NEW GaN Amplifier : Dual ACM8816 GaN amplifier chips + AK4118AEQ [YJCO D816]
daniboun
France (Lyon)
Hi amigos,
I’m sharing another discovery I made by chance while chatting with a guy on an audio forum. There is a GaN amplifier based on dual ACM8816 chips that features very comprehensive connectivity. This is actually a true dual-mono amplifier; the ACM8816 chip is inherently a mono chip with I2S digital input. (It could almost be described as an FDA)
There are several versions, with or without a PSU, ranging from 36V to 48V.
This could be a modern alternative to the TPA325x chips that are flooding the market...I think we'll need to wait a bit to get a better perspective on this little amp! But in any case, it's very interesting...
YJCO D816
About the ACM8816 Gan Chip
SPEC :
Ultra-Compact, Ultra-Powerful
300W×2 output in a palm-sized chassis (152×140×42mm) – fits anywhere, drives any bookshelf speakers with ease.
Next-Gen Bluetooth 5.4
Latest QCC3084 chip supports SBC/AAC/aptX/aptX-LL/LDAC – lossless wireless audio up to 24bit/96kHz. Yes, LDAC included!
Premium DAC & Amp Combo
• Dual ACM8816 GaN amplifier chips – pure, efficient power
• AK4118AEQ receiver chip – studio-grade digital audio decoding
• THD: 0.02% | SNR: 108dB – audiophile-level clarity
4 Inputs, Unlimited Sources
• OPT Optical | COAX Coaxial | USB | Bluetooth 5.4
• Optical/Coaxial: up to 24bit/192kHz
• USB: PCM 24bit/96kHz
Keeping an eye on this because I've not seen an amp based on these new GaN Chinese chips until now.
A shame it doesn't have analog inputs. They probably intend the amp to work out of the box as-is, no DACs required. At least BT is QCC-based and supports LDAC.
300w on a qfn48 package with nearly only heat relief a pad that is like 1/3 of the footprint. Now we are talking. I wouldn't use leaded solder with this one :D
WTH, they sell the bare board for 1/2 the price of the D816 too
Hi amigos,
YJCO D816
SPEC :
SINAD below 80db.
Post filter feedback or open loop, frequency dependent frequency response?
Wonder how they sound compared to classic PCM to PWM amps like TACT and Panasonic SA-XR series using digital input. I do hope these amps sound good/decent..
Using their advertised specs of SNR 108 dB and THD of 0.02%, calculated SINAD would be 74dB :)
We've seen time and time again that these GaN amps provide no benefit versus traditional ones. It's just a marketing buzzword.
The benefit is staying cool without heat sinks and fans. A GaN CPU would transform computers.
0.02% THD is pretty poor. That's about 74dB SINAD. Probably audibly fine, but no advantage except for output power over a TPA3255. No option for PFFB either.
I'd like to see a scenario where it is relatively easy for @amirm to use thermal imaging to measure the respective heat generated by an ACM8816 GaN chip and a TPA3255 chip.
At 1W, 1kHz, SNR 117 dB, total harmonic distortion plus noise (THD+N) is only 0.02%, noise level ≤ 100μVrms.
This is what I found on a Chinese website: https://xcsztech.com/?company/57.html
i saw an aliexpress link and now its gone lol
I think they are around $140 usd which is ok for what you are getting but these just do not have the refinement of the tpa3255
i would not buy a one box solution because you know things are going to age badly
i would prefer the BRZ dual tpa3255 thing and *some* kind of upstream dac
I finally found some measurements. Let's be honest: GaN amps aren't revolutionary—at least not yet. In my opinion, we'll have to wait a bit longer to see this type of amp deliver performance worthy of a well-implemented TPA325X.
It's pretty cool to see that the frequency response is not dependent on the load...
See attached file
In my humble opinion, a conventional amplifier based on GaN transistor technology—featuring an analog topology and fully balanced inputs would be preferable to a GaN "chip amp" with digital inputs.
It is clear that the ACM8816 chip appears to be the limiting factor here.
Incidentally, if you take a look at the Orchard Audio module—which is based on a classic topology—you’ll see superb performance.
Checkout measurements :
