I am asking about Outputs, not inputs.
the Amazon ad says those are INputs - where are you getting that as the Outputs?
Pics on the Belkin site show them as outputs.the Amazon ad says those are INputs - where are you getting that as the Outputs?
Thanks. I think you raised a good point. Historically I felt iTunes to HomePod stereo has been extremely flaky (even after HomePod got firmware upgrades); I previously attributed to bad experience partly to AirPlay 1 but maybe it was more due to HomePod. Let me try things like https://www.airserver.com/ and see how it works. If it works fine I can return the Belkin dongle.
Yup, you nailed it. As you intimated, the advantage of Airplay over something like Roon or Spotify Connect, is that any audio on the sending device can be streamed to the receiving device. It behaves similarly to Bluetooth in this regard, but at higher quality over WiFi.Based on some questions and statements here, some people do not understand Airplay.
For music, it is simple. On any iOS or MacOS device, you can send any audio from any app to an Airplay receiver via WiFi. Spotify, Tidal, Deezer, Web browsers, Apple Music, TuneIn, fart apps, whatever. The receiver can be any device with the Airplay royal jelly from Apple inside it. (Like Tidal Connect or Spotify Connect royal jelly) If Belkin slapped an amp on this thing, it would be an amp with Airplay. If Belkin slapped a HDTV on it, it would be an HDTV with Airplay.
So this device is for people with gear missing Airplay royal jelly. I use an old Airport Express on an old reciever. Same thing. Except the Express has a very nice but old AKM in it.
Airplay 2 adds multi room. In attached image, some are, but some are not. Unless!
As far as quality, for now it is 16/44.1 max. Which is most recorded music. However, June may hold some “improvements” now with Apple lossless on Apple Music.
I am in the 16/44.1 is all I ever want or need in PCM.
I got the Belkin today
Based on my limited experience with Airplay + Mac/iOS, I feel there were definitely more issues with Mac than with iOS in terms of integration with Airplay.I tried the same thing on iOS - loading a shared local iTunes music library in the Music app on my phone and routing the sound to the Belkin - and I did not get the same error. Everything worked. So the problem with the Belkin seems to be confined to shared libraries and Music / iTunes on macOS.
I placed an order today, planning to feed my Genelecs via its Optical.
7350A + 8330Ax2. I have a TOSLINK->AES converter.Which model Genelec ? feature TOSlink input?
