Follow-up to the previous post, with some useful technical information.
11 - PFFB circuit
12 - OC_ADJ & FREQ_ADJ resistors
Visual explanation of the previous two photos ->
13 - One channel OPAmp
On this photo I wrote an annotation specifying that the OPAmp is used as a 'buffer', which is partly true because it does not 'produce' any gain, however it is partly false because the capacitor (framed in green) located on the feedback circuit of the operational amplifier will directly condition the shape of the 'downward curve' in the high frequencies in connection with the components of the PFFB circuits.
When the latter is poorly 'calibrated' then this is partly an explanation for the 'rise' in high frequencies when an impedance (for example 8 Ohms, rather than 4) as we see on amplifiers which do not have PFFB circuits or which are poorly 'implemented'.
(Lester from SYLPH Audio had explained and demonstrated this to me through simulations as well as with a simulator using BODE diagrams when designing his modified D200 MK II PCB
14 - Line gain OPAmp (the one located next to the volume potentiometer)
I haven't had time to reverse-engineer the PCB yet, so I can't give you any more information at the moment...
15 - OPAmps supply voltages (Important point raised in the previous post)
I also took temperature readings from the top of the case—using a thermometer positioned 20 cm away—with the two different PSUs I had available.
The ambient temperature was 27°C with 49% humidity for the following two readings:
- Idle temperature with 36V DC 6A PSU (recorded after 4 hours)
- Idle temperature with 42V DC 7.5A PSU (recorded after 4 hours)
With this same power supply and my AIYIMA A70 stereo amplifier, the temperature under exactly the same conditions was 39.8°C.
It can already be objectively stated that the BRZHIFI PAD-30 amplifier (with two TPA3255 chips) runs cooler than the stereo AIYIMA A70 (with a single TPA3255 chip).
Subjectively, I have nothing to say about this amplifier that would distinguish it in any "glaring" way from other amplifiers of this type.
Nevertheless, the sense of available power—as well as the impact (if one can call it that) in the bass register—is truly noticeable (despite using a "simple" 42V DC 7.5A PSU).
For instance, when listening at close range (at my desk) with my speakers and the volume set to the "10 o'clock" position, the perceived sound pressure is almost on the verge of being unbearable; so, in my case, my choice of PSU is more than "sufficient."
Note: I should mention that in a previous post, I spoke about a 42V DC 8.5A power supply available from Audiophonics, but the unit I actually received was different. I informed them of this discrepancy and mentioned the publicity I had given them here, suggesting they respond to the thread—though they haven't done so (yet?). Their reply was that they hadn't been notified of the change made by their supplier; they offered me the choice of either returning the unit or keeping it in exchange for a €10 voucher.
Here is my small contribution to this topic, pending objective measurements of this amplifier.
See you soon, and happy reading on this forum
PS: @BRZHIFI ->
Could you make a DAC using the same chassis and dimensions—keeping it just as simple (no completely useless displays or LEDs, no MQA or Bluetooth)—featuring only RCA outputs, dual ES9039Q2M chips, 6 swappable op-amps for the audio output stage, a chip to handle a 10-band parametric EQ function, a robust and durable USB-B port, plus a simple "POWER" LED and a 3-position switch (ON/OFF/TRIGGER), all at an affordable price point so it pairs perfectly with this amplifier (I suggest the name DAD-30)?
With this amplifier (PAD-30), you really focused on the essentials, backed by what is clearly a masterful command of the technical aspects; a DAC sharing that same spirit would certainly be welcome—both for me and, I’m sure, for many of your other customers.
It would be a refreshing change from all those DACs loaded with complex features that are both useless and uninteresting... in addition to being exorbitantly expensive (justifiably so)
