I was’t asking about Erin’s.YT is Erin’s Audio Corner. Patreon is likely the same, and in any event a Patreon link will be available on his YT channel page and/or in the descriptions of his videos.
@hardisj is Erin of Erin's Audio Corner, if you weren't aware.I was’t asking about Erin’s.
I wasn’t! Thank you!@hardisj is Erin of Erin's Audio Corner, if you weren't aware.
I honestly can't follow their reviews, they release 3-4 videos for a single product and it's all structured weirdly.
I appreciate his reviews. It's not my style and TBH I rarely watch due to lack of time but he absolutely puts in a lot of effort to provide his audience with tons of information and I like that - despite it being all subjective - he has different people come in and demo the speakers and provide their own feedback. It's entertaining. If you're into the subjective only side of things.
That said, I agree with you here. I haven't thought about it before but reading your comment I thought to myself "right?!". I personally think more structure - even something simple as "Part 1", "Part 2", etc with a standard format - would help his channel immensely.
Pink noise is among the worst signals you can find for measuring maximum SPL of a loudspeaker, even worse than the typical sine sweeps. Spectrum which is nothing like typical music material and only 6 to 12 dB crest factor (depending on source) which is much too little especially above the bass range. M-Noise (AES75) is a good initiative, but it also has its issues and the procedure is painful and slow to use. We are not using either one internally.You're right about the sweep, here's the conditions:
Talking about music though, wouldn't it make better sense to measure it with something like PN or M-noise across the spectrum as it is additive?
(my previous post at another thread was about that too)
The tweeter sees the signal already from about 2 kHz and upwards where the crossover is. That is where the heat starts building up because of the sweep direction. A 2.7 second sweep spends about 0.9 seconds from 2 kHz to 20 kHz which is an eternity from the tweeter's viewpoint which is designed to produce high SPL peaks of a much shorter time. Anything longer than a few tens of milliseconds will trigger the protection circuit at that kind of SPL.In a logarithmic 2.7 s sweep from 20 Hz to 20 kHz (ca. 10 Octaves) the range from 10.000 Hz to 20.000 Hz (the last Octave) is only forced pretty much exactly 270 ms
Perhaps it should have done better in this testing.
Here the KEF Blade 2 Meta as an example:
I can't promise it, but I will see what I can do.Would you be willing to share your result?
In previous years ago, perhaps. But sites like ASR and Erin have bridged a gap between Home and Studio speakers. Unless I'm mistaken, Erin has stated in this thread that he would enjoy owning either a KEF Blade or a Genelec 8380A in his home for purely Home use. His reviews are seemingly targeted primarily at Home use where he subjectively evaluates them. I think about owning either of these speakers for personal Home only use in the future. There are seemingly numerous ASR members who use Genelec speakers purely for Home use.Blade 2 and 8380A are two completely different loudspeakers for two completely different applications.
This is what I think, it is much easier to determine the tonality of a speaker if one can quickly A/B against a measured neutral on axis response. Otherwise, one is entirely dependent on what is neutral from (questionable) memory.I heard it in a relatively large, moderately damped room not so long ago, with GLM enabled. It came across as pretty neutral (so not overly bright).
And, there is no reason a KEF Blade cannot be used in a Studio, granted it has no built in protection circuitry, but presumably that could be somewhat achieved manually via DSP. I can't see how a KEF Blade would be anything other than a well above average speaker for Studio use, from purely a performance point of view.
The Blade is a passive speaker which makes it irrelevant to probably 90% of the studiosIn previous years ago, perhaps. But sites like ASR and Erin have bridged a gap between Home and Studio speakers. Unless I'm mistaken, Erin has stated in this thread that he would enjoy owning either a KEF Blade or a Genelec 8380A in his home for purely Home use. His reviews are seemingly targeted primarily at Home use where he subjectively evaluates them. I think about owning either of these speakers for personal Home only use in the future. There are seemingly numerous ASR members who use Genelec speakers purely for Home use.
Get both. It would be interesting to read a comparison.I think about owning either of these speakers for personal Home only use
From a performance point of view, a KEF Blade is seemingly a very acceptable speaker in a studio.The Blade is a passive speaker which makes it irrelevant to probably 90% of the studios
Plus it doesn't have any room correction
So you're comparing apples to oranges
I think people complain about comparing apples and oranges too much....So you're comparing apples to oranges
Wouldn't it just!Get both. It would be interesting to read a comparison.
Yikes, hate that.FWIW, the data for these may wind up not going on my website anytime soon. I’ve had a lot of issues with other websites using AI to scrape my website/data to generate “reviews“ and affiliate links. I’m considering a complete overhaul of my website or a second one to be more like a buyers guide mainly to disrupt the flow of traffic to these other sites. Quite frankly, I’m pissed off by it.
Correct in one. Bass runs out much sooner than mid or treble.it is much more likely to reach the maximum SPL of a loudspeaker below 100 Hz than it is above 10 kHz.
