dagfinn
- Joined
- Apr 9, 2023
- Messages
- 285
- Likes
- 610
Please doTransition seems a little steep there, I would add something in between or at the side (so can be mounted in both directions)
SPL? Did you ever compare the 8361a to a 1238a? I'm partial to the 15" vs racetracks... A 1238-size would fit existing holes in the wall, perfect upgrade for 1038abc around the world. Challenger to 1238a as well, I would say.Other than soffit mounting, why not get a 'ones'?
Just because of the form factor?I'm partial to the 15" vs racetracks
We have to think out of the box I think.
It looks exactly the sameWe have to think out of the box I think.
Since they own the 8381A arrangement at mid-highs already I would tend to believe they will use it at some form.
The mid-tweeter already looks suspiciously the same.
I grew up with big woofers, and their dynamic power is hard to beat. To improve on the 8361a, they used a 15"+12" for the W371A. Don't get me wrong, I'd love to have some 8361a's in the living room, but they are too expensive and my wife would refuse. In the music room, I know what I have now is my endgame.Just because of the form factor?
Yeah, it IS hard to put in words, really. I've been gobsmacked since I got the 1039a's in the house, and every day is a new revelationIf you don't know what the 12xx series speakers sound like, you don't know how high-quality these master series products are. They surpass many high-end passive speakers costing hundreds of thousands of dollars and their amplifiers in terms of sound quality.
The bits they have publised seemingly fitsThe new release on September 30 will have to be really tough if it is going to beat the 1238a in sound quality and sound pressure. That is, if it is a product concept in the same size class.
A triangle has no parallel walls. A tube has the same diameter no matter how you rotate it. Most monitors no longer use purely round straight ports to avoid this port resonance.Why are they using this shape instead of a round port?
That's my concern too, cheapest main monitor is S360 and I'm betting this release is an update to the 12xx series which means even more $$$$Whatever it is I can't afford it.
I wonder why they ditched their smooth wooferI see there's new ribbed woofer in the videoclip, but couldn't find the right one. Trying to understand what ribbing does for a woofer I found this:
"The speaker cone shape (profile) is a critical factor in the speaker’s sound quality and performance. If the cone is straight-sided (perhaps with concentric reinforcing ribs molded in the cone body), it will be the strongest and more rigid at very low frequencies. Decoupling rings can be molded into the cone body, which look like ribs, but a cross-section of the cone shows that while ribs are composed of added material on the face of the cone, decoupling rings are concentric cone corrugations. These corrugations allow the cone’s effective radiating area to decrease with rising frequency. The off-axis response tends to look better over an extended frequency range with decoupling rings (and curvilinear profile), allowing the speaker system designer the option of using a higher crossover point between the woofer and the tweeter or the midrange." https://audioxpress.com/article/speaker-cones-fabrication-materials-and-performance
Who makes the Genelec woofers?
