Once again: Sound Pressure goes with 1/r. If one is solving any equation of the style 1/(r+d) = x * 1/r (and thus xr + xd - r = 0) for r, x or d there is no squaring involved, nowhere.
Yes, relation between % and dB could be the reason for misunderstanding.Where? The only time I've mentioned dB's was that "10% less SPL = ~ -1dB"
Yes, -1dB SPL is about 10% less SP, which means about 25cm at 2.5m distance.Once again: Sound Pressure goes with 1/r. If one is solving any equation of the style 1/(r+d) = x * 1/r (and thus xr + xd - r = 0) for r, x or d there is no squaring involved, nowhere.
I guess what I’m trying to say is that, given how stereo audio is typically recorded, mixed, and mastered, “stereo bass” doesn’t really hold up in practice. While interaural level differences can technically work at low frequencies, real-world playback environments, like domestic living spaces, tend to disrupt that information so much that it becomes meaningless ("not localizable"). In that context, using mono bass to reduce resonances often yields better results than trying to preserve or create stereo bass.It just shows that localization perception is also based on level, ILD at work. Together with ITD this allows bass and even very low bass to be perceived as directional just as any other frequency range
While actual speakers will be seldom closer than 1.5m, nothing stops us from rendering phantom sources at closer distances, using crosstalk cancelling. This is tricky with low bass but not totally impossible.
The main point was debunking the myth that low bass < 80Hz cannot be localized and thus a mono sub can cover all possible scenarios. It can't.
And now back to thread topic again.
SPL is proportional to V. Power is proportional to V².For me, putting twice power into an amp gives twice SPL
A double for power quantity is +3 dB. A double for root-power quantity (like sound pressure) is +6 dB.Actually, I don't know, which approach is commonly used.
The Electret microphone capsule contains charged material, so an external power supply is not necessary.Bias voltage is for electret mics, most studio condensers are not electret they use amplifiers in the mic body.
Root-power quantity: voltage, sound pressure.A double for power quantity is +3 dB. A double for root-power quantity (like sound pressure) is +6 dB.
Power, root-power, and field quantities - Wikipedia
en.wikipedia.org
The P in SPL means pressure, not power. SPL is the ratio of sound pressure over silence atmospheric pressure. So it is not scaling like power but like root-power.Root-power quantity: voltage, sound pressure.
Power quantity: power, sound intensity.
Now:
Power scale with voltage squared.
SPL scale with sound pressure squared.
While SP is root-power quantity, SPL is defined to behave like power quantity. It mimic SIL - sound intensity level, which is power quantity.
These statements are analogous only if by P in SPL you mean power. But Sound Power Level is abbreviated as SWL. SPL is Sound Pressure Level.Power scale with voltage squared.
I would say, you convert your input SPL to an absolute value, double that, convert back to SPL and compare. For example:My question is, what does it mean twice SPL. Is it 3dB or 6dB?
My bad, you are right about electrets not needing external bias. But the point I made still stands. Most studio condenser mics have built in preamps that need phantom power. These preamps have noise that limit the S/N of the recording so a ADC thats 28 bits has no noise advantage over a 24 bit ADC.The Electret microphone capsule contains charged material, so an external power supply is not necessary.
Other condenser microphone capsules are not like that, and therefore require some kind of power supply.
Whether the microphone's preamplifier is built-in or external is a separate issue.
IMO we shouldn't ignore mathematics. Twice in logarithmic scale is 3dB. The convention to use 20*log for root-power quantities ensures, that level values behaves the same as level values of power quantities.So, double SPL is +6 dB
The ratio squared.SPL is the ratio of sound pressure over silence atmospheric pressure.
Lol, I am out.IMO we shouldn't ignore mathematics. Twice in logarithmic scale is 3dB. The convention to use 20*log for root-power quantities ensures, that level values behaves the same as level values of power quantities.
The ratio squared.
Do you recommend a "break-in" period? And should I keep the D-1 on stand-by or DC off?
We generally burn-in for minimum 160 hours (7 days) and exercise the noise-gates around 200,000 cycles during burn-in. Just before a D-1 is shipped, it is given a final critical listening test of at least 10 minutes. We see no need for an additional “break-in” period, but it certainly won’t hurt.
Stand-by (sleep mode) or DC off are both are fine. Personally, we leave our D-1 units on standby, but turn the OLED display off. See the FAQ entry above “OLED Display Health.” If left on over some years, OLED can tend to leave a “residual” echo on the screen substrate.
It is a reliability burn in, not sound quality conditioning.I find it hard to take this DAC seriously when they talk about burn-in.
www.audiosciencereview.com
You just happen to be preconditioned in the wrong way by the abuse of the term "burn-in" in audiphile circles.I find it hard to take this DAC seriously when they talk about burn-in.
The UTB Transformer Interface Box was designed for situations where a D-1 destination (power amplifier, headphone amp, preamp, etc.) does not have XLR diff-bal inputs. The UTB uses a pair of ultra-high-grade Lundahl LL1585 line transformers to convert the D-1 XLR diff-bal output to an unbalanced RCA feed.
Use a highly-shielded XLR balanced cable to connect the D-1 to the UTB input, with a very short RCA cable at the destination end. We recommend Gotham 11301 “Ultra-Pro” cable for all D-1 analog interconnects.
The superior Lundahl xfmrs are performance-rated to a much higher maximum headroom level than the D-1 (+28dBu @20Hz), which means HDR-A dynamic range is preserved.
Electronics do not "burn in" in any audible sense. There is also no audible difference between the D1 and any other competently designed DAC running the same filter and settings. All that happened is that your brain got used to it and you lost that "new stuff!"-feeling.We should ask the designer of the DAC if that was the intended purpose. On a DAC, the reliability burn-in thing does not seem to be that common with DAC manufacturers. I do know that I received 2 brand new D-1's with what was supposed to be 0 hours on it. I thought it did not sound good at all at first and needed about 150 hours before it got really good.
Using isolation transformers is generally not recommended for low voltage analog connections like RCA and XLR. You almost always get problems in the bass region, which is clearly not something you would want. If there is any audible difference between using the transformer and not using it (in a controlled blind test) with the same devices, the transformer is making it worse and should be ditched.BTW - I just found out that there is a new transformer-based passive converter for RCA connections. I heard a prototype (built by someone else) before on the D-1 and have been waiting to buy a real production version. This is going to be for my $400 Schiit Aegir v1 Class A amp to connect with the D-1. The amp drives my RAAL SR1a phone. This combo was so good that I sold a $7k tube headphone amp and went with the $400 amp.
I am assuming you have not heard the D-1. I know that this is a measurement only crowd on ASR, and I believe the D-1 measures better than all other DACs. Just by the measurements alone I would think this DAC would stand above other DACs on this site. The measurement reports were why I initially wanted to hear this DAC.Electronics do not "burn in" in any audible sense. There is also no audible difference between the D1 and any other competently designed DAC running the same filter and settings. All that happened is that your brain got used to it and you lost that "new stuff!"-feeling.
There is generally no reason to use an isolation transformer on XLR or RCA lines, unless you've got a clearly audible ground loop or other obvious noise problems. If you need the conversion from RCA to balanced, just get the right adapter cable or use an active pre-amp which does it.
You're in luck! People more qualified than you and me already tested the D1 in detail and also did extensive blind and sighted listening tests compared to an industry standard interface (RME ADI 2 FS B). They found that it measures excellent, just as transparent as the RME. But since there is no more transparent than transparent, both devices will sound identical. And their listening tests confirmed this assumption!I am assuming you have not heard the D-1. I know that this is a measurement only crowd on ASR, and I believe the D-1 measures better than all other DACs. Just by the measurements alone I would think this DAC would stand above other DACs on this site. The measurement reports were why I initially wanted to hear this DAC.
I totally believ that you've got that impression. However, semiconductor devices don't "burn in". They work within spec, often for decades. If you feel like the sound of a device changes, this is likely your brain tricking you. Bias is real and strong for all humans. I have seen absolutely zero evidence up until now to show that "burn in" exists in any form and again, you are free to provide some. Simply saying "but I heard it!" will not advance this discussion, because opinions are not facts.The only 2 pieces of gear I have owned that did not improve with more hours was the $500 Schiit Valhalla 3 OTL/OCL (my current office preamp) and the Benchmark AHB2 amps, which I owned many times but no longer. Though I am interested to hear the D-1 paired with a AHB2.
You sure can build devices with transformers in them. I don't see what's special about this particular one with the exception of marketing jibberish like "Fractal-Wire" and the lack of basic specs like frequency response. Being a genius also does not replace solid engineering.There are 3 very respected audio guys that I know who have built transformer based passive switch/preamp. I heard 1 of them and the D-1's UTB was likely inspired by the one I heard since the 2 designers know each other. Then there is also this one.
The Townshend guy is a genius in my books based on the podium isolation platform for speakers, which I own.
These are low voltage high impedance "line level" connections. There is basically no power flowing, only the voltage levels change. In that regard, line level signals are totally different than connections from the amp to the speakers. Where is this danger supposed to come from? At best, you surprise yourself with a short burst of noise or the volume is greatly attenuated in case the adapter cable has a different XLR pin out."There is generally no reason to use an isolation transformer on XLR or RCA lines, unless you've got a clearly audible ground loop or other obvious noise problems. If you need the conversion from RCA to balanced, just get the right adapter cable or use an active pre-amp which does it."
This is a very dangerous way to convert. Holo Audio Serene preamp guys told me that that could kill their preamp using such a cable.
Again: Without solid controls (blind, level-matched), any listening test just generates noise. Humans are biased, placebo-like effects from buying new gear are strong and you cannot compare devices by listening to them hours or even minutes apart because our echoic memory is only a couple of seconds long. I understand that you did not know this at the time, but your listening comparisons did not generate reliable results and your impressions from these devices are most likely wrong.I sold the Serene after I heard the transformer passive preamp my friend made. The Serene could not compete sonically with the transformer. I believe the Serene also measures well like Benchmark LA4 preamp. I owned the LA4 or HPA4 for over a decade but sold it since the D-1 did not sound good going through it. The D-1 sounded best going direct into the amp or the transformer. First time the LA4 or HPA4 did something negative to the sound.
I am sorry, but you won't impress anybody on ASR with bragging about expensive HiFi equipment. We focus on what matters for good sound reproduction, which tends to be mostly uncorrelated to the price (maybe with the exception of speakers). There are a multitude of tests on the forum showing superb performance for a couple dozen or hundred dollars. And there are also some showing equipment for thousands of dollars being rubbish.Last week I sold a CODA #16 amp ($$$) to replace it with the 30-year-old CODA #11 amp ($). This was because the D-1 direct into the much cheaper Class A CODA #11 sounded better to me. The #11 is slightly warmer than the #16 but less resolving. The D-1 makes up for the less resolution of the #11.
Since I owned the D-1 (Dec 2025) I have sold $27k worth of audio gear on USAM (yyzsb) because they became expendable. The Valhalla 3 OTL/OCL had a small part in that, but the main driver for all the sales was the D-1.
