New desktop speakers setup — looking for recommendations
JasonFilan
Hi everyone,
I'm a newcomer to the forum and would love to get your objective feedback and recommendations!
I'm looking to set up a new active desktop speaker system along with the necessary upstream chain. Below are the details regarding my current gear, listening habits, and room environment:
1. Upstream Gear & Volume Control​
  • Current DAC: SMSL D3 (an R2R DAC). I mainly use it paired with a GA10 to drive my HIFIMAN HE1000-Unveiled. However, the D3 does not have a built-in pre-amp / volume control.
  • Volume Control: If I transition to active monitors, I'll need a way to control volume. I'm currently looking at a passive monitor controller—specifically the Heritage Audio Baby RAM (or similar stepped attenuator). Do you think this is a reasonable match, or would you recommend an active controller / another interface?
  • R2R vs. Modern Delta-Sigma: I know most people running active studio monitors use clean Delta-Sigma DACs or dedicated pro-audio interfaces (like a Native Instruments Komplete Audio 6 MK2). Given ASR's focus on transparency, would sticking with the SMSL D3 be fine, or should I just switch to an interface/balanced DS DAC with built-in volume control? Ideally, I'd like to make good use of the D3 if it doesn't compromise the setup.
2. Prior Experience & Monitor Shortlist​
  • Past Setup: I used a pair of KEF LSX II for about two years and recently sold them. While convenient, over time I experienced some listening fatigue, especially with higher frequencies and sibilance. I primarily listen to vocal and pop tracks and prefer a smooth, neutral signature without harsh treble or boomy, overpowering bass.
  • Subwoofer: I do not plan to add a subwoofer anytime soon.
  • Budget: Around $1,200 USD (for the pair).
  • Candidates on my radar:
    • Neumann KH 120 II: Currently my top contender. I like the built-in DSP engine, and renting/borrowing a Neumann MA 1 mic for automated room calibration seems like a huge plus. (Note: Might slightly exceed the budget unless found on deal/used, but strongly considering).
    • Genelec 8030C
    • Kali Audio LP-UNF / IN-UNF /Adam D3V / iLoud MTM MKII
3. Room & Desktop Acoustic Challenges​
  • Room Setup: My desk is placed in a rectangular living room (just under 30 m² / ~320 sq ft). The room is completely untreated—hard floors, no rugs, and bare walls.
  • Resonance & Neighbors: When I pushed the volume slightly on the KEF LSX II, the downstairs neighbor complained. I suspect the issue is either severe low-frequency room modes or mechanical vibration coupling through the desk into the floor structure.
  • Acoustics Question: Since extensive room treatment isn't an option right now, what simple, practical steps would you suggest? (e.g., isolation pads/stands like IsoAcoustics, adding a rug, DSP/EQ bass nulling/shelving, etc.)
P.s.If I cut the budget to 800 dollars, which one would be preferred? And the photo of my desk is attached below, you can see the space for speakers is little.
Thanks in advance for your insights!
at least in my case the IK-multimedia sub was a game changer. (used with ADAM D3V)
will passives be something you'd consider?
Probably not a significant audible difference, though if you are buying, I'd go for modern Dalta-Sigma for absolute transparency.
And on that basis - for the price of that volume control (for which you need to worry about input and output impedance ranges), you could get a new DAC with built-in preamp/volume control. So that is the way I would go.
I'd just ask why not go with the Neumann or Genelec at your budget level?
Answering my own question: Ascilab offers some decent passive options in that price range, but otherwise?
As for bass annoying the neighbors, my rule of thumb is to turn the subs off (or turn down the volume / bass) after dark.
PEQ to knock down peaks and a rug should also help, but there isn't a lot you can do about bass traveling through walls without drastic measures.
Thank u so much! Like SMSL D2R? But, it's a little expensive, so any recommendation for DAC with built-in preamp/volume control?
我只想问,在你的预算范围内,为什么不选择 Neumann 或 Genelec 呢?
我自己回答一下:Ascilab 在这个价位上提供了一些不错的被动式期权,但除此之外呢?
至于低音炮会打扰邻居的问题,我的经验法则是天黑后关掉低音炮(或调低音量/低音)。
PEQ 可以降低峰值,铺地毯也有帮助,但如果不采取激烈的措施,对于低音穿过墙壁传播的问题,你几乎无能为力。
Ok, I would have a try, thanks!
You seem to like SMSL - how about the D100 or D200
Hi everyone,
    • Genelec 8030C
Postpone the desktop speakers for now and get a larger monitor.
Doesn't the Kali IN-8 fit within a $1200 budget? A coaxial driver should perform better at close range—that’s actually how I use them at my computer desk. The sound issues with the KEF LSX II might have been due to the room itself.
https://pmc.ncbi.nlm.nih.gov/articles/PMC11267622/. According to it, "The best localization performance in terms of elevation is of the order of 4–5 degrees." For instance, someone mentioned the Neumann KH120 II earlier; the distance between its drivers is—by my estimation—(130+25)/2 + 35 = 112.5 mm, which corresponds to a distance of approximately 1.61 meters for a 4-degree angle.
if I haven't made any mistakes anywhere
