New Buchardt Audio speaker
AM88
Seems Buchardt Audio has a new active speaker with master tunings and dsp which allows cardiod dispersion. It seems to be on the small side so hopefully their cheapest cardiod speaker.
A200 is the model. I couldn’t see any info on the website yet but they posted it on instagram.
No measurements, although preorders start tomorrow.
From the pictures it appears they are using the same amplifier that they've used with all their other active loudspeakers. This is unfortunate as they are about to launch a new amp module that includes spdif connections and upgraded amplification. It must have been done like this to meet whatever price point it will sell for, but it makes a brand new product seem dated on launch.
Some more information to be gleaned on the website now that pre-ordering is happening. Took notice of this tidbit "22hz -3dB at max 95dB SPL for one speaker at one meter (pink noise)".
Thanks for posting this. On first glance it's slightly smaller than the Anniversary 10, and yeah, intended for genuine bookshelf use if you don't have room for a speaker on a stand. Looking forward to reviews!
Interesting that the sound power line looks like that, since they have quite a waveguide on the thing, you would think it could be smoother / more continuous. Seems maybe intentional? It looks like the DI has 3 distinct segments. 0-1khz, 1-3khz, and >3khz.
Very impressive bass performance but I won't throw confetti until we also see the THD graph. :)
Yes, I don't expect this is a speaker unit that will play loud.
It's a small bookshelf that has a back driver and needs internal space for a Platin plate amp. Cardioid is also going to shave off some max SPL. It's going to be quite volume limited with the cardioid pattern, and slightly better without it.
Maybe they will also include a setting that cuts off anything below 50 Hz that will enable higher output.
In any case, I have no doubt there's a customer base for this speaker, but it's something to be aware of.
EDIT : Just noticed those are 5" not 6" woofers, and it's a 10 L (external) enclosure, very small indeed.
And also something else I've noticed, that's super useful at low volumes, which seems to be where those speakers excel.
Automatic ISO 226:2003 Compensation = Low Level Enhancement - LLE
It is well known and documented in research, that the perceived sound balance is dependent on the level at which sound is reproduced. Best example is that with traditional loudspeakers, when listening at quieter levels, there is very little experienced bass and treble reproduction, although at louder level the bass and treble is clearly present.
Don‘t see a (relevant) cardioid effect—please don‘t tell me that a 1dB gain elsewhere is useful. And we see a jump in directivity, once the tweeter takes over. And there is no increase toward the higher treble.
Directivity is overestimated deliberately, while the referring room reverberation (and coloration) is happily ignored. Not a system’s engineering approach. More like gear fandom?
Reactions: CD2
Apparently, the cardioid is showing full effect solely above 200Hz, so I would not overly worry about it limiting the max SPL. Frequency bands which really eat up power and demand excursion capabilities, are more or less omnidirectional. Similar to Kii Seven.
Signs of cardioid behavior are visible between 200 and 600Hz. It does not look like a textbook cardiod in terms of directivity index, though.
Intentional in the sense that they in general seem to prefer higher treble directivity? Maybe yes, but in this case even a mild cardioid design can help balancing the reverb tonality. If this works, solely a listening test can show.
If a speaker designer is not specifically aiming for constant directivity in the middle bands (as I would prefer), or in contrary going for a rollercoaster ride of narrowing and widening pattern with significant steps, I would ignore calls for ´smooth´, or ´continuous´ directivity. Reverb tonality and resulting imaging effects are not perceived as deviations from a straight line in the graph, we rather hear differences in level between octave-broad or broader bands.
Correct me if I'm wrong, to me, I interpret the directivity as not that good and that it won't take well to EQ. I noticed that Kef speakers for example, tend to have smoother directivity that these. I know I'm not comparing apples to apples, I'm thinking of the context of EQ-ability.
Reactions: CD2
Would agree that it does not look ideal, particularly for the overly narrow directivity 2...5K compared to the lower neighboring bands. If EQing could be successful, very much depends on room and listening distance. If the indirect sound level is in general recessed, there might be a good chance.
The bookshelf units I am aware of, tend to show a continuously, pretty steeply increasing directivity, combined with an almost omnidirectional pattern below the baffle step. Would say they are pretty difficult to EQ in a room, if not impossible in certain situations. Reason being, the midrange/lower midrange dominance over brillance and treble, is pretty audible in many rooms, and any attempt to bring the indirect soundfield into balance, would result in an audible kinked direct sound tonality showing dominant treble.
Would say any speaker with cardioid midrange is easier to EQ as there is little risk of having dominant midrange.
Reactions: CD2
How did they manage to have lower frequency extension with smaller woofer compared to A10 ?
Edit: And yes, I guess we need to wait for low frequency distortion graph...
Reactions: CD2
Thing is, it depends. Toole, if my recollection doesn‘t trick me, always emphasizes, that the reverberant sound field in-room is secondary to the direct field. The latter comes first. The reverberant field will follow, depending on many factors that interact in complicated ways, that are not yet ready for evaluation. The estimated, or predicted in-room response is calculated assuming a standard room regarding dimensions, size, frequency depending reflectivity, damping, listener distance, and what not.
To take a short-cut in taking the directivity chart once for all, comparing the lines for whatever feature is unscientific. There is not good reasoning behind such misinterpretation of data, it is just coarse at best.
O/k, REW makes it easy to „measure“ the grand total sound field, the steady state, all reverberation included, but, according to Toole, that‘s not what people, you also maybe, „hear“. REW is misleading, one might argue. Easy but wrong. Strong statement? Sure. Before you condemn my notice, please look-up the literature, and for starters the weighting of „estimated in-room reasponse“ in the Olive score.
On the other hand, the steep change in directivity at a somehow arbitrary freq/ won‘t be universally beneficial.
Ps, compare the REW measurement for different positions in the room. You will wonder, and stop taking the directivity charts too seriously.
I’m not a technical person, but doesn’t that graph show the frequency response of the A200 at only 55 dB?
That's actually very true which is pretty low but it also says @ 10m distance just as in the case of A10
