Yesterday I finally made brief measurements of my FiiO Level 1.
Analog RCA labelled as "PRE OUT" were measured.
Perhaps in the future I will also test the speaker outputs and coaxial input, but first I need to assemble a dummy load and appropriate cables.
Test conditions:
Volume knob at maximum position.
Bass and Treble knobs at center position, however they seem to don't have any effect on "PRE OUT" and works with speaker output only.
PEQ works both on preamp and speaker outputs.
Maximum Line In level: 1.5 V RMS
Maximum Pre Out level:
2.9 V RMS for 1.5 V RMS analog line input
2.9 V RMS for 0 dBFS Bluetooth
2.6 V RMS for 0 dBFS USB
Digital part of the device looks like a complete disaster.
USB Input to PRE OUT
First of all, USB DAC losses linearity above -3 dBFS. All signals between -3 and 0 dBFS produces exactly the same output.
1 kHz FFT at -3 dBFS
A SINAD of 70 dB is an average or even poor result, but just look at how terrible skirts of the 1 kHz test signal look. This indicates serious issues with internal clock.
Jitter test is one of the worst which I ever seen.
The problem occurred at both 44.1 kHz and 48 kHz sampling rates.
J-Test 24 bit / 44.1 kHz
J-Test 24 bit / 48 kHz
Interestingly, when measuring the FFT at 10 kHz, I managed to capture the moment of "stable" measurement by using short 32k FFT without any averaging:
but usually it looked equally bad like previous measurements:
31 multitone FFT
