The old, ‘if you can’t hear the difference you have saved yourself a lot of money’ chestnut.
An oldie but still a goodie.
I definitely think that they will sound the same when properly level-matched and using the same filters and EQ settings. However, as you can see in that well written audioXpress article, I have evidence to support my claims. The writer of that article is very experienced in testing audio devices and neither he nor his two younger colleagues could distinguish the two tested DACs in sighted or blind tests. So currently, there's at least three people who listened to the D1 using proper controls who disagree with your impression.I have this RME DAC side-by-side with the D-1. If you think they sound the same, then you have saved yourself a lot of money. You do sound convincing in your post. However, I know better and really have to discount everything you have argued. That is OK.
I tend to repeat myself here, but without proper controls, any subjective listening impression is pretty much worthless. Your brain plays tricks on you. You can try it for yourself.The only reason I have the RME is because the D-1 does NOT do DoP on SPDIF. I was listening to this RME via the OTL/OCL preamp last night with some SACDs (DoP SPDIF). There is a lot missing in the sound, but it is not bad. How do I know it is not as resolving on DoP via SPDIF as it could be. I had the Meitner MA3i DAC side-by-side with the RME both doing DoP on SPDIF, and the MA3i was so much better that even a tone-deaf person could tell the difference.
The elephant in the room is the innocent-looking statement 'The level switching between the low and the high path is implemented well with less than 0.02 dB of error on the worst channel. '. That alone kills the monotonicity of the DAC. 0.02dB is like a huge bump or spike in linearity. Which, technically, was an absolutely expected fault. You cannot cut a <1nV resolution DAC in half and then splice the halves together again in analog fashion and still retain that 1nV step monotonicity.
I am pretty sure John LaGrue is aware of that, but he would also be aware that it would absolutely kill his business case.
Jan
Thank you for that.Hi Jan,
We're achieving a CLE (cross-fade linearity error) of 0.003dB in production, so the review unit may have an issue. Or perhaps the D-1 simply hit the limit of their measurement tools.
This is why we require a "calibration" cycle, to best align the low-path to the high-path. A CLE of 0.003dB is not measurable on our AP 2722 linearity plot.
That said, in our early blind studies of cross-fade error audibility, we found that the worst-case just noticeable difference was a pure tone (1kHz) at 0.9dB. Below 0.9dB, nobody could detect a cross-fade error. But that's just our internal testing with a few engineers. In a larger sampling, results would likely vary a bit. So, even at 0.02dB, that's almost two orders of magnitude below JND.
Should also note that with various kinds of common music program (pop, classical, jazz), our blind CLE JND was somewhere around 2.5dB. There's a FAQ entry which gets into cross-fade calibration. (by the way, thanks again for being the very first writer to cover the D-1 DAC, way back in December 2023! It was a brilliant premier article, over a year before we actually started shipping).
Imersiv D1 Multi-Path Digital-to-Analog Converter Completes 32-bit Audio Chain
Unveiled at the 2023 AES Conference in New York, the new Imersiv D1 Digital-to-Analog Converter is the first product from a new brand created by Millennia founder John La Grou, and the first to introduce to the market his approach to multi-path technology. The results of years of research and...audioxpress.com
From the FAQ https://imersiv.com/faq/
My corrections regarding the errors in post #369, which I quote below, remain unchanged.My bad, you are right about electrets not needing external bias. But the point I made still stands. Most studio condenser mics have built in preamps that need phantom power. These preamps have noise that limit the S/N of the recording so a ADC thats 28 bits has no noise advantage over a 24 bit ADC.
Condenser microphones require some kind of power because biasing the capsule is essential.Condensers mics that use phantom power (almost all of them) have built in preamps (thats what the phantoms for).
Why does the D-1 require a calibration in order to ensure that the high path and the low path combine seamlessly depending on the hardware that are plugged in to the output of the Immersiv D-1? Does that mean that the two paths are not summed internally but through the load that is plugged in to the DAC output ? In other words, the summation node (Σ) on the below drawing does not correspond to some sort of output buffer internal to the Immersiv D-1?
If it is so, are there restrictions to the loads that the Immersiv D-1 is able to drive?
Not really. Dynamic mics dont have built in preamps, codensers do because of the capsules very high output impedance.My corrections regarding the errors in post #369, which I quote below, remain unchanged.
A microphone preamplifier is needed somewhere, and it's possible to power it using AC, battery, or phantom power, but that's a separate topic from the type of microphone.
Hi. Thanks for clarifying that, however, I have two problems with this distinction:Thanks for that. We know of at least two sources using electrostatic speakers who aren't hearing any difference in spatial-depth information between DACs. We don't have any e-stats here to test with. This bit of detail was added to the FAQ some months ago. From the FAQ https://imersiv.com/faq/
Let me @signalpath be more blunt.Hi. Thanks for clarifying that, however, I have two problems with this distinction:
Again, I appreciate you interaction with the forum here. Until now, all the credible evidence I have seen still supports that there is no audible difference between the D1 and other competently engineered DACs. This also specifically applies to the idea of "sound stage", which happens to be difficult to link to individual measurements. The latter is also very convenient for someone claiming to offer an improvement in this subjective metric.
- The listening tests were done using three pais of speakers + a bass array: Quad ESL 988, JBL 308p mkii, NHT 3.3. Only one of these speaker pairs is electrostatic, the JBL are professional monitors and the NHT are regular passive towers. Not all testers listened using all speakers, but the results for all speakers were "no difference heard".
- With all due respect, but this exception that electrostats wouldn't show the advantage and happen to be precisely the speakers used by some reviewers not supporting your claims is just incredibly convenient. You do see that this argument is in essence the same as the default audiophile argument of "your speakers aren't resolving enough to hear the difference", right?
www.audiosciencereview.com
If you want to continue to claim audibility of the measurable improvements between the D1 and any other well-measuring conventional audio DAC, then it is time to put your money where your mouth is, and prove it by carrying out some verifiable, fully documented, properly controlled, and statistically relevant blind testing - preferably of the ABX forced choice form.
Audio Blind Testing - You Are Doing It Wrong! (Video)
Just uploaded a video on the basics of performing controlled tests in audio. It was motivated by saving myself text in having to write all of this down when telling someone who to do these tests right. And as a counter to a few online personalities to keep saying they do "blind" tests yet when...www.audiosciencereview.com
Please read the 30+ pro comments on the imersiv website. If you find them "not credible" I would be curious as to why. These are the most credible ears on the planet. Read the pro media reviews, all of whom work in professional studios. Most of these pro engineers did A/B testing against other DACs. And most listening was done in highly resolvent studios, not a living room. https://imersiv.com/press/Until now, all the credible evidence I have seen still supports that there is no audible difference between the D1 and other competently engineered DACs.
As far as I can see after scanning the linked press material, there are maybe five reports from sighted listening "tests" in there? The most prominent being the one from Bob Katz, which has already been discussed and critiqued in this thread. The rest of the links lead to people reporting from the 2024 AES show about various new devices or magazine articles, all of which pretty much just recite the tech specs and marketing material about the D1.Please read the 30+ pro comments on the imersiv website. If you find them "not credible" I would be curious as to why. These are the most credible ears on the planet. Read the pro media reviews, all of whom work in professional studios. Most of these pro engineers did A/B testing against other DACs. And most listening was done in highly resolvent studios, not a living room. https://imersiv.com/press/
I don't think they are marketing to ASR. I think that consumers are buying it is weird, but revenue is revenue. Also I think this thread is becoming unnecessarily heated.I don't criticize the device, I criticize the marketing.
I recommend the famous Sengpiel webpage (should be available both in native German and English) to learn about the definition of these terms as well as to use the very helpful conversion tools.Root-power quantity: voltage, sound pressure.
Power quantity: power, sound intensity.
Now:
Power scale with voltage squared.
SPL scale with sound pressure squared.
While SP is root-power quantity, SPL is defined to behave like power quantity. It mimic SIL - sound intensity level, which is power quantity.
There is no problem, if we use SPL represented in dB. My question is, what does it mean twice SPL. Is it 3dB or 6dB?
It seems to me to be way beyond what human hearing could ever appreciate. It's a drop forge filling in for what a tack hammer could easily handle.130 dB SNR is somewhere between 21 (126) and 22 (132) bits. 28 bits would be 168 dB.
Or somebody is playing with numbers, or my maths are really rusted.
So it’s anecdotes and testimony like cable advertising ?Uncontrolled and sighted listening. No one is immune to perceptive bias—no matter what gear they are using, their experience, training, or the general golden-ness of their ears. It is how human perceptions work. Let me reiterate: No one is immune. Not One Person.
On the other hand - the more "industry" a person is - the more (it seems) they view their hearing as infallible.
EDIT - I have now followed every link on that page and have not found a single description of any blind test— let alone a well-documented, implemented, and controlled one.
Hello All! This is my first post to ASR.Real science has to be done in a controlled way to be meaningful. If you are at home testing DACs and not doing it in a proper double blind, volume output matched way the results you are getting are worthless and not scientific. This "do you own research" thing people throw around is only meaningful when the research is done correctly. I would love to see the results of proper double blind testing on this DAC or any others people claim are worth their higher price or more complicated design.
The D1 review posted states the DAC has "unshakable sense of completely unobstructed transparency." So does the SMSL SU-1 for $70. If this $12000 DAC is truly transparent as is claimed, how can it sound different from a $70 DAC that is also tested and proven to be transparent? The D1 is either transparent or it is coloring the sound. It can't be both.
