Yes, but that means you are only limited at 1kHz and 10kHz with cosmos apu. It's fine, but you can't do a frequency sweep.
You can't with the AP either.
Sure. You can make a THD+N vs frequency or level sweep with the notch filter (aka. "precision sine analyzer") enabled, but it's THD
+N. Not THD. You can get the AP to plot THD vs frequency but as far as I can tell only with the chirp analyzer. And you can't enable the precision sine analyzer with the chirp, so you're stuck at the THD of its built-in ADC, which is good, but not the -148 dBc that you paid $40k for.
From what if sounds like, but I will let @tomchr confirm, he is trying to get a customized version that can do what the AP software can do, and it will be made specifically for this analyzer, either as additional cost or as part of the purchase.
Yes. I'll have software for it. I hope to be able to bake the price of the software into the cost of the analyzer, even if it means nudging the cost of the analyzer up a bit.
So he is intending for his customers to use somebody else’s analyzer software
Not entirely. I am giving you the option to use whichever software you like. That'll get you basically everything except auto-ranging on the I/Os. For the full functionality you'll need to use the software that I'll provide.
REW the author is John Mulcahy, so Neurochrome should change the name from “analyzer” to “high performance to audio interface” to avoid any further confusion in my opinion …
No I shouldn't. Because what I offer is not an audio interface. It's an audio analyzer. It has built-in attenuators/amplifiers to scale the I/Os properly. It also offers protection against over-voltage on the analog I/Os. It may work like a sound card, but marketing it as a sound card would cause even more confusion.
good luck with the EULA! and getting permission to bundle in a commercial product.
I've already talked to John. Leave that to us instead of creating drama here, please.
Virtins Multi-instrument is another option.
www.virtins.com
Virtins is Windoze-only, sadly.
What I have right now is a working prototype that's good enough for me to spend $5k for a booth at Axpona, travel, etc. to demo it. I'm trying my best not to over-promise and under-deliver. Please respect that.
So let's see the hard numbers when its all done.
Yeah. Let's.
Apx555 now starts at $40k!
Yep! And by the time you add the options I offer as standard in the NAx1, you're up to $58k. The NAx1 supports I2S and PDM standard. Those two options add $9570 and $6650, respectively, to the $40k analyzer. So for the price of the options alone you can buy about three NAx1s... Tradeoffs, tradeoffs. And AP doesn't do I2C. We do.
Tom
