The first inside picture on this webpage clearly shows at least one ESS DAC, though the part number cannot be read: https://www.soundpure.com/p/millennia-imersiv-d-1-stereo-multi-path-dac-black/39443I found one pic https://imersiv.com/wp-content/uploads/2024/12/D-1-Product-Page-Close-Up-4.png
Still can't see the DAC chip, I agree, I'm stupid. Could you please call the part number?
WOW, I didn't expect that. THD+N is worse than -114db, how did they implement it?ES9038PRO
www.audiosciencereview.com
So no advantage using any mic that needs phantom power, most codensers, and tube mics.There is no additional preamp. The TrueMatch modules are self-contained. The idea is that the preamp/ADC under no circumstances whatsoever compromises the recording. No more issues from gain settings wrongly estimated and then ending up being too hot (clipping/limiting) or too cold (more hiss from the preamp/ADC than from the mic). That's a huge benefit in large-scale applications.
Despite the somewhat cheesy company name which sounds like cheap far-east entry levels stuff, StageTec is one of the most professional audio companies in the world, for decades (founded 1993 by a number of former Neumann engineers).
What does mic type have to do with that? The advantage of never running into gain setting issues is very real in practice with any mic.So no advantage using any mic that needs phantom power, most codensers, and tube mics.
Condensers mics that use phantom power (almost all of them) have built in preamps (thats what the phantoms for). These analog mic preamps have dynamic ranges much less than that preamp so whats the advantage of it? Ditto for tube mics. And if you think about the ambient noise in all recording spaces those ultra high S/N ratios are useless.What does mic type have to do with that? The advantage of never running into gain setting issues is very real in practice with any mic.
I hope we can keep ASR calm and friendly. Gain staging is a critical point of this topic. I have the opinion that the D1 is the start of higher dynamic range recording chains. Millennia Media, @signalpath makes microphone preamps, including with ADC, 24bit?, which hope someday are tested on ASR's Audio Precision, joining other microphone preamp tests. I hope Audio Precision and Rohde & Schwarz keep improving their test instruments. And I hope Analog Devices continues ADC innovation. Out of college I had a job offer from them, they are a great company, but I went to the dark side of digital.Condensers mics that use phantom power (almost all of them) have built in preamps (thats what the phantoms for). These analog mic preamps have dynamic ranges much less than that preamp so whats the advantage of it? Ditto for tube mics. And if you think about the ambient noise in all recording spaces those ultra high S/N ratios are useless.
Gain staging is recording 101 and if your depending on your gear to do it for you you flunked.
?Condensers mics that use phantom power (almost all of them) have built in preamps (thats what the phantoms for).
Obviously you have no idea what the conditions are in those large scale top tier installs that StageTec is dealing with. You may have many dozens of mic channels going into ADCs in a remote gear room/closet, not easily accessible for manual gain settings. You'd need racks full of mic preamps with remote control of the gain settings, and remote monitoring as well. Totally impractical. Good luck telling the producer the orchestra and singers have to do the whole opera one more time because you wrecked it, driving some mics into clipping or with too much headroom and noise, both of which may be only identified later in the production stage.Gain staging is recording 101 and if your depending on your gear to do it for you you flunked.
So before StageTec recording an orchestra was impossible?Manual gain staging with conventional gear is only possible in small, localized setups like smaller recording studio, and when you have the time.
Bias voltage is for electret mics, most studio condensers are not electret they use amplifiers in the mic body.?
The reason condenser microphones require power is because a bias voltage needs to be applied to the capsule.
Whether a microphone preamplifier is built-in or external is a separate issue from the type of microphone.
Agree. In the analog domain theres no amplifier (opamp cct) that even comes close to 24 bit dynamics so again theres no point. So the bottle neck of this DAC is the analog circuit and your not going to get even 24bit performance.
I guess, THD+N -152db(the plot shows -153-155db) is a simulation-based number. The noise itself for 1nV/sqrt(Hz) and ideal zero impedances setup, makes -154db, H2 level -157db.I think the Weiss OP2 opamp claims a 152dB SINAD, see https://weiss.ch/products/oem/op2-bp-2/
This would imply about 25 bits of dynamics, we are actually there. Since it is also marketed at the professional market, I would expect them to avoid absurd claims.
I looked at this link and am having some difficulty fully understanding the causal link between tmin and human hearing sensitivity and the fact that bit depth is the only factor contributing to the calculation of tmin. Be that as it may, if there is a direct relationship between tmin and human hearing sensitivity, based the equation presented in the link you provided low level (-40db), low frequency (20Hz) signals would have a tmin value of 11,000,000ns, or 11us, within the time resolution of human hearing. So at the very least, wouldn’t this dictate that for very high fidelity reproduction that 24bits or even 20 bits would be an improvement?16 bit / 44.1 kHz gives you a time resolution of about 0.1 ns. Even if you assume that you lose an order of magnitude in resolution due to noise + dither, 1 ns is far, far better than anything humans could ever discern
My understanding is as follows: As long as your sampling rate is high enough to have a Nyquist frequency above the upper threshold of human hearing (commonly quoted as 20 kHz), you can reproduce all relevant frequencies faithfully. This is the case for common audio formats, which start at 44.1 kHz sampling rate and go up to a couple hundred kHz. At that point, only your bit depth detemines the loss of precision in your recording. This loss is called quantization error. In itself it is an amplitude error, but of course a slight difference in amplitude at the sample points would also shift a sine wave of a fixed frequency slightly to the left or right in the reconstructed signal. So in the end, this amplitude error due to quantization also limits the time resolution of your reconstruction. Other members with a deeper understanding of the topic are welcome to correct me on this, in case this explanation isn't quite accurate.I looked at this link and am having some difficulty fully understanding the causal link between tmin and human hearing sensitivity and the fact that bit depth is the only factor contributing to the calculation of tmin. Be that as it may, if there is a direct relationship between tmin and human hearing sensitivity, based the equation presented in the link you provided low level (-40db), low frequency (20Hz) signals would have a tmin value of 11,000,000ns, or 11us, within the time resolution of human hearing. So at the very least, wouldn’t this dictate that for very high fidelity reproduction that 24bits or even 20 bits would be an improvement?
There is no loss of precision for signals below Nyqust frequency. Please note, that if we talk about signal with frequency, we mean periodic wave, which consist of multiple samples. There is no shift of signal caused by error of a single sample. Actually with a proper dithering, quantization error is turned into noise. And you can hear periodic signals below noise level.At that point, only your bit depth detemines the loss of precision in your recording. This loss is called quantization error. In itself it is an amplitude error, but of course a slight difference in amplitude at the sample points would also shift a sine wave of a fixed frequency slightly to the left or right in the reconstructed signal.
The actual DA convertor output is stepped, i.e. it contains above-nyquist ultrasonic frequencies which must be removed (the steps "smoothed out") by the analog reconstruction filter. For 44.1 the nyquist is 22kHz - it's very hard to make an analog filter so steep to keep 20kHz and "completely" eliminate 22kHz. So e.g. upsampling 8x moves the nyquist to 176kHz - the analog reconstruction filter now must filter out everything above 176kHz, while keeping 20kHz - much easier to do.t would be great to have reference of why upsampling is necessary if 44.1kHz provides adequate resolution to record material in the audible range for humans,
