@amirm On the topic in the thread, what software would you recommend for analysis using an ADI-2 Pro (Fs)? I see most analysers have built in software, but I don't know the best software to use for a device that is not an analyser, just a really good AD/DA
I rather agree with Amir. All the software has its issues. If you don't mind a little manual work, you can test most things you want. Just not in a straightforward automated way.
Alan March likes Virtins Multi Instrument software.
https://www.virtins.com/multi-instrument.shtml
You can download a 21 day trial of it. I would read up on the documentation prior so you can make good use of your trial period. I found it capable, but still not quite my cup of tea.
I made up my own test signals in Audacity (Adobe Audition would work too). I usually run it thru Reaper which is DAW software. You can get Reaper free though you should pay for it if you use it. Honor system however. You can trial it forever. Once I've run the test signal and recorded it in Reaper I analyze the file mostly in Audacity though I sometimes use other software for this or that.
So to analyze something I have two wav files with various signals on them that last a few minutes each. One is near max level and the other is for low level signals. So I'd end up spending maybe 20 minutes connecting things, setting levels and running/recording the test files. Then I'd spend a while longer manually getting results for each type of specification of interest. You'll be able to get good results for most all of your usual specs this way.
You also can use REW for electronics testing for some purposes as it doesn't know the signal was never sent over a loudspeaker.
RMAA can be okay for basic testing. Somethings about it I don't quite like how it is done, but for comparative purposes it is usually consistent. It is the easiest and most automated of free or nearly free software. RMAA is free, but there is low cost paid version with some extra features. You might start playing around with it first.
If you'd like copies of test files I've made up I'd be glad to share them. Nothing special about them other than they already are done.
