Waveguides aren't everything
They tend to be if you want good DI.
I wonder also, if a passive notch above 20k would be beneficial for dampening the influence of breakup and resonances that may cause intermodulation distortion. Similar to what you did with your signature speaker build, or the purifi app note.This means if needed, you can passively shape response to a minor loss and still have plenty of output. This may be beneficial, as a small dip centered around 2k could be of benefit, looking at the CSD and spectrograms.
No, it just makes it easier to get a decent DI.
I don't find the sensitivity that high: it may be around 93 dB/m at 2.83 V, but that's a 4-ohm driver. The conclusion of the test at Hifi-Selbstbau states:and has high sensitivity in such a package.
Wegen des geringen Wirkungsgrades von 89 dB/W/m zeigen sich oberhalb von 105 dB thermische Kompressionseffekte
Due to the low efficiency of 89 dB/W/m, thermal compression effects occur above 105 dB.
If I use a dayton dsp amp board, I'd probably want to add some passive attenuation anyway, to reduce hiss.
I would have expected a little more from such a big monster of a dome tweeter.
I said I'd use passive attenuation/padding to reduce hiss and help smooth those breakup bits above 20khz. A DSP amp the way I would use it is only going to smooth out broad problems in a gentle way, preferably by attenuation. Really, the DSP will hopefully just allow me to prototype crossovers faster. I may still implement them with passive components. . . Either way, my desire to have a set of good dayton drivers I can just drop into a project and work with isn't looking so feasible now. All the marketing looks good, but it ends up sounding like the improvement from all this fancy RND and new material doesn't translate to huge benefit over, say, their inexpensive 25 dollar tweeters and woofers. . . Or maybe I'm an idiot *-shrugs-* This has been a lot to learn, and I'm not sure i've been learning it well~This also means that there are not too many reserves left for the following intention:
I'm interested, although maybe a different thread is necessary. I like the idea that I don't need a waveguide provided I choose drivers with plenty of overlap and solid directivity performance overall, with low order crossovers between them. Keep the baffle out of the way and poof. Solid starting point. Could a waveguide improve things? Probably. Might let you cross a tweeter a little lower or integrate better with whatever midrange, but as far as I understand things right now, it's a nice to have kind of item.I have some counter arguments but since I don't have cult of personality behind me like you, what I say doesn't really matter to anyone here ¯\_(ツ)_/¯
*-sigh-* I got all excited, hoping it would be a dome driver
This is more or less how I planned to dial in a mid dome; between 350-650hz to 2.5-3.5khz The lower I can cross it over, the better. But unfortunately DIYers report that's difficult... Meanwhile, measurements I've seen for the domes I'm looking at say it's passable. Passable with an asterisk. Not sure I'll be getting the low distortion specs I want, even using these products in their intended range.I used to be really interested in dome mids, then I tried to use them. Dispersion is just way too wide for anything other than very small bandwidth ala KH310's implementation.
