New Genelec 8380 main monitors
Or start designing the interior based on the fact that both the Blades and the 8380s are in the room.
Both blades and 8380s can be in the same room. Just that I won't be in that room because the wife would have me kicked out of the entire house
hey guys I am lucky owner of a pair of 8380 in my living room, and I can say very confidently that nitpicking over the data that erin shared on his review on compression is just non sense.
Those speakers are rocking ! I like the science and the numbers, but in the end, I am listening and enjoying the music. Those can go FREAKING LOUD. Headroom (almost) is infinite...
I tried to crank them up for some fun, with the glm mic at the MLP I recorded 115dbC EASILY while listening to some SUNN O))). I had ear plugs on, good thing my neighbors are not very close from my home.
The entire room was shaking, and a big smile was on my face the whole time. And I was not close to the end stops. I chickened out before the speakers even broke a sweat.
That is one thing to go loud. but doing it with low distortion, composure, and such accuracy is a rare experience.
on that matter the kefs can't compete. maybe the big jbl's can, but I have not tried them.
As erin said the 8380are just freaking awesome. I love them and listen to all my music all over again, just to know how it sounds on those. It is such a treat.
I agree with Erin on the listening window. I have them also slightly off axis ( not 30deg, but maybe more 20-25 ). The directivity is a bit narrower than the Ones, but it also helps with limiting reflexions and room interaction, helps to fire on a longer distance if needed. I do sit quite close actually, around 2.5m so I am in the window where direct sound dominates.
GLM is a godsend , and a must-buy and should be included with any sale of SAM speakers ! In my room they are measuring flat , the slight elevation erin measured over 2K could explain while the in-room response is so flat : here is GLM corrected response in my room at MLP.
So this is after the glm, without touching the sound character profiler settings ( so no messing around with the shelves ).Looks pretty good to me, but indeed not a tilt downwards like the "predicted in room response" graphs. My room is not fully treated as it is a living room, and early reflexion are kept in check with the highest one below -10db, and the RT60 is around .4 wich is good for a living space ( I hate overly damped rooms, but may invest some time building bass traps )
Honestly I kind of like it this way, and don't find it overly bright to my taste.
I tried a gentle tilt downward like erin did + 2db 100hz and -2 at 2k, and it does sound good, especially at higher listening levels, and with electronic music or mor pop oriented style, but I also think the sound looses a bit of air, shine, and presence. Most of the time I prefer only the sligth low end boost, and even keep it flat for acoustic or classical stuff.
What's great in GLM, is, one can do Group presets with different "flavors of target curves" and another neat trick, is that if you have the 9320 controller like I do, the presets can be enabled via the physical buttons on the controller,switch happens very fast, and allows to A/B differents sound character.
I can provide more measurements If you want just let me know what you want to see from REW data.
greg
Good luck finding drivers for a 20 years old hifi speaker
It really depends on the brand. Genelec seem to have a reputation for some of the best long term spare parts available. I don't know much about others, but once again you seem to be pigeon-holing "Pro" brands do X and "HiFi" brands do Y. If I acquired KEF Blades, I'd be very satisfied if they lasted me 20 years without another upgrade urge :D But I do prefer active speakers (5 years with Dutch & Dutch 8C's) due to less box count, built in protection, etc.
View attachment 564415GLM is a godsend , and a must-buy and should be included with any sale of SAM speakers ! In my room they are measuring flat , the slight elevation erin measured over 2K could explain while the in-room response is so flat : here is GLM corrected response in my room at MLP.
greg
I completely agree with you: people nitpick the compression dynamic range graphs that Erin systematically publishes
even though in real-world use the speakers play extremely loud without any issues.
there is some visible compression at very high levels (as with everything),
but nothing problematic for a speaker of this price and power
You made it look like those big speakers belong in that room!
I agree, GLM is awesome!
Thanks !
I am still playong around with placement a bit, since that picture, I have pulled them a bit from the front wall. Still battling that 90hz dip showing on the measurements .
Grade report is a great tool to understand room acoustics and help setting up the monitors properly !
Actually, I was the one who suggested replacing the Yamaha NS-5000s with the Genelec 8380
and I'm very pleased with how it turned out
the result is excellent, especially considering this is a living room rather than a dedicated listening room
as a sound engineer, I'm quite demanding when it comes to sound reproduction, so I wouldn t have recommended such a significant change if I wasnt convinced it would be a genuine improvement
The 8380s have clearly proven themselves in this environment
Theoretically would they work in a 3M X 3M room, or are they too big?
that would be a waste of money, with that volume 8331 is enough, add a 7350 sub if you want more bass. No point in future proofing now, better get something that is working now and enjoy the music, and not be stuck in buying paralysis .
I Went all In and sold all my previously acquired gear, speakers, amps, dacs etc. only kept the turntable. It was a risk, but I knew it was entirely worth it.
When you have the space and the room , upgrade is always an option, genelec usually keep good resale value.
my living room is around 120m3 in total volume with 3m ceiling, and has a big opening. I still think 8361 would have been enough for me realistically.
as I said before I was evaluating between 8351+w371, 8361, and 8380 for my upgrade path. either would have work for me. I listened to them and prefered the 8380. There is something special with those.
Erin mentioned Genelec GRADE™ (Genelec Room Acoustic Data Evaluation). It would be worth of separate YT-video imo. It is great review how G performs in your own room and how you could improve it.
It would definitely be an interesting video and I had considered that. But to be honest I have about 10 pair of speakers here and 4 different amplifiers that have to take priority. Some of them I've had for 6+ months at this point. If I were to ever create content around GRADE then it would have to be much later. And I'd also prefer to have the Genelec speakers on hand to give some additional data/information such as how the results can change if I add absorption panels, move the speakers, etc.
gotta disagree there. I'm in a 10'x10' room with 8361a's and 7380a's. 8331a and 7350a are toys.
Toys ??? Really ? With their SPL and FR, 8331A and 7350A are a superb combination for a small room. You can push to 8341A/7360A if you really need it, or why not 8361A without sub, but 8361A/7380 A in such a small room, I view this as kind of overkill.
This is good! :cool:
It would be interesting to take a look at the .mdat file.
SPL logger
Anyone and everyone can play Sunn O))) music at full volume on their own sound system. But how are you supposed to listen to Thomas Köner’s *Daikan* if the low frequencies are cut off below 25 hertz?..
