not parametric EQ.... which the others listed have.... . . Mojo2
The original post said:not parametric EQ.... which the others listed have...
Did you mean cynical? Please explain.How cynical that one of the first hifi DAC's with EQ capabilities is a dongle. How many discussions did I see about how difficult and expensive it would be to provide this feature?
A few use cases: iPhones, streaming app with no EQ (or no good one), when you want to leave a dongle attached to your headphones or IEM to not have to mess with presets.When is the need for onboard EQ on a DAC ? I wonder
I also think the price might be a barrier, especially if it's *only* used with portable devices. OTOH you do get real quality, and it's a bargain compared with things like the AQ Dragonfly.A few use cases: iPhones, streaming app with no EQ (or no good one), when you want to leave a dongle attached to your headphones or IEM to not have to mess with presets.
I also think it’s too expensive compared to
A Qudelix 5K. But it’s a neat dongle!![]()
There are EQs for iphones. UAPP does Tidal and Qubuz.A few use cases: iPhones, streaming app with no EQ (or no good one), when you want to leave a dongle attached to your headphones or IEM to not have to mess with presets.
I agree, however, technically, the V1 has better measurements on distortion levels, but much less power.I also think it’s too expensive compared to
System wide?There are EQs for iphones.
And more PEQ bands.I agree, however, technically, the V1 has better measurements on distortion levels, but much less power.
Nope:And more PEQ bands.
www.qudelix.com
??? The 5K, from a couple of FW revisions ago, does offer 20x PEQ, or 2x10, or 10+10L+10R, or GEQ, or 10GEQ +10xPEQ…And more PEQ bands.
Is that per channel?Nope:
Qudelix-5K Bluetooth DAC AMP
Qualcomm QCC5124 Bluetooth Dual ES9219C SABRE HiFi® DAC 3.5mm Unbalanced 2.0V RMS 2.5mm Balanced 4.0V RMS aptX Adaptive, LDAC, AAC, aptX-HD 6 ~ 20 hours battery time USB DAC 96KHz / 24-bit 20-band Double Precision PEQ/GEQ High Sensitivity 3-D LDS Antenna Qualcomm® cVc™ noise cancellation High...www.qudelix.com
I wouldn't know.System wide?
I have multiple headphone profiles, setup on my phone with Neutron media player, that I can dial in with a couple of taps. They use no more than 4 bands each!And more PEQ bands.
Can you name one? I’m not aware of any system-wide EQ for iPhone.Not an iphone guy, but I know they exist.
Not wanting to be pedantic, but that's not 20 PEQ bands per channel.??? The 5K, from a couple of FW revisions ago does offer 20x PEQ, or 2x10, or 10+10L+10R, or GEQ, or 10GEQ +10xPEQ…
I don't think the Neutron has BlueTooth. That might be as big a deal as anything else for most users.Nope:
Again, not an expert:Can you name one? I’m not aware of any system-wide EQ for iPhone.
It needs USB power and a player. BT is really not required.I don't think the Neutron has BlueTooth. That might be as big a deal as anything else for most users.
I'm saying that the Qudelix has BT, which IMO is a big plus over the Neutron as you don't need a cable source-to-DAC. The Qudelix also has a claimed 6-20 hours of battery time, another plus.It needs USB power and a player. BT is really not required.
Now if it had onboard power, then BT would have been really nice, even a must. Perhaps they could make an addon device.
I went another direction: several Qudelix 5K & T71 “attached” to headphones, and a bunch of FreeDSP cables or equivalent “attached” to IEMs. After setting up an EQ that works for me… I just swap USB-C enabled HP & IEM between my iPhone, Laptop, Work Laptop (no EQ app allowed…), and, if I wanted, Raspi, PlayStation, etc. No need for any tap in any app after the initial PEQ setting.I have multiple headphone profiles, setup on my phone with Neutron media player, that I can dial in with a couple of taps.
Maybe… But then why Neutron‘s only DAC/Amp device is precisely built around a HW DSP solution?I am saying it is a very narrow Need!
All right, you’re correct on this one.Not wanting to be pedantic, but that's not 20 PEQ bands per channel.
