Thanks for your reply and yoga blocks recommendation. I double checked and I do have enough space for the speakers.I have been completely satisfied with the sound of these speakers, however I note that you say "desktop". My one piece of advice is to look at the dimensions of the speakers. The old saying goes "there is no replacement for displacement" and these get quite low in the bass, but they get there with quite big cabinets. The desk space taken by each speaker is just a little bit larger than a standard 8.5"x11" letter sheet of paper, so make sure you have that much desk space to spare on either side of your monitor (if this is what you are implying with the word desktop). If you have the space I think you will enjoy the speakers.
I am using a pair of yoga blocks under each speaker as affordable speaker risers to get the tweeters up to ear height, depending on how high your desk is.
The listening distance would be 2.5 feet away. Would that be an issue with these speakers?
Also, was it difficult to build the speakers? What tools do I need? Did it come with any instructions?
