Not sure ‘best’ is the correct adjective, hideous perhaps.
. The Sphäron (in the picture) cost about one million dollars has 4 18" drivers per side and dosen't fit in a standard big living room since the ceiling is to low in such a room.
I have heard them they are certainly one of the best speaker on the planet.Not sure ‘best’ is the correct adjective, hideous perhaps.
The speakers are for big rooms which bring some benefits in room acoustics. They are created with the intention to build an ultimate speaker where money doesn't matter. They have many "smaller" "more affordable" models which are for normal rooms.I'm not familiar with this brand. Do they explain why ceiling height matters (aside from literally not fitting in the room), and how low is "too low"?
OK I listend to the Sphäron in the Acapella show room and it sounded fantastic. Nothing compared to any small speaker system. Some older systems form Acapella are a bit bass shy and haven't perfect tonality but all newer models are absolutely phantastic. Even their "smallest" speaker the Harlekin 2 is better than almost all reference speakers from the usually praised brand here IMHO.I have heard various Acapella speakers over the years at the Hi-Fi ‘Deluxe’ show, I never once thought ‘these are one of the best speakers’.
He means the Violon.I don't know about that speaker? Never heard of it or can't find anything on the internet? Are you sure about it?
Yes my mistake, those are the ones he had… terrible.
Ok 15 years old, at that time I wasn't aware of the brand. The older models are more a hit or miss from everything I know. The measurements don't look that good tonality wise. But they seems to have very low to no resonances and good high signal handling.Well since we're so far off the rails anyway.
Also, lol. Nothing like an upward pointing in room response.
https://www.stereophile.com/content/acapella-high-violoncello-ii-loudspeaker-measurements
Ok which brand was your favorite and which model wasn't to your liking. If there is a company with better horn speakers I am very interested to know. The more famous brands like Avantgarde, Klipsch and so on was to me like expensive but not so good PA speakers...At a nearly two-year round searching for nice big horns (destined for a big space) Acapella didn't even make the top ten.
None of them.
Come on monitor speakers are not necessarily less colored. The smaller Genelec for example like 95% of speakers can't play back any instruments with high energy in the tweeter band correctly. They all sound more like a psss from a snare not like a tst like a real snare sounds, no matter how hard you try to equalize the speaker...Monitor speakers in studios are designed to reproduce all genres as authentically as possible, and some manufacturers are able to do this, but these HIGH-END horn speakers are intended for fans of very specific types of music. And too many people fall into the trap of their own deception, without realizing that a super speaker must sound as good as possible with all genres of music, not just elevator music or light music for older people.
The final choice was Blumenhofer DV-3.Ok which brand was your favorite and which model wasn't to your liking. If there is a company with better horn speakers I am very interested to know. The more famous brands like Avantgarde, Klipsch and so on was to me like expensive but not so good PA speakers...
And why does the snare sound like a psss and not like a tst at any volume? It is because many small dome tweeters have a inherent sound signature! The brand Bohne audio was founded because of this. If you know what to listen for you find the weak point of any speaker fast...test1234.
I've already mentioned this here almost a hundred billion times. If a speaker competes in the same net volume as the size of the enclosure against another competitor, Genelec beats most of its competitors with the Ones series and the Master series.
But if the measurement is only sound pressure, many PA speakers and hi-fi speakers sound louder and stronger, and there is more bass.
In any case, the highest sound reproduction that humans are capable of comes from these Genelec speakers, because the sound purity has been refined much further through the use of glm/dsp software, even with aes/ebu digital.
