- Joined
- Jun 24, 2024
- Messages
- 2,724
- Likes
- 4,717
Ah, yeah that'll do it. I forget people still use those things.The preamp was at its minimum (no output) setting but still connected to a live stream from an FM tuner.
The ESS AMT-1 is rated over 100 dB/watt, so would be hard to fry in usual home context: to low crossover frequency of the high pass to cover the roll-off of the bass starting from 1 kHz might cause this?Way back in the day when I worked for a NoVA audio chain there wasn't a week that went by without stores sending in to the shop Advents of both sizes and ESS AMT-1s with blown tweeters. Others for sure, but those were the ones we saw constantly.
Still? That event was in the last century.Ah, yeah that'll do it. I forget people still use those things.![]()
No idea, just that we saw them just about every week coming back into the shop.The ESS AMT-1 is rated over 100 dB/watt, so would be hard to fry in usual home context: to low crossover frequency of the high pass to cover the roll-off of the bass starting from 1 kHz might cause this?
Hard clipping by underpowered amps will do that.The ESS AMT-1 is rated over 100 dB/watt, so would be hard to fry in usual home context: to low crossover frequency of the high pass to cover the roll-off of the bass starting from 1 kHz might cause this?
The hole speaker's sensitivity is rated at 98 dB ... even a tube won't clip at sensible loudness (and 98 dB is still very loud, even at 2 m distance it's over 90 dB).Hard clipping by underpowered amps will do that.
Ever have kids around your gear? They can't keep their grubby little paws off anything. A quick clockwise twist of the volume knob up to eleven, and you're crying in your Cheerios.The hole speaker's sensitivity is rated at 98 dB ... even a tube won't clip at sensible loudness (and 98 dB is still very loud, even at 2 m distance it's over 90 dB).
I still use FM (NAD 4300) & do DXing. (I can't hear above 14 K, anyway)Still? That event was in the last century.
Never damaged anything myself. I kind of wonder what people are even doing to make it happen. I do a lot of DIY and I've had amps mess up and wires cross that send nasty signals to tweeters and still nothings been damaged.
Executive order should be passed, forcing hifi manufacturing companies to revert back to old school aesthetics.I have a... thing... about FM tuners (mono or MPX stereo).
Never (yet) damaged anything with one, though.
I will note that coupling capacitors between source and amplifier are cheap insurance just in case there's some DC riding on the output of the former.
In numerous cases, they have.Executive order should be passed, forcing hifi manufacturing companies to revert back to old school aesthetics.
Dang impressive memory for your calculated age group!1966:
Still has the spinner knob but is digital tuning, that is as far as I will go with it (my other tuners are older than this NAD 4300):I have a... thing... about FM tuners (mono or MPX stereo).
Here is a good way to set something off, though:
