The output low pass filter is usually an LC filter (a coil inductor plus a capacitor). It gives a 12 dB/octave attenuation. An LC filter has very little damping, and the actual damping relies on the resistance of the load (the loudspeaker) to dissipate the energy. There the lower the load resistance, the higher the energy dissipation and higher damping. That's why you usually see a higher response peak at the filter cutoff frequency for an 8 Ω load than for a 4 Ω load. This problem of load dependent frequency response can be effectively mitigated using post-filter feedback, as in the cases of Purifi, Hypex, Axign, Icepower, many of the newer TI chip based amplifiers with PFFB, etc.
Below is a block diagram of an Axign based amplifier. Since the Axign operates in the digital domain, all the digital signal processing rules and techniques apply. The brick wall filter is from the digital processing of the signal.
I'm going on some traveling starting today for the next few weeks. So my posting will be sporadic.
