New Fiio Jade Audio Level 1 TPA3255 amplifier with DAC, PEQ, sub-out, BT 6.0 LDAC
Okay, I finally hooked the Level 1 up and I must say, it does definitely sound better than what I was used to (Sony TA-S7 and Sony TA-FE320R).
There's only one thing and that is that the Level 1 feels like it's missing a certain part of the spectrum in the low frequencies (sub 24Hz it starts to struggle it seems but I'm not sure if the limit is imposed by the amp or my speakers). Or maybe it just sounds cleaner which causes me to notice some things more clearly. Maybe the Sony TA-FE320R masked or blended certain parts of the low frequency spectrum. I don't have appropriate gear to test this, all I can say is that I'm impressed. It feels like the Sony TA-FE320R is just a lot more bassy even though the bass and treble was turned to a neutral position on it. But the bass didn't sound better on the Sony, it feels like it was mainly just delivering too much bass. I have to find a way to get more bass into the playback without killing the stereo image.
First things I notice:
- I had to move my speakers around a bit as imperfect alignment is a lot more pronounced now
- The stereo spectrum sounds much wider
- The music seems to reach 'further' into my room and sounds more balanced even when not sitting in the perfect spot
(two Magnat Monitor Supreme 1000 floorstanding speakers, spaced out in front of me to form a triangle with 2m edges between my head and each speaker, and enough space behind each speaker since they are bass reflex)
- Cleaner details, each sound in a song seems to claim more space
- When playing music on a quieter level, it doesn't sound as good as when I raise the volume a little (the ideal volume is having the volume knob pointing 'west')
I have played a bit with the bass and treble knobs but decided on leaving treble on neutral and bass on around '+4'. I'm playing the music through the USB C connection from my PC. It's time to check out some EQ. Not sure if I'm going to use the app with parametric EQ as I prefer to change these things in a way that is future proof (for example, imagine that the app some day stops working and I won't be able to adjust PEQ anymore).
After half an hour of playing, the case gets warm but not hot.
As you might see I'm not that familiar with the correct terms and most observations are very subjective. All I can say is that this amp makes my speakers feel like they doubled in value hahaha.
I'd echo your thoughts after a week with the Level 1. Not science here, but my 80's Linn speakers are on the dull and mushy side by today's standards, but now they sound more punchy, bright and fun. Unit looks great with my PiCorePlayer w/ green OLED, Modi 3+... little silver stack. Hoping someone with a measurement bench gets to this one.
Hood to hear! Does your unit also have a volume knob that has a bit of free turn? On mine it turns a little before actually adjusting the volume because of this. Which makes it harder to make small adjustments to the volume manually.
No, it's does not have any lag, play, or wobble at all honestly. I just double-checked to be sure. I did notice some random clicks and pops using bluetooth, which is not my normal use... I use the Pi streamer and Modi 3+, RCA normally. The pops went away when I slightly lowered the Volume in the control app. They weren't synchronous with clipping peaks, just totally random and super annoying. But the bluetooth volume fix seems to stick at that slightly lower spot after power down.
Okay, thanks for confirming. The seller told me that they contacted FIIO and that they claimed this was normal.
I might ask for a replacement because the free movement feels really iffy.
I also noticed signal loss with the Bluetooth connection. At first I thought it was in the music but I skipped back and it definitely wasn't there when I replayed that part.
Vintage vibes, Small Size and some practically useful features
This is one good looking amplifier.
This is really this small comparison to what it is making sing at the moment:
They have done few things smartly:
- Volume Knob also function to change input (quick press)
- Fiio Control app also has input selector
- LED behind volume knob isn't just for decor, different colors indicate different inputs and BT codec in use
- Bass & Treble knobs has center detent, makes it easy to set to bypass (or zero)
- All pots have very smooth operation, feels good quality
- Fiio Control app has volume limit function
- 31-band PEQ could be setup with Fiio Control app, can be applied to stereo (both channels) only
- LED could be disabled with Fiio Control app, if it bothers
Quick look at Fiio Control App run through
31-band PEQ Settings on Fiio Control App (stereo only, no L/R individual settings)
Stock Power Supply - look at the safely certs
This amplifier does support more powerful PSU:
Idle Power Comsumption
I have it hooked up with Mofi Sourcepoint 8 speakers with 48v/10a PSU.
Idle: 9 watts
Running to slightly louder than my usual levels, I see it jumping to 10 - 11 watts with some bass heavy tracks.
Thermals
There aren't any vents/holes in the case for ventilation, but still the bottom plate is slightly warm in use so far.
Hiss, Noise, Pop
- No hiss/noise on speakers on full power
- No pop on power on/off
- It takes a second to power UP after power toggle turned ON, most likely delayed power on/off operation
USB C input allowed me to connect it directly to nVidia Shield Pro
and... so far, so good!
I will check on SW and pre-out over the weekend.
P.E.
Some more Measured Parameters:
Gain: 29dB
SW Out Max: 2 V, variable with volume control knob
Pre-Out Max: 1.52 V, variable with volume control knob
Enjoy.....
Hi there Guddu, I bought one of these last week and when I turn mine off it pops. Can you please tell me if you follow a specific set of power-down steps to stop it popping? Happens for me regardless of:
- volume being at zero
- how long it has been turned on
- how long nothing has been playing
- whether there's an input cable physically connected or not, or
- which input is selected
I looked in the app to see if there was a firmware update, but the app says I'm on the latest.
Thanks
Thanks
Hi there,
My unit didn’t have any power on/off pop, I never followed any specific sequence really.
My unit was on ver1.1 and worked perfectly until I gave it away for community pool area.
Does your unit has a minor or faint pop on turn off or loud?
Hi there,
Hi Guddu, thanks for getting back to me! The pop is relatively minor but I'm concerned it's bad for my speakers (I'm not wise enough in the ways of audio to know how to assess whether it's a problem) and also don't want to connect my sub via High-level because I don't want to have to power the sub off manually (It's the amp on my computer desk - so too much effort)
Minor faint should not be an issue but personally I would avoid it in such state with expensive speakers.
Unfortunately it is quite common with most cheaper class D amps.
In this youtube video here the reviewer claims the internal DAC is "muddier" then when using an external one with the Level 1! (which I find hard to believe)
I assume owners here have had no sound quality issues with the digital input?
I never had such impression.
I suspect like often is the case, the reviewer see a basic DAC his brain already has decided it sounds inferior
People hi :D
The problem is that, nowadays, various DAC chips have reached such high measured performance levels that even a trained human ear could not distinguish between them—provided their integration with the surrounding circuitry is well executed.
Any audible differentiation (really just very subtle "nuances") depends entirely on the components in the preceding audio circuitry and the designer's attention to the power supply noise levels for the entire assembly.
Such differentiation is only possible if all necessary precautions are taken to ensure proper testing conditions (identical output levels, etc.).
In reality, there are no good or bad DAC chips—only poor implementations.
That is precisely what can, in some cases, be revealed by Amirm's reviews ;)
I ended up sending my unit back to the seller. The free movement in the volume knob made it very difficult to make small adjustments to the volume as it first always spun a little before engaging the actual potmeter. This, combines with a Bluetooth connection that displayed pops and cracks about once per minute annoyed me enough to send it back.
The Level 1 did have a great sound to it when connected over USB C, it also didn't run hot at all with the 48V 5A PSU, and of course it looked really good.
My quest continues. Next up I might be looking at the O-Noorus amps, though I read the D4 Pro had issues with heating up in one review. So I'm hesitant.
This might be their attempt to PFFB but not 100% sure.
Pre-Out frequency sweep looks pretty fine to me, less than -0.5dB between 10-15K and -1dB at 20K should not be anything to be worried about.
But again, this is for its pre-out.
Thanks for your measurements. Where did they hide the Bluetooth antenna with all the metal in the chassis?
Assuming a replacement does not a free movement on volume is the reason to return it your BT issues?
I've had no issues with BT on my K13 R2R including using LDAC but its a different chipset
NB: I'm eagerly waiting for see the forthcoming Level 2 specs and pictures to be released
Heh, I'm guessing that'll probably be my review with the temps. Don't get me wrong, I like the D4 Pro's feature set and have it hooked up to the DX 1 ii, and the heat is not a hard thing to mitigate. The company rep (owner?) has just replied that the casing is directly coupled to the chip, so just a simple usb fan to create airflow will be sufficient.
I am intrigued, it has the exact look and functionality I need. I hope they send it to Amir for a test-drive.
Had my level one for a while now and using it as a power amp through my very good passive pre amp and my also very good external Dac the level one amp is excellent.
