mhardy6647
- Joined
- Dec 12, 2019
- Messages
- 11,372
- Likes
- 24,579
He was all about that bass...You know Godzilla stomping around would generate all the bass. ALL the bass.
I have a hard time comparing the ellipticor woofer with purifi woofer in erin's review. The L(x) is better on purifi but symmetry range for Bl and Kms seems worse. How do those things affect the woofer and which one is the better one? The distortion might be the ultimate goal for all those motor measurements, and the distortion on purifi in my opinion is a bit better. What do you guys think?
For most of people they want to use the woofer extend to subbass, why is that? For me I think get dedicated subwoofer not only reduce IMD and distortion, but also makes placing the sub according to room modes a bit easier. So if I want to get a woofer, I will get purifi woofer and just put it into closed box, make a crossover at 80 Hz and spend the rest of money to get subwoofer. Very easy to design and make, better distortion and better room mode treatment.
The ellipticor measurement was from voice coil test bench, not from erin. They both use kllipel to measure the motor so I think we can compare their results.Do you have a link to the Ellipticor review you're talking about, please? I can only find the Purifi measurements on Erin's website.
Thanks for your input. I agree with you that distortion are quite similar except over 500Hz. One thing interesting is when ellipticor increases in 2nd harmonic, the 3rd harmonic decreases. That decrease is nice but increase in 2nd harmonic really makes it not as good as purifi.
Do you know what makes IMD? How does harmonic distortion relate to IMD? For example if we have a driver with higher 2nd HD and lower 3rd HD, how does the IMD compare to driver with lower 2nd HD and higher 3rd HD?IM distortion is unlikely to be high given that H3 and presumably higher-order harmonics are low in level
Are they? A polygon with three cornes (Illuminati confirmed) would be a way to go. Or all low order uneven ones.ellipses are not symmetrical
Do you know other woofers that has the same low distortion above 80 Hz?
"The asymmetrical shape of the voice coil....."? An ellipse is NOT asymmetrical because an ellipse has 2 line of symmetry.The two companies pursue very different strategies with these two model series.
Purifi's chassis is revolutionary in terms of the overall concept - very low HD, high linear excursion Xmax, high power handling.
In the case of the Ellipticor series, the revolutionary is quite obvious, elliptical shaped voice coil, magnet gap and dust cap, but also the damping of the chassis cone and surround.
The review of the 21WE/4542T00 (German Hobby Hifi 2019 No 5) I know shows very good measurements. The asymmetrical shape of the voice coil and dust cap, seems to suppress harmonic distortions of odd order extremely well.
In this review HD2@90dB is from 50Hz-9kHz at or below 0.32%. But the outstanding thing is that HD3 and HD5 are below 0.01% at 90dB in the frequency range 250-1600Hz, which is more than -80dB attenuation of the odd order HD.
For an 8.5'' chassis these are sensationally low HD3 and HD5 values - the concept seems to be, a bit more HD2, but extremely low HD3 and HD5 (significantly lower than what I would expect from an 8'' Purifi woofer in this frequency range).
Unfortunately, the price for the chassis is painfully high.
"...:ellipses are not symmetrical."? According to Geometry ellipses are symmetrical.Basically, nonlinearities in the driver. These arise for various reasons. For example, as the voice coil moves back and forth through the gap, the force exerted on it by the motor varies (i.e tends to decrease with voice coil displacement). Similarly, as the cone moves back and forth the stiffness/compliance of the suspension varies. Another common source comes from voice coil inductance (particularly problematic at higher frequencies). There are of course many other possible sources of nonlinearity.
Interestingly in the context of the Ellipticor drivers, symmetrical nonlinearities generate odd-order distortion components (odd-order HD and odd-order IMD), while asymmetrical nonlinearities generate even-order components. This is one reason why 3rd-order HD is so much lower in this Ellipticor driver than 2nd-order HD: ellipses are not symmetrical.
I'm not at all well-versed in the signal theory that would be necessary to answer this question properly, so the version for dummies that I can give you is probably a massive oversimplification that can't be applied directly in practice.
Having said that, the essential relationship as I understand it is that the higher in order the harmonic, the higher in relative level the equivalent-order IM product will be.
In other words, if we have H2 and H3 at the same level, IM3 will be higher in level than IM2, etc. (I believe the simplified form of the relationship, not taking into account lots of very important factors, is: IM[n] = n*H[n], where IM[n] is the level in dB of IM of the nth product and H[n] is level in dB of the nth harmonic, but don't quote me on this.)
