can't compare audio devices with a sighted, non-level matched tests with minutes or hours of switching time between devices.
Human echoic memory is only a couple of seconds long. Sighted testing is biased, even if you are aware of possible biases. And level matching to 0.2 dB or better is 100% essential because experiments have shown repeatedly that louder music is nearly always deemed to sound better.
"Sound stage" is an inherent quality of the recording. "Dynamic" is just louder. "Resolution" is just more perceived treble due to playing louder (see Fletcher-Munson curve). You came to a wrong conclusion because your testing is flawed. It happens.
Your profile says you have been a member here since 2024. Have you looked around much? Because this is a very old discussion and belongs in the “do DACs have a sound signature” thread.
You’ve already seen the reaction-it’s vanishingly unlikely you could perceive this difference blinded and level-matched, so the community here kind of views it as useless and misleading.
Why don’t we just ignore it? Well, my ignore list is long, but many of us are so incredibly tired of BS claims from the high end industry that we react and try to keep this venue, at least, clear of them.
Sounds logic.
I'm sure you compared level matched, controlled and blind.
No?
then your observations are meaningless - as you probably already know.
You are somehow right. BUT. I buy an expensive watch for its looks. I buy an expensive DAC for its work. I bought my Z8 because of both its looks and its works.
Resistor ladders have no magic, or super-duper-ingenious engineering in them... it's technology of the past, as it is vinyl, hence spending high numbers on such tech is a waste. of everything.
A good R2R DAC nowadays could (and should) cost no more than 250 USD. 10 to 15 times that is a theft.
Even if the precise tolerance resistors needed for R2R ladders were cheap enough to make a profit at the 250 USD price point, you're forgetting about economies of scale. The more refined the product, the higher the price, and the fewer units are sold - price and units sold are a function of one another, when setting the market price to be profitable. This is one of the underlying factors of "diminishing returns."
There have always been people who always say YES and people who always say NO, people who always agree and people who are systematically "against."
All of this is seriously lacking in nuance.
If your ears can't tell the difference between an MP3 listened to while jogging with your smartphone and headphones and a FLAC listened to in an auditorium with a coherent system, you're right, all DACs sound the same.
But if you're able to put yourself in favorable listening conditions and hear nuances, then you'll discover music in all its nuances and you'll hear differences between different systems. Some you'll like, others less, but that's a matter of taste, not nuance.
You shouldn't say:
"All DACs sound the same."
You should say:
"I've never heard any difference between a €200 DAC and a €3,000 DAC."
It would be more honest for the readers.
I'm beginning to suspect that most of the "all DACs sound the same" crowd here have sub-$500 DACs attached to Logitech speakers with those free RCA cables that used to ship with DVD players. With a setup like that, then why yes, all DACs sound the same, Garbage-A is difficult to differentiate between Garbage-B. None of them talk about their own audio equipment, and don't own the gear being discussed.
And like most religions, many here seem to be trying to bring in "inexpensive is fine" converts to reinforce their own realities, which is that inexpensive equipment really is as good as their more refined (and usually more expensive) counterparts. This hobby definitely does have more than its fair share of snake oil, and there is gear that punches far above its weight like pretty much everything from Topping, so we can say price isn't everything.
But many of us blessed to be able to own some of the better gear know that statements like "all DACs sound the same" and "the only differences between DACs sound are downgrades caused by distortion" are wrong, and that many who passionately push those statements are doing so to cope with the FOMO of owning their own bargain tier equipment.
There was a time in the early 00's when I purchased a set of Polk 5.1 speakers and a basic Denon AVR from Circuit City. I thought I had a great setup, and was happy with it. And then one day I walked into the showroom of a place called Definitive Audio in the Seattle area (forum owner Amir has 100% been there many times), with a much better setup. That was both a good day and a bad day for me, depending on how you look at it. My ignorance and naivety of actually listening to gear in person was lifted, my Polk and amp setup I thought was so amazing, was suddenly trash-tier. The sound of the piano being produced by the speakers in the showroom was as lifelike as the piano I grew up playing, no A/B comparison with my Polk setup was needed at all. There was some very overpriced Transparent cables in the showroom for sure, but the fact remained, some gear sounds better than others, and there is often strong correlation with price.
For gods sake, read the threads I linked to. Nothing you say hasn't been said a 1000 times on this forum. You are wrong. Please learn to understand why.
Non-owner of the R30 Svend, you called me out in the other R30 thread for "lashing out," there are surely more productive ways of convincing people than repeating yourself and telling others they are wrong. In reality, the number of posts won't increase the likelihood of convincing anyone of anything here. No amount of factual text or graphs will replace listening experience, which is the entire point of owning a DAC.
It's good if you're content with a more austere DAC and setup, i.e. "love what you have."
That post is a minefield of logical fallacies dressed up as experience. It starts with a classic ad hominem and genetic fallacy, dismissing anyone who disagrees as poor or ignorant rather than engaging with their argument. The validity of “all DACs sound the same” has nothing to do with whether someone owns a $500 DAC or $5,000 one; attacking people’s equipment is not the same as refuting their reasoning.
From there it leans on straw-manning and false analogy, comparing objectivists to religious zealots, a rhetorical trick that lets the you avoid evidence by implying faith instead of data. It’s a lazy way to moralize a technical debate.
The emotional tone is full of appeals to wealth and elitism: the idea that being “blessed” with expensive gear grants superior insight. That’s not expertise, it’s status signaling, an argument from authority built on spending power.
The claim that skeptics “cope with FOMO” is Bulverism: inventing psychological motives instead of addressing the content of their view. It’s also poisoning the well, pre-emptively discrediting anyone who might disagree.
When it gets to the personal anecdote about Polk speakers and a high-end showroom, we see anecdotal evidence, false cause, and confirmation bias rolled into one. The story proves only that you heard a better system in a different room, not that DACs differ audibly.
Finally, the whole argument hinges on circular reasoning and a false dichotomy: assuming that if you can’t hear differences, your system is bad or your ears are untrained, and that only the “enlightened” can perceive the truth. That’s not logic; it’s gatekeeping disguised as revelation.
In short, your post substitutes socioeconomic snobbery and personal anecdotes for controlled evidence. It’s emotionally satisfying rhetoric for believers, but logically falls apart at the first glance and addresses none of the actual arguments.
