If we add more cooling the unit should be available to produce more. If the OP specs are correct, and I think they are, the module is a dual TP3255 operating in dual mono, so each chip should be able to produce 600 W at 53V when fed 2 V. Those are the limits of the chip, so in theory, if properly implemented, the board could be able to 600W x2, therefore the claims of 300W, depending on cooling and power, are feasible.Would be good to see it measured.
150w/8 300w/4 and 600w/2 ohm. Can it actually produce this?
I accept that it would not be an audible improvement. Lower operating temps are good enough for me. To each his own.Yes. But you would not hear any improvement. If you think you will, then please provide us with files for a DBT.
I mesured this module with E-MU 0404, on the photo is simple SE-BAL converter and module is after some mods but measurements are made without converter and both before and after mods. Direct balanced signal from E-MU, PSU TDK-Lambda 39V, dummy load 6,8Ohm, power approx. 6W.
Sorry for the mess.
Oryginal module, 6W load, 39V supply:
Moded. Replaced opamps with OPA1656, green Nichicon caps with sandwich C0G(NP0), power caps with low esr Nichicon, inductors with Sagami 7g17a-100:
How do you like this one? There are so many TPA3255 modules out there these days. I recently picked up this exact one along with its single-ended-to-balanced module. I’m really keen to try out the OPA1656 with it, but my usual buying channels are just flooded with fakes.I mesured this module with E-MU 0404, on the photo is simple SE-BAL converter and module is after some mods but measurements are made without converter and both before and after mods. Direct balanced signal from E-MU, PSU TDK-Lambda 39V, dummy load 6,8Ohm, power approx. 6W.
Sorry for the mess.
I think it was caused by the adapter SOIC-DIP8 and inadequate decoupling. Finally I installed OPA2134 in DIP8 package, but I didn't measure it.It seems that the second configuration is worse, despite the "better" components. Is it the OPA 1656 working out of optimal conditions, or what else could be the reason?
I picked this module specifically because it has dual TPA3255s with PFFB. The seller recommended adding a preamp, since implementing PFFB lowers the overall gain. As for the volume, I haven't really noticed any issues so far—probably because I always listen at lower volumes anyway.I think it was caused by the adapter SOIC-DIP8 and inadequate decoupling. Finally I installed OPA2134 in DIP8 package, but I didn't measure it.
Nowadays it's the main amplifier in my 2-way active system. I doubt that as cheap part as OPA1656 could be faked, but everything is possible.
I am looking for reliable high quality ADAU1452 DSP based boards, ideally lots of I/O channels
ADAU1445/ ADAU1466/ ADAU1467 even better if FIR required
With enclosure available would be nice.
I don't mind the amp chips being built in, but must be preamp-out as well if some channels need moar Watts.
3e Audio? Tinysine?
Actual purchase links would be appreciated
Thanks. With only 4 outputs I think I'd need BNC clocking to avoid clock drift messing with phase alignment.What about the York DSP 2x4 Link?
Hi! I saw you disassembled this power supply.Speaking of PSU, I made a great discovery at a rather reasonable price. (68€]
Check here (48V / 40A 2000W Single Rail version)
Nice PSU, built using an LLC resonant circuit design with high-quality components. Excellent circuit design. Compact, modern (pfc + llc). On the secondary side, A synchronous rectifier with 4 mosfets (150 v) instead of diodes. On the primary side, 2 transistors from magnachip: mdr60r037jf (37 mω, 70–80 a). The brain of the system is the kpe2592bsg chip—a specialized “2-in-1” combined controller that integrates control of the pfc (power factor corrector) and llc (resonant converter). The voltage range of 39–59.5 v is great.
In this review the sinad is 86. In your test it is 92. This is a huge difference.Here is test data for A07 Max at ~ 35 watts. Same caveats regarding power line noise and aliasing noise. Ignore them. This is very good performance.
www.audiosciencereview.com
