New Evo 5 Wharfedale series
I like surprises, good ones, would this be a good one?
Cannot tell you as it is vastly dependent on the room, the listening setup and your expectations. Have no experience with this particular generation of Wharfedale speakers, but I remember some predecessors to be showing the typical character of AMT tweeters with highlighted brilliance band (3-6K), while KEF models typically tend to be in general pretty recessed in this frequency band in their off-axis response.
In all my years in and out of hifi I don't have much experience with different speakers.
I've tried lot of amps and quite a few Dacs, but not speakers, mainly because they are not as easy to move around or return if you don't like them.
Looks like I might have to do this with the Evo 5s thought.
You can get a flavour of my room from my profile picture.12ft wide 17ft long..
AMT tweeters seem to be a marmite product, some love them, others don't.
Like you say though only way to find out if they suit me is get them in my room with my gear.
If and when I do, I'll be sure to post my findings on here.
Only subjective reviews for now.
Frequency response – on-axis (red) and vertically at an angle of 30° below the axis (yellow) and 30° above the tweeter axis (green)
Looks better than the Evo 4.4 measurements from the same website:
Thanks so much for the links.
It's also difficult to try these, so it seems more feasible to buy online, try them out, and return them if you don't like them.
So far, I've bought a pair of Monitor Audio Studio 89s and am trying them out. They seem very good.
How did you like these speakers? Do they have a great soundstage? What do you like? What do you not like?
@fordda
Hi.I have to say the speakers are excellent. I'm using a pair of Kef R3s.The soundstage is very good, they have a very open soundstage, and I have to say the bass is terrific!!! I didn't imagine two small mid-woofers could have such a full-bodied bass.I have to say I had to get used to the ribbon tweeter. It has a completely different response than the classic silk dome (or other materials). It has a more "material" high-frequency reproduction, especially on wind instruments. It gives a sensation of vibration when listening to flutes or trumpets; it's a difficult sensation to explain.What don't I like? Nothing at the moment, maybe, but don't take it seriously. The midrange could be a little more forward (I used to have a Kef R3), but vocals are excellent, so it's probably just my misconception or the amplifier I used.I'll add that I tried them with an Arcam A25, and it was with that amplifier that I had that feeling in the mids. I then connected them to a Nuprime Ida-9 and it was the opposite: the mid-high range was too prominent and became tiring after a while (I returned the Nuprime).Aesthetically, they're very beautiful.Now I don't know which amplifier to pair them with. I was considering the new Arcam A25+ or a Roksan Caspian M2/Exposure 3510/or going back to the NAD 399 I had three years ago.Regarding the Monitor Audio Studio 89 speakers, I can only recommend them, but keep in mind that I paid €1390 for them (around €2500 is too much).Let me know about anything else.Best regards.
@fordda
Thanks for this. I am a bit confused in your response as to what is describing the audio studio 89 or r3. Do you prefer the r3 or studio 89? Have you tried the studio 89 within 12 inches from a wall? If so did it affect the sound much?
Hello, I am interested in the 5.3. Due to my room, I have a mobile listening position. And I look for speakers with good dispersion abilities. Are these a good option in that sense? I listen mainly to rock music. My other choices are Fyne 501E or 501s
They would have to be at 30 cm from the rear wall, is that an option for the 5.3?
@fordda
How is the sound outside of the sweet spot?
Measurements look like the ribbon driver spreads very narrow
Bought a pair of evo 5.2 with a discount because of customer return. The tweeter is physically quite high on a 58 cm stand. So before I continue I have to score some smaller stands. To be continued
So far, This is the first book shelf I had to high pass at 100 Hz. The cabinets are literary trembling on higer volumes if I don't. Also, pointing them on axis for decent soundstage is eminent otherwise it collapses rather quikly. The 250 watt ncore amp is more suitable than the equivalent powered but less transparent class A/B amp ( here comes the tomatoes). Room correction shows mostly high Q factors. The comparable priced MA silver 100 isn't this picky in positioning and the Kef R3 non meta coaxial design is a totally different experience but more testing needs to be performed.
Packaging is good and because of the weight, I presume, each speaker is boxed seperately. Just you know.
Reactions: XDM
I own the Wharfedale 5.2 EVO speakers, use them as L/R fronts in my 5.1 home theater system. I upgraded my entire home theater system about 4 months ago. I had to match the 5.2 EVOs with a Polk XT-35 Center due to space limitations. Surrounds = Wharfedale 12.1 Diamonds and an SVS SB-1000 sub. Everything is driven by a Marantz Cinema60 HTR.
I'm happy with the 5.2 EVO speakers--certainly an improvement over my harsh Yamaha NS-A636 fronts (also big bookshelf 3-way speakers). I'd describe the EVO 5.2 set as "warm" if that's what you're looking for. I originally set the front crossover at 60 Hz, since the EVOs can handle low frequencies down to the mid-40s. But they were making a big thumping sound when playing Resident Evil: Requiem on the PS5. So I bumped up the front crossover to 80 Hz to match the surrounds, much better performance. Get the handsome walnut set, your wife will appreciate it, lol.
Update: I bought the Wharfedale EVO 5.C center speaker to match my Wharfedale EVO 5.2 fronts. I assumed previous LFE distortion was caused by my Polk XT-35 center. I also have Wharfedale Diamonds 12.1 as surrounds and an SVS SB-1000 sub to complete my 5.1 home theater. A Marantz Cinema60 HTR drives the system.
After using multiple sources—Roku 4K Ultra / Panasonic Blu-ray / PS5, I eventually had to bump the crossover on the Wharfedales to 110 Hz to avoid the thumping/trembling that Romario mentions in his post. This is disappointing for sure. My sub filter is set at 120 Hz. Even with these settings, I often need to adjust volume to avoid LFE distortion. A good LFE test is the 2022 horror film Barbarian, directed by Zach Cregger. I streamed this film via HBO with ATMOS. Around the film’s 30 minute mark, Tess discovers the basement's hidden doorway/passage. Heavy LFE for the next few minutes—a rapid thumping representing Tess’ terrified heartbeat. My system absolutely failed this test, the LFE distorting horribly. That’s when I bumped the crossover and turned down the sub a few DBs. I’ll probably keep these speakers, I’m 4 months in on the 6 month Crutchfield warranty. But I cannot recommend.
If you turned down the sub and it solved the problem then couldn't the subwoofer be the one distorting the sound?
"Turning down the sub" did not solve the problem. Distortion is primarily coming from the front speakers--not the sub. Bumping up the crossover helped some. Check Romario's post #30 in this thread, he had to do the same thing. The EVO 5.2 speakers should be able to handle an 80 Hz crossover which is standard on most systems.
It's quite disappointing when you have to bump up the crossover for speakers in this price range.
Can you share if you are doing any of the following:
A) bi amping the speakers using the same amp
B) running room correction with bass boosts
C) enabled Lfe to be rerouted to mains speakers (LFE+Mains setting)
I have had issues with my Evo 4.2s but it turned out to be related to the room correction boost I was requesting rather than anything wrong with the speaker.
Also, what’s your listening volume in SPL and your listening distance?
I'm not doing A/B/C. My listening distance is approx 10 feet from the L-C-R front speakers. Typical volume is between -20 to -15 dB, which seems to be a common listening volume for home theater.
The main issue with the room is a large mirror behind my couch. But I didn't have these distortion issues with my old Yamaha NS-A636 speakers, which were large 3-way bookshelf speakers, about the same size as the EVO 5.2 set. I had those old Yamahas set with a default 80 Hz crossover. My next step is to try the Marantz Audyssey audio set up.
I think that’s what your volume control displays. That’s nothing to do with how loud you are listening. The question was SPL, that’s sound pressure level, which you can measure with a smartphone app amongst others.
One additional note here: if you're considering the Wharfedale EVO 5.2 set for music, then I can recommend--they're actually quite enjoyable. Definitely better than the harsh Yamaha NS set they replaced. Even when playing Blu-ray Audio/DTS-HD 5.1 or DVD-Audio/Dolby Digital 5.1, the EVO speakers perform well. Examples: on Blu-ray/DTS-HD--Beatles Abbey Road & Sgt Pepper; on DVD-Audio/Dolby Digital--Fleetwood Mac Rumours and Talking Heads Fear of Music. All sound excellent.
I think the problem is home theater LFE. I'm currently in the process of setting up the Marantz Audyssey config. I'll post again in a few days after the Audyssey setup.
I heard these briefly at the UK NWAS and thought they sounded pretty good
So much so I've arranged a demo at my local dealer.
I report back when I've had the demo.
I didn’t get to demo these, the reason being the dealer only had boxed stock in the warehouse and didn’t want to open the boxes for a demo.
Update2: Marantz Cinema60 Audyssey fixed my LFE issues. Embarrassing to admit, but it’s truth-telling time now. The easiest way to convey what happened is to post my original settings and then the updated Audyssey settings. Note on settings below: 0 dB is the Cinema60 default speaker level. I manually bumped the center +2 dB for clearer dialog; manually lowered the sub -2 dB due to LFE distortion. Also manually bumped the crossover way up from default 80 Hz to 110 Hz due to LFE distortion.
Speaker levels before Audyssey Config: Left/Right = 0 dB, Center = +2 dB, Surround = 0 dB, Sub = -2 dB.
Crossover settings before Audyssey Config: 110 Hz for all speakers.
Audyssey Config Process:
1. Made my living room as quiet as possible: turned off the AC, turned off the ceiling fan, and turned off my cell.
2. Attached the Cinema60 microphone to a quality tripod that I bought for my binoculars. Didn’t bother with the ridiculous cardboard tripod that comes with the receiver. I set the tripod height at ear-level in my primary listening position, then plugged in the mic cable to the Cinema60’s mic jack.
3. Started the Audyssey config, and it requests that I turn my sub down to 30% volume. I have an SVS SB-1000 sub, which doesn’t have a volume knob. So I download the SVS app to my phone. My sub’s default setting was approx 90% volume (-10 dB). So I drop the sub way down to approx 30% volume (-37 dB).
4. Audyssey transmits multiple beeping, echoing audio signals to all my speakers—it reminded me of Close Encounters.
5. Audyssey offered to config 8 different positions in the room, but I stop after 3 positions. I’ve never had 8 people in my living room.
Speaker levels after Audyssey Config: Left/Right= -2.5 dB, Center= +2 dB, Surround = -0.5 dB, Sub = +12 dB
Crossover settings after Audyssey Config: Left/Right/Center = Full Range; Surround = 40 Hz
To summarize: Audyssey turned my sub down to 30%, then added +12 dB via receiver. Cumulatively this sets the sub level to approx 50% (-37 dB + 12 dB = -25 dB). Sub level is still way lower than my original 90% setting (-10 dB). It also dropped my fronts -2.5 dB and a slight drop on surrounds -0.5 dB. It kept my center setting at +2 dB (at least I got one thing right). Crossover settings are wildly different.
Things sound dramatically better post-Audyssey, no more LFE distortion. Replayed the Barbarian basement scene, streamed Sinners on HBO, played a few hours of Resident Evil: Requiem on PS5. Watched Prometheus Blu-ray disc via Panasonic Blu-ray player. Wharfedale EVO 5.2 fronts now perform well on all sources, getting solid LFE without distortion. Lesson learned: use whatever room correction config that comes with your receiver. Don’t use manual settings unless you really know what you’re doing.
