I should note I just moved; this is the first measurement I've made from my new place and I had to use a bit of an impromptu setup, so forgive me for the small chance something
may be slightly off in places. I did spend a lot of time repeating the measurements to make sure, but there's always the chance something is off. I also measured from 2 feet instead of my usual meter. Shouldn't matter for a speaker this small, but worth noting.
I have a back yard now, which should theoretically help me get a wider gate for higher resolution data in the low mids and bass.
Unfortunately, my old measurement setup doesn't really work, so I need to build come up with a new 'rig'. In this case the speaker was light enough that I could just mount it on a tripod, but that won't really work in the future. And as nice as it is to have a back yard in NYC, it is much noisier than my old pin-drop quiet apartment. Plus it's going to be a pain to measure in the winter
But once I figure this out I should be able to get slightly better measurements, as I think I can reach an 8+ms gate in my back yard.
