New british Speaker, Wharfedale Denton 1S and Leak sandwich 100
Coaxial like kef Very stylish with the cover on, high waf (imho) if you have to have one Wife
- Sensitivity: 88 dB (2.83 V @ 1 m)
- Nominal impedance: 8 ohm
- Minimum impedance: 4.5 ohm
- Recommended amplifier power: 30–100 W
- Peak SPL: 95 dB
- Frequency response: 50 Hz–20 kHz (±3 dB)
- Bass extension: 45 Hz (-6 dB)
- Crossover frequency: 2.6 kHz
Leak Sandwich 100
Also very stylish with the covers on
Where i live Mission 750 is for some reason super expensive compared to the Leak Sandwich 100 but as good as the 2 mentioned speakers if you live in uk
How good are they and could the wharfdale be an alternative to Kef ls50 meta and non meta but cheaper ?
Difference between the Leak Sandwich 100 and Mission 750 besides the reversed tweeter ?
One thing that stands out is both do not go down to 4 ohm or lower (as goes for the Mission 750) but do get down in the mids of 4 ohm or closer to 5 ohm than 4.5 ohm, easier load than speakers i often se that go down to 4 ohm or lower, like my own wharfedale Diamond 12.1i (4.0 ohm, the old non i's are measured to be as low as 3.7 ohm)
- Peak SPL: 95 dB
Leak Sandwich 100
