NEW GaN Amplifier : Dual ACM8816 GaN amplifier chips + AK4118AEQ [YJCO D816]
Hi, what I would like to understand is: What is a QFN48?
It's the standard packaging format the chip uses:
Quad - the contacts are on 4 sides rather than Dual or Single lines of contacts
Flat - it's flat to the board not sticking up vertically
No leads - instead of having metal legs sticking out it just has contact areas that get soldered to the pads on the board
48 - the number of contacts, excluding the large heat transfer pad that's often in the middle. Combined with the Quad this means there will be 12 contacts per side.
The point was that it's a small package so there's a fairly low limit to how much heat it can dissipate.
But the whole point of using GaN is, hardly any (or at least way less?) heat generated in the first place, right?
Not like the design efforts needed for TI TPA32xx
Functional block diagram, include a DAC and delta-sigma amplifier.
And analog feedback for ‘poweramp’ after the DAC
The only issue is that the feedback occurs before the filter, which is very messy, disadvantageous, and error-prone.
Even if a prediction algorithm—like the one used by Infineon—is employed, it is clear that the result falls far short of being optimal.
Got the d816 today after high hopes reading this thread.
Gffhhsssssssssssssssssssssssssssssssssssssssssssssssssssssssss when you turn up the volume past 65.
Its going back tomorrow.
Anybody know a different class d that puts out about 150 watts @ 8ohm, for about 500 euros? There is the 100 bucks league, the nothing, then 800 bucks for still quite weak pirify or hypex. the only class d with a bit of juice go past 1000 and i simply find that way tooo expensive for this simple technology.
The Mono flavour of 3e A7 allows for not just 10A of available current, but going up to 51V when you want / need to squeeze every SPL drop possible.
Adjustable PSUs are not necessarily that much more expensive, open chassis needs an enclosure ofc
After that ICEpower, Hypex, Purifi etc
I’ve received my D816. It might be unfair to evaluate it without a proper break-in period, but for the price—especially considering it’s also a DAC—the sound is fairly ordinary.
The sound is similar to the SMSL AO10, or perhaps even the PA40.
It’s powerful, bass-heavy, and "thick," though the overall structure feels a bit budget-tier.
What stands out, in particular, is a simplification of the high frequencies, along with potential distortion in the high-frequency range.
This becomes noticeable with complex music, though. If you listen to pop, club music, or rock, this DAC/amplifier is perfectly fine for someone just starting out in Hi-Fi.
That said, I didn’t notice anything truly outstanding.
Who knows—perhaps the high frequencies will smooth out a bit after some break-in time.
break-in period
Just in case you don't know, this sort of subjective nonsense is not in line with this community's culture
I know you might not believe this, but after a 20-hour break-in period—with the speakers wired out of phase and facing each other to minimize the noise—this amplifier sounds truly excellent; the harsh, "dirty" high frequencies are gone.
In my opinion, it’s now on par with the Raw MHA1 + SU-3 combo (which cost $200 each)—and in some respects, perhaps even better.
Considering it has a built-in DAC and costs just over $100, it’s absolutely phenomenal!
If it can't be measured, it can't be heard. There is no such thing as break in. It is brain in, where your brain get used to the sound over time. How would you even remember how it sounded like 20 hours earlier?
I didn’t actually listen to it for those 20 hours; I just left it running, with the bookshelf speakers tucked under a blanket.
The difference is so obvious that I believe it could easily be measured.
When I first took the amplifier out of its packaging and ran it for 2–3 hours last night, the high frequencies were clearly distorted, and the sound felt more constrained.
I have quite a bit of experience with "breaking in" amplifiers, though in only a small percentage of cases has the process actually changed the sound.
For example, the GZLOZONE 3255 and the "blue board" 3255 (the one with two large capacitors)—I bought both brand new from AliExpress, and out of the box, they sounded rather lackluster. In those cases, 20 hours was plenty of time for that to go away and for the sound to become normal.
Perhaps 5 hours would have been enough; I’m not sure.
On the other hand, amplifiers like the Ampapa D1 showed no change whatsoever, even after 250 hours of operation.
I did that purely out of curiosity.
The SMSL MHA1 also didn’t change its sound at all—though, to be fair, it wasn’t brand new when I got it; it might have already been "broken in" when FanatNsk performed measurements and maximum power tests on it.
As for the SMSL AO10 (based on the 3116 chip), I bought it new, and it didn’t sound great.
After 150 hours, nothing had changed, but by 200 hours, it began to sound noticeably more pleasant—though, in this instance, it could just be a trick of the mind.
Then there’s the D5 Pro, a clone of the NHB-109; when it’s brand new, the high frequencies are truly awful. After 150 hours of break-in, the highs improved, and by 200 hours, they got even better—though they likely won’t improve any further. Regardless, the high-frequency range remains the weak point of this amplifier.
Show us the measurements then.
This has been discussed endlessly.
Here's a combination of factors that should raise skepticism:
1. Noticing a sound change that subjectively appears extremely obvious. and
2. Finding out that no one has ever measured a shift in amplifier response over time due to burn in.
Any huge shift like this, if it really existed, would be easy to measure, right? So, something else is happening.
I have no doubt that you heard this change and that, as you say, it was obvious. No one is doubting your perception. The doubt is that the perception was based on changes in the amplifier rather than changes in your perception...ie cognitive bias. Cognitive bias is not subtle, it is not a sign of weakness, it determines how all of us hear, see, and perceive the world.
I recall another example from my own experience: a long time ago, I bought a new 3e Audio 3250 (SY-DAP1002) from AliExpress.
On the first day, it sounded a bit "dirty."
After 24 hours of "break-in," that effect disappeared.
Because of this, I believe it’s good practice to give new audio equipment—amplifiers in particular (and perhaps DACs as well)—about 20 hours of run-in time.
Whether or not it makes a difference in any specific case, there are times when it is absolutely critical.
