Glad to see someone implemented this in production, with Amir's blessing.It has always been like this, the old charts were also rated by percentile score. So I just copied that. The only difference is that in the old charts only the best values were shown, and right now I'm also showing values for other inputs/outputs when available. I agree that everything in blue and green probably sounds exactly the same if its a recommended product (might be other issues if its not).
You can set the color fields to be a quantized set of N (dis)similar colors, which would differ from Amir of course. Or a continuous band. Or remove color entirely, since the value it represents is on the chart already. (Said Edward Tufte.)
It is an embedded object so if your security level is too high, it may not show up. It works for my Chrome browser.WEIRD! When I go to
https://www.audiosciencereview.com/forum/index.php?pages/Audio_DAC_Performance_Index/ using my Chrome browser, I get a blank field.
Using Microsoft Edge - I get the chart. I wonder if some extension or setting in my Chrome browser is blocking the HTML for the chart?
I'm using Chrome and the web page opens and data is available.WEIRD! When I go to
Do you mind taking a screenshot of the type you mean?Given the number of items tested and the very small, unreadable type at the bottom of the chart...
I suggest a change in format from horizontal to vertical layout.
It's in here: https://www.audiosciencereview.com/forum/index.php?pages/Audio_Equipment_Reviews/ but not in the comparison chart. In almost all cases I haven't used the data generated by Amir's old analyzer to keep the comparisons accurate. A few times I used the output impedance numbers, and headphone power once.My Emotiva DC-1 was measured by @amirm back before the current Sinad ratings.
https://www.audiosciencereview.com/...surement-and-review-of-emotiva-dc-1-dac.2306/
Is there any way to incorporate this data into the newer listings?
TIA,
Sal
